Battery or starter
by Dallas69
08/27/16 07:56 AM
Napa Syn 15w50 to replace BradPenn 20w50 in 454bbc
by FlyNavyP3
08/27/16 07:51 AM
Real Main Seal Leak ? ? ?
by larryinnewyork
08/27/16 07:35 AM
Gov't wants to lower speed limits for trucks
by JetStar
08/27/16 07:11 AM
GM 55560202 longlife cut open - 10782km
by turboseize
08/27/16 04:54 AM
Coolant Question.
by Farmer
08/27/16 04:20 AM
Stocking up for the Eco
by buck91
08/27/16 12:25 AM
Mobil 1 10w40 HM
by SubyRoo
08/27/16 12:16 AM
What type of glue for door panels?
by Nick1994
08/27/16 12:07 AM
Painting rear of chrome bumpers
by buck91
08/26/16 11:09 PM
Walmart Rifle Clearance
by hatt
08/26/16 10:44 PM
Vehicles That Must Idle For Long Periods Of Time
by BlueOvalFitter
08/26/16 10:30 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
79 registered (AirgunSavant, 4WD, A310, 97f150, 3800Series, 2009Edge, 4 invisible), 1290 Guests and 38 Spiders online.
58935 Members
66 Forums
253614 Topics
#185747 - 04/10/06 01:37 AM STP and synthetic oil
James408 Offline
Loc: Texas
Probably a dumb question but here it goes. Can a person use stp with a synthetic oil to boost zinc?
If so how much thicker does stp make an oil. For example, does it make a 10w30 into a 40wt etc...?
#185748 - 04/10/06 01:54 AM Re: STP and synthetic oil
bruce381 Offline
Loc: Millbrae, CA
Probably
bruce
#185749 - 04/10/06 01:56 AM Re: STP and synthetic oil
Drew99GT Offline
Loc: Colorado Springs
It turns 10w-30 into what's known as motor honey [Big Grin] Why do you think you need more zinc? Do you have a flat tappet pushrod engine with a 9,000 rpm redline??? If not, then you really don't need anymore zinc.
#185750 - 04/10/06 02:20 AM Re: STP and synthetic oil
KJA426 Offline
Loc: Punxsutawney, PA.
Yes, you can use it to boost your zinc and phosphorous anti-wear agents.
#185751 - 04/10/06 02:30 AM Re: STP and synthetic oil
James408 Offline
Loc: Texas
Thanks guys. I was just curious. I was considering a synthetic oil and if they have enough zinc in them.
Actually, I run Havoline 20w50 SL in my modified Pontiac 400. I just got off the Havoline Web page it stated that this oil has 0.103 zinc in it. Is this amount suffient if I stick with a conventional oil.
I've switched between Delo 15w40 and the Havoline 20w50 a several times and my motor seemed to run better and smoother on the Havoline.
I ran Royal Purple 15w40 for a short time. With the Royal Purple my motor was very quiet and smooth. However what spooked me was the way it thinned down. Maybe it was just in my head. I'm sorry, I'm off the subject.
#185752 - 04/10/06 05:08 PM Re: STP and synthetic oil
TallPaul Offline
Loc: By Detroit
There are better products than STP for boosting zddp.
#185753 - 04/10/06 06:14 PM Re: STP and synthetic oil
James408 Offline
Loc: Texas
Thanks Paul. What other products are available? I know there's a GM additive but can't remember the name of it. Is it EOS? Does this product thicken your oil or just add zinc. I don't want any thicker oil.
#185754 - 04/10/06 08:58 PM Re: STP and synthetic oil
TallPaul Offline
Loc: By Detroit
The EOS is around 6000 ppm zinc and phosphorus so you would not need much (ounces) to boost zddp.
STP will thicken unless you can get some of the discontinued STP 6000-Mile Oil Extender.
Big Lots is selling CD-2 Street Legal High Performance Oil Boost (15 oz pink bottle) for $1.99. It has around 4500 ppm zinc and phosphorus and so half a bottle would be a pretty good boost. It is thicker but not nearly as much as STP and so should not appreciably thicken your oil.
There also is a product that some Walmarts carry called Powerservice Diesel Lube Oil Extender. There is a VOA on this site. I think around 3500 ppm zinc and phosphorus and not thick.
#185755 - 04/10/06 11:26 PM Re: STP and synthetic oil
AndyH Offline
Loc: MSP 'burbs, MN
quote:
You might want to look into SX-UP from Specialty Formulations (a BITOG site sponsor).
http://specialtyformulations.com/products.htm
quote:
SX-UP
Synthetic Multiple Anti-Wear Oil Supplement
SX-UP is a select blend of premium anti-wear (AW), extreme pressure (EP), anti-oxidant, and anti-corrosion additives in a fully synthetic carrier oil. It is designed specifically to boost the additive levels of modern SL/SM rated motor oils to meet the needs of older engine designs that require a more robust anti-wear package. SX-UP is compatible with old and new engine seals and is fully miscible in conventional or synthetic motor oils.
#185756 - 04/11/06 12:10 AM Re: STP and synthetic oil
JohnBrowning Offline
Loc: USA
The new "STP Racers Edge" product that comes in a quart sized container is much thinner then previous products. I think if anything this new product might be the best choice of a low cost additive available OTC. I think it runs $5.99 at Walmart.
If you want a really well designed additive that is not going to thicken your oil check out "SX-UP".
#185757 - 04/11/06 12:53 AM Re: STP and synthetic oil
TallPaul Offline
Loc: By Detroit
Good point JohnBrowning. I forgot that SX-UP is not thick, and certainly is a premium quality product.
#185758 - 04/12/06 02:44 AM Re: STP and synthetic oil
James408 Offline
Loc: Texas
Thanks guys I really appreciate the info. This SX-UP, can you find it in stores or do you have to order it from the above web site.
#185759 - 04/12/06 03:58 AM Re: STP and synthetic oil
TomJones76 Offline
Loc: Akron, OH
You'll need to order it. Unless I missed something, there are no retail outlets.
#185760 - 04/12/06 12:59 PM Re: STP and synthetic oil
Rand Offline
Loc: NE,Ohio
Dont be afraid to order its all top quality stuff.
I'm going to ordering a nice load for the 3 rangers in the family now...
That being said if you are worried about thickening
with something else use 15w40 and with the additive.. you got your 20w50 [Smile]
