Streaks left after using leather seat wipes.
by jigen
05/24/16 07:57 AM
Poulan Pro 5020AV carburetor adjustment
by jstutz
05/24/16 07:57 AM
Winchester firearms - 15% rebate until May 30
by mjk
05/24/16 07:29 AM
Redskins name offensive
by grampi
05/24/16 07:20 AM
Rear Disk Brake Question
by NibbanaBanana
05/24/16 06:58 AM
anybody good in theorycrafting mathematic?
by yvon_la
05/24/16 06:51 AM
Aeroshell 22 v Mobil 28
by rooflessVW
05/24/16 06:36 AM
QSAD 5W20 VOA Bottled 2/25/16
by dustyroads
05/24/16 06:29 AM
What polish/wax to apply before Collinite 845
by pennzoil_guru
05/24/16 05:46 AM
Native American Advertising
by tony1679
05/24/16 05:45 AM
Akebono ProACT ceramic pads
by dlundblad
05/24/16 04:37 AM
3D printed plastic lower receiver
by Merkava_4
05/24/16 04:19 AM
WeekendWarrior, emily, lex73, showstopr30, any_user
57966 Registered Users
82 registered (AirgunSavant, ARCOgraphite, 87sammy, 2004tdigls, Andrei, abycat, 6 invisible), 1545 Guests and 114 Spiders online.
57966 Members
66 Forums
249333 Topics
Page 4 of 4 < 1 2 3 4
#1826758 - 03/22/10 10:33 AM Re: Mobil 1 0w30 2008 Chevy Cobalt 2.2L Ecotec [Re: Nyquist]
Brian Barnhart Offline
Loc: Ohio
UOA wear numbers are low, which seems fairly typical for this engine. There is probably significant fuel dilution in this engine (even though itís not apparent in the fuel number). That would seem to explain why the shearing and flashpoint are not what one would expect to see in a synthetic after only 2.7K.
The OLM for this engine probably would have gone over 8K on this OCI before reaching 0%. That seems rather long given the shearing and flashpoint numbers in this UOA report.
Based on what I see here, a dino probably would have performed just as well in this engine under these conditions.
#1826950 - 03/22/10 01:12 PM Re: Mobil 1 0w30 2008 Chevy Cobalt 2.2L Ecotec [Re: Brian Barnhart]
21Rouge Offline
Loc: Vinegar Hill
But might there be reasons to think that a synthetic oil performs better (than a dino) in the presence of fuel? i.e. better resists shearing or even with comparable shearing still protects the engine better?
#1826987 - 03/22/10 01:39 PM Re: Mobil 1 0w30 2008 Chevy Cobalt 2.2L Ecotec [Re: 21Rouge]
Loc: Ohio
I didn't spend much time looking at other Ecotec results, but from what I've seen, the evidence doesn't seem to support the idea that synthetic (or at least this particular synthetic) performs better than a dino in this application. Both shearing and flashpoint have degraded significantly and rather quickly. Vis and FP for this oil are no better than this dino in another Ecotec with nearly twice the OCI. Plus, the M1 started out thicker and synthetics usually have greater initial flashpoints.
#1827108 - 03/22/10 03:21 PM Re: Mobil 1 0w30 2008 Chevy Cobalt 2.2L Ecotec [Re: kender]
TomYoung Offline
Loc: New Jersey
Every 1,700 miles roughly? Sure hope you are using one of the high-end synthetic oils:)
#1827116 - 03/22/10 03:30 PM Re: Mobil 1 0w30 2008 Chevy Cobalt 2.2L Ecotec [Re: ARCOgraphite]
TomYoung Offline
Loc: New Jersey
Originally Posted By: ARCOgraphite
Start up noise, hot running noise, rough running and tappet noise and car wouldnt rev over 4K rpm which is indicative of insufficent hot viscosity. The VVTi is very sensitive - Toyota 1nzfe ECU require a re-flash if you run 20w oils. As soon as I did the OC car ran perfect (after a couple days babying it during the add pack changeover).
Are you saying that the engine would not rev past 4k due to the oil degradation.... I don't think so.
#1827294 - 03/22/10 06:07 PM Re: Mobil 1 0w30 2008 Chevy Cobalt 2.2L Ecotec [Re: TomYoung]
JAG Offline
Loc: Fredericksburg, VA
3 comments below are in response to some other posters' comments.
1) Part of what makes this an "Advanced Fuel Economy" oil for an XW-30 oil is the initially low HTHS viscosity (2.99 cP) and the poor shear stability, making the used oil HTHS drop significantly further.
2) Viscosity loss from mechanical shearing happens very quickly and stabilizes as more and more of the polymeric viscosity index improved get broken, since they become harder to break the smaller they are. By 2700 miles, most of the mechanical shearing is complete.
3) Used motor oil flashpoint is dominated by the amount of fuel so the virgin oil's flashpoint doesn't factor in.
Wear looks fine. This engine appears to be a breeze on oil.
#1841334 - 04/01/10 04:12 PM Re: Mobil 1 0w30 2008 Chevy Cobalt 2.2L Ecotec [Re: TomYoung]
sbergman27 Offline
Loc: Oklahoma
What he's implying is that the oil had sheared to such a low viscosity that the vvt-i actuator couldn't function, leaving the valve timing in the fully retarded setting.
I don't believe that for a moment, of course. (And would love to see an independent reference to this supposed "known problem".) But that's what he's saying.
Toyota issued a TSB for his (an my) engine OK'ing use of 5w20 in them back in 2006, which didn't mention anything at all about vvt-i problems or an ECU reflash. So that should settle that.
-Steve
Edited by sbergman27 (04/01/10 04:16 PM)
#1843173 - 04/02/10 11:58 PM Re: Mobil 1 0w30 2008 Chevy Cobalt 2.2L Ecotec [Re: addyguy]
chet2 Offline
Loc: NH
so oil couldve gone 8k according to OLM even in nasty weather... i used to change my oil every 3-4k or so till i knew how long oil could really go...now i go at least 6k and that is conservative
#1843174 - 04/02/10 11:59 PM Re: Mobil 1 0w30 2008 Chevy Cobalt 2.2L Ecotec [Re: chet2]
chet2 Offline
Loc: NH
how was mpg on the 0-30?...i have a ecotec too
#1844423 - 04/04/10 08:06 AM Re: Mobil 1 0w30 2008 Chevy Cobalt 2.2L Ecotec [Re: Nyquist]
fdcg27 Offline
Loc: OH
Wear looks pretty good.
It would be interesting to see a UOA of a longer run with this oil, which would settle the question of whether you reached a point where shear stability had been reached, or whether shearing would continue in a linear fashion.
I put this oil in a friend's G5 2.2.
My logic was that the oil should be just fine down to 0% OLM and beyond, while delivering good cold-weather performance, and enough fuel economy improvement to cover its cost ($12.00 after MIR).
I also thought that the low HTHS was just fine for this engine, since it cannot impose the kind of loads and heat that would require a higher HTHS, and HTHS was apparently not something GM found necessary to account for in their OLM logic.
I currently have this oil in my '99 Accord as well.
Also used it as a winter fill the previous year.
I have a third jug for next winter, all of it cheap after MIR.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
