lubriplate 1200-2
by buffalobob
07/30/16 02:49 AM
How do you politely say no to people?
by motor_oil_madman
07/30/16 12:39 AM
To change or not?
by ram_man
07/29/16 11:55 PM
Nozzle Flow Versus Pressure/Viscosity
by Shannow
07/29/16 11:20 PM
Camaro "How its Made" TV show Observations
by SumpChump
07/29/16 11:08 PM
Wondering if sitting with few quick starts degrad
by corndogzombie
07/29/16 10:51 PM
whole hog cook w/ pics
by 04SE
07/29/16 10:12 PM
redo a/c in 1994 dakota 2wd
by bmwjohn
07/29/16 09:37 PM
How to post UOA's on here?
by motor_oil_madman
07/29/16 09:34 PM
Remanns Brand Remanufactured engines
by TiredTrucker
07/29/16 09:11 PM
Best long lasting door hinges lurbicate ?
by MetalSlug
07/29/16 08:59 PM
How do you clean trunk area (not inside the trunk)
by MetalSlug
07/29/16 08:57 PM
jractk, LatitudeDancer, AKN, NickGB, Marcusd1979
58645 Registered Users
21 registered (Duke, bamorris2, Boczech, FordCapriDriver, 3 invisible), 841 Guests and 10 Spiders online.
58645 Members
66 Forums
252429 Topics
Page 1 of 2 1 2 >
#1853795 - 04/11/10 09:06 PM what happens if you run gas in a diesel engine?
sasilverbullet Offline
Loc: San Antonio, Tx
My son and I were discussing this, I didn't know exactly. I own a 02 VW bug with a diesel engine and he asked what would happen to the engine if you filled the tank with gas and drove it.
Could someone please help me answer his question?
Second question: which of the two fuels ignites easier in the engine and how does that play a role in what happens to the engine?
And a highly technical answer is fine, he's 17 and a budding genius about math/chemistry/computers...
Edited by sasilverbullet (04/11/10 09:09 PM)
14 Honda Civic 4dr EX-L - Mobil 1 Ext Perf 0W-20 & M1 Filter
14 Honda Accord 4dr EX-L 4cyl - Mobil 1 Ext Perf 0W-20 & M1 Filter
#1853820 - 04/11/10 09:25 PM Re: what happens if you run gas in a diesel engine? [Re: sasilverbullet]
defektes Offline
Loc: Hesperia, CA, USA
If I remember correctly something to do with lubrication properties of diesel in the fuel system.
2002 GMC Sierra 5sp. 4.3L 145K ST3980 E-Core
Chevron Supreme 5w-30, Amsoil Synchromesh In Tranny
Valvoline SynPower 75w-90 Gear Oil In Rear
#1853822 - 04/11/10 09:28 PM Re: what happens if you run gas in a diesel engine? [Re: defektes]
kevinf Offline
Loc: Virginia
Lots of parts in a diesel setup rely on lubrication from diesel, that they won't get from gasoline. Short term it probably wouldn't do too much damage. Diesel has more energy density than gasoline, so it will lose power. And the gasoline may not detonate on compression effectively, so it may not run at all, depending on what percentage gasoline vs diesel is in the tank.
'07 Toyota Sienna - Castrol GTX 5W30
'01 Toyota Sienna - PP 5W30
'98 Acura CL 3.0 - G-Oil 5W30
#1853826 - 04/11/10 09:31 PM Re: what happens if you run gas in a diesel engine? [Re: sasilverbullet]
gonzo Offline
Loc: millington tn.
The nozzle from a diesel pump should not be able to fit into a gas powered vehicle.
#1853836 - 04/11/10 09:38 PM Re: what happens if you run gas in a diesel engine? [Re: defektes]
SuperDave456 Offline
Loc: Dallas, Texas
Knew a person who borrowed a friend's VW in college. He filled it up with 87 octane even though it says "Diesel ONLY" just about everywhere on the car.
The car wouldn't start, someone somewhere designed a safety for this sort of thing, and once he got to thinking about things... he knew he was in deep poo poo.
Thank goodness it wouldn't start as Diesel is more difficult to ignite because it is supposed to... well... diesel.
Due to the absence of spark plugs, and if the fuel injectors still worked correctly, eventually you would get 87 octane to diesel.
Depending on how it burned it might turn over the engine, then again it might burn in such a way to bend valves or cause other damaging high pressure spikes (perhaps blow a cylinder out the bottom like nitro methane, but who knows).
BTW, Diesel is Much more lubricant like than Gasoline, so there is that aspect of cylinder wear also.
Anyways, eventually they all got together and decided that the best course of action was to disconnect the main hose that lead to the fuel injection system and drained the entire tank in the parking lot of the gas station. I think it was like 15 gallons of gas going down the drain. Refilled with Diesel and it supposedly ran fine.
BTW, this was the same set of dudes that almost burned down an Apt. complex because they didn't have a lighter and decided to use a electric element on a stove to light a cigarette. They turned the stove top element on HIGH and then proceeded to pass out due to having too much to drink. A few hours passed, I stopped by, and felt radiant heat coming from the kitchen in the back, about 25 feet away. As I approached the stove top the element was a Bright cherry red, I had to wear gloves to get to the knob the stove top was so hot. Not bright fellows to say the least.
#1853839 - 04/11/10 09:41 PM Re: what happens if you run gas in a diesel engine? [Re: SuperDave456]
DieselTech Offline
Loc: AZ
Yeah it's horrible for pumps and diesel don't run on octane but whats called cetane. The result will be horrible rattling and extreme lack of lubrication to the VERY expensive fuel system components
Diesel is harder to ignite and is ignited from compression rather then spark. Thus the very bad rattle from gas in a diesel will obviously occure.
Best advice pickup the green handle or for the shotty stations the yellow.....mobil
Edited by DieselTech (04/11/10 09:45 PM)
03 Ford F250 7.3 (Lots of Mods). Redline & baldwin 7039
07 Ford F150 fill. Penz Ultra 5-20 & Bosch 3410
99 ford F150 4.6 fill. Redline 5-30 & P1
#1853840 - 04/11/10 09:43 PM Re: what happens if you run gas in a diesel engine? [Re: DieselTech]
simple_gifts Offline
Loc: Middlesex County CT
I like the comment from "the straight dope" website
Quote:
What happens when you use gasoline in a diesel engine? Either something expensive or something very expensive.
2003 Echo >392K miles; Castrol 5W-50
2006 B2300;108K;ALM
Please conserve paper; it is not like it grows on trees.
#1853842 - 04/11/10 09:44 PM Re: what happens if you run gas in a diesel engine? [Re: SuperDave456]
doitmyself Offline
Loc: MI
Seems like the much higher compression of a diesel engine, combined with the higher volatility of gasoline, combined with the way direct injection of diesel engines works would cause a greater explosion in the cylinder, maybe at the wrong time (pre-ignition) and damage the engine catastrophically. Whew, long sentence.
Google diesel engine compression.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#1853847 - 04/11/10 09:47 PM Re: what happens if you run gas in a diesel engine? [Re: doitmyself]
DieselTech Offline
Loc: AZ
This is correct, most pumps has octane ratings of 87-93. Diesel cetane runs between 47 and 55. 55 if your extremely lucky these days
#1853861 - 04/11/10 09:59 PM Re: what happens if you run gas in a diesel engine? [Re: gonzo]
HTSS_TR Offline
Loc: Lake Forest, CA
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#1853863 - 04/11/10 10:00 PM Re: what happens if you run gas in a diesel engine? [Re: doitmyself]
FL_Rob Offline
Loc: gulf coast FL.U.S.
High cylinder pressures and temps would pre-ignite.Plus injectors at what?... 1500-1800-or 2200 PSI would cause a flame thrower effect.Luckily,diesel engine components are so strong it wouldnt have an effect.As mentioned earlier it just wont run on straight gasoline.
#1853866 - 04/11/10 10:03 PM Re: what happens if you run gas in a diesel engine? [Re: gonzo]
gonzo Offline
Loc: millington tn.
I guess I should have payed more attention to what was being talked about.Just ignore what I said earlier.Thanks for not making me look too dumb.I don't need any help with that.
#1853872 - 04/11/10 10:10 PM Re: what happens if you run gas in a diesel engine [Re: gonzo]
Seguino Offline
Loc: Vancouver BC
One of our less than stellar employees filled up the truck with Gas. An old Cummins ( 855 cubic inches ). Had to call the tow truck 5 miles down the road. Goodbye engine.
Edited by Seguino (04/11/10 10:10 PM)
#1854045 - 04/12/10 02:28 AM Re: what happens if you run gas in a diesel engine [Re: Seguino]
Kiwi_ME Offline
Loc: New Zealand
The local BP station once accidentally put gasoline in my mother's 2004 BMW diesel. She drove it around for about 15 minutes with it stumbling badly and blowing heaps of white smoke. After she returned to the station they paid for the fuel to be drained out. It seems to still drive OK, 2 years later. The problem is if the high-pressure CR pump had been damaged a new one would have cost in the region of $6K in this part of the world.
#1855144 - 04/12/10 06:46 PM Re: what happens if you run gas in a diesel engine [Re: Kiwi_ME]
Dieseldoctor Offline
Loc: tn usa
My 1991 speced u could run up to 30% gas in a diesel in winter time. I never did.. causes detonation misfiring and eventually it will burn a hole in the piston valves totally destroy the engine most likely not to mention if it has any close fitting pump parts most likely they will seize up too.
Page 1 of 2 1 2 >
