on line data search programs - which is best?
by bmwjohn
02/12/16 10:11 PM
What size air compressor is needed
by ram_man
02/12/16 09:45 PM
DHS wants to force car owners to use OEM parts
by faltic
02/12/16 08:54 PM
Castrol Edge 5w30 no longer A5/B5
by slacktide_bitog
02/12/16 08:20 PM
Best Oil Analysis?
by countryboy9799
02/12/16 07:28 PM
Left my lights on and battery died.
by joegreen
02/12/16 07:25 PM
Honda CRX '91 transmission fluid
by jhmed80
02/12/16 07:18 PM
It's winter, let's take out the... Motorcycle???
by OVERKILL
02/12/16 06:54 PM
Home Testing for Gas in Oil?
by landtoy80
02/12/16 06:54 PM
Cost to replace windshield.
by Oldmoparguy1
02/12/16 06:44 PM
Oil Life Monitor vs. Mileage vs. Time
by HOG
02/12/16 06:24 PM
Carrier A/C moving ALL production to Mexico.
by GiveMeAVowel
02/12/16 06:23 PM
RTS, jhmed80, engus, Rob_Pol, Nick24w
56901 Registered Users
78 registered (74DartSport, akela, 2015_PSD, 90crvtec, 04SE, 01_celica_gt, 3 invisible), 1155 Guests and 211 Spiders online.
56901 Members
66 Forums
244623 Topics
Page 1 of 2 1 2 >
#1863573 - 04/19/10 04:48 PM saab sludge
Edmund Offline
Loc: Canada
I have recently purchased a 2002 saab 9-3 se. They are notorious for sludeging it has 130 000kms on it. I am wondering what the best way to check way to if it is indeed a problem I was planning on running an amsoil engine flush and then running amsoil synthetic. Any thoughts?
#1863582 - 04/19/10 04:53 PM Re: saab sludge [Re: Edmund]
saaber1 Offline
Loc: Pacnw
Pulling oil pan and taking a look is probably the best way. Checking under oil cap (if you can see any internals) is another way that can give you a hint if it is sludged up or not. Most importantly, what has been the previous oil change history? Have they been running a good synthetic? At what intervals?
"when 5W30 is cold, ...the oil is 35 weight (5+30),...20 w 50 starts at 70 and warms up to 50"
- Kyle, auto mechanic & VP Speedline Motorsports, INTL
#1863583 - 04/19/10 04:54 PM Re: saab sludge [Re: Edmund]
tig1 Offline
Loc: Illinois
Welcome! If you can take the valve cover off that will tell the tail about sludge. As for cleaning slude out I would scrape all you can get out. Draine the oil and refill with M1 10-30HM.
Edited by tig1 (04/19/10 04:59 PM)
2007 Ford Fusion 173,000 miles
M1 0-20 AFE
2007 Ford Focus 151,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#1863584 - 04/19/10 04:54 PM Re: saab sludge [Re: Edmund]
d00df00d Offline
Loc: PA
welcome to BITOG!
If the engine doesn't have any serious apparent problems, the only way to check is to open the engine up. You may be able to shine a light into the oil fill hole and check; if that doesn't work, you'll have to pull the valvecover.
Either way, there's no need for the engine flush. If there is sludge, you'll want to remove it SLOWLY so you don't get chunks floating around getting stuck where they shouldn't. And of course, if there isn't sludge, there's nothing to worry about. wink
What's the spec oil? Isn't it Mobil 1 0w-40?
2011 Mazda RX-8 R3
Castrol GTX 5w-20
#1863591 - 04/19/10 05:00 PM Re: saab sludge [Re: saaber1]
Edmund Offline
Loc: Canada
Unfortunately i cannot get the history and the oil cap is not ton the valvle cover. I have thought about dropping the oil pan but it is a pain in the [censored] as it requires the removal of the sub frame.
#1863669 - 04/19/10 06:04 PM Re: saab sludge [Re: Edmund]
Deltona_Dave Offline
Loc: Deltona, FL USA
I would try running Pennzoil Platinum for a while. It gets rave reviews on this board, and cleans slowly, but effectively. It is readily available at Wally Mart for about 20 dollars for a 5 quart jug. 2 5K changes or so, should have that engine pretty clean, IMHO.
Dave
Emergency Vehicle Technician Law Enforcement
2013 Hyundai Sonata GLS 2.4
2013 Kia Optima EX 2.4
2012 Mazda3 2.0 SkyActiv
#1874736 - 04/28/10 09:08 PM Re: saab sludge [Re: Edmund]
ekpolk Offline
The Regenerator
Loc: Pensacola FL
Or you could get one of these and go exploring. A great tool (or toy, depending upon your perspective...).
09 Camry Hybrid, Black (M1 5w-20, std flavor).
07 Avalon XLS, Cassis Pearl (GC 0w-30).
04 Prius, Black (GC -- 0w-30).
#1874853 - 04/28/10 11:54 PM Re: saab sludge [Re: ekpolk]
Autobahn88 Offline
Loc: Kingston On, Canada
Being the owner of a Saab, and having owned 4, just take the valve cover off. It is a simple job. You can tell if the car has been neglected or not. If there is signs of sludge you will have no other choice but to lower the oil pan and clean it out along with the pick up screen and hope that that will be enough.
1998 BMW 528i
2008 Mazda5
2000 Land Rover Disco
#1874952 - 04/29/10 05:57 AM Re: saab sludge [Re: Autobahn88]
wolfc70 Offline
Loc: Wisconsin
There are a few things to do, first is hook up an oil pressure gauge and see what pressure you have when hot. If it is low, then the pickup screen is clogged. If your car is sludged, the best thing to do is do the oil pan modification, where a removable metal plate is put over the pickup tube so it can be cleaned without dropping the pan. The reason for this is the pickup screen is very fine and will clog easily once you start flushing the engine.
The other thing to do is put a heat shield over the catalytic converter, as it run beneath the oil pan.
Andrew's Saab calls it an accumulator oil pan.
2011 Honda Accord EX Saloon, Manual, K24Z3, Toyota Synthetic 0w-20, Napa Gold 7356
2008 Pontiac Vibe 1ZZFE, PP 5w-20, Federated LF410F
#1875821 - 04/29/10 09:43 PM Re: saab sludge [Re: wolfc70]
Dick in Falls Church Offline
Loc: Falls Church VA
There's a lot of info on this at saabnet.com
Give it a try
#1875887 - 04/29/10 10:44 PM Re: saab sludge [Re: Edmund]
hominid7 Offline
Loc: North Texas
I'd skip the engine flush and fill with Mobil1 0w40 and carefully watch the oil level and condition of the oil during the first OCI.
If it's terribly sludged you should be able to see some signs of that through the oil fill hole, unless it has one of those annoying baffles over the inside of it.
Dan W.
2001 Mazda 626 ESV6
#1875931 - 04/29/10 11:37 PM Re: saab sludge [Re: hominid7]
Paul B. Offline
Loc: Shelton, CT
The sludge problem on the vintage Saab you own is due to inadequate crankcase ventilation. During certain operating conditions this results in breakdown of the oil and subsequent sludge formation where the hottest engine surfaces exist such as oil pan near catalytic converter.
Frequent oil changes will minimize the exposure of the oil to blow by contamination and breakdown. The nature of the sludge that causes engine failures on these engines is reported as hard particles ("coffee grounds") and is unlikely to be broken down by synthetic oil changes or other oil treatments. The particles wash down and collect at the fine mesh screen on the oil pick up tube and cause oil starvation.
If you want to be 100% sure you will not have the probem drop the pan and check the pick up screen. If significant clogging of the screen is noted, install the modified oil pan with clean out port and clean it when you change the oil. If only a small amount of debris is noted, install the improved cranckcase ventilation kit (about $55 for parts) and use good quality synthetic oil changed at 5000 mile intervals.
My 2001 model has seen mostly highway miles with a strict oil change regimine and has not had the problem. I have 140,000 miles and added the improved PCV kit at about 90,000 miles.
Edited by Paul B. (04/29/10 11:39 PM)
#1875960 - 04/30/10 12:27 AM Re: saab sludge [Re: Paul B.]
Zedhed Offline
Loc: Texas, USA
Saabs are sludgers....
2006 Silverado 5.3 Crewcab PP 5w-30
Kawasaki ZG-1400 RTS 5w-40
Suzuki SV650 RTS 5w-40
Yamaha WR-250 Maxima Extra 15w-50
#1876020 - 04/30/10 05:59 AM Re: saab sludge [Re: hominid7]
wolfc70 Offline
Loc: Wisconsin
There is no oil fill hole in the valve cover, it is just a large version of the dipstick tube, it goes straight into the oil pan.
Here is a pic. The yellow cap behind the valve cover is the dip stick/oil fill.
Google Andrews saab and go to his page (Saabpros, IIRC) and seach for his NINES articles, he has done extensive work on tracking down causes and cures for the Saab engines oil issues.
#1876570 - 04/30/10 04:21 PM Re: saab sludge [Re: wolfc70]
hominid7 Offline
Loc: North Texas
That's too bad, i really like being able to see into the VC.
Thanks for the photo. Looks like the Valve Cover wouldn't be too terribly difficult to get off.
Dan W.
2001 Mazda 626 ESV6
Page 1 of 2 1 2 >
