Painting rear of chrome bumpers
by buck91
08/26/16 11:09 PM
Walmart Rifle Clearance
by hatt
08/26/16 10:44 PM
Vehicles That Must Idle For Long Periods Of Time
by BlueOvalFitter
08/26/16 10:30 PM
2013 Taurus SHO Ecoboost
by SHO
08/26/16 10:11 PM
Need recommendation
by double vanos
08/26/16 10:00 PM
Kawasaki must be completely full of gas to start
by jrcowboys
08/26/16 09:36 PM
Un-Screwing
by Ducked
08/26/16 09:05 PM
BG 109 vs 120, any techs experienced w/ both?
by dccode
08/26/16 08:24 PM
Harder on engine, idling or restart?
by mattri
08/26/16 08:20 PM
Solvent/cleaner + 2 stroke oil for piston soak
by OldEuroCarLover
08/26/16 08:09 PM
Costco Canada Michelin wiper blades $9.99
by JC1
08/26/16 06:47 PM
Havoline Car Giveaway
by SatinSilver
08/26/16 06:47 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
68 registered (andrewp1998, 2004tdigls, AZjeff, ammolab, Americana, AirgunSavant, 4 invisible), 1066 Guests and 31 Spiders online.
58935 Members
66 Forums
253605 Topics
Page 1 of 6 1 2 3 4 5 6 >
#1825247 - 03/21/10 01:00 AM Does premium unleaded burn hotter than regular
RTBandit Offline
Loc: California
Just curious - Does 91 octane gas create a hotter explosion than 87 octane? All input is appreciated.
#1825254 - 03/21/10 01:04 AM Re: Does premium unleaded burn hotter than regular [Re: RTBandit]
daves66nova Offline
Loc: los angeles
The numbers are just ratings for the level of resistance to detonation,it is not an indicator of "performance"
THIS SPACE FOR RENT, PLEASE PM ME.
#1825260 - 03/21/10 01:14 AM Re: Does premium unleaded burn hotter than regular [Re: daves66nova]
Colt45ws Offline
Loc: Central Washington
Quoted for truth. Octane is associated with performance because high performance engines have designs that require higher octane. Turbocharging, supercharging, high compression are all reasons that an engine has more performance, they are also reasons they need high octane so they don't have pre-ignition. Pre-ignition can rattle an engine apart and/or burn holes in places they shouldnt be.
Edited by Onmo'Eegusee (03/21/10 01:14 AM)
-Colton
2002 Ford Crown Vic PI, 187k "Highwayman"
Ex-Kootenai County, ID Unit #42
Maxlife 5W20
Lubegard Bio/Tech oil treatment
Ultra XG2
#1825266 - 03/21/10 01:23 AM Re: Does premium unleaded burn hotter than regular [Re: Colt45ws]
RTBandit Offline
Loc: California
My question is about temperature not performance.
#1825268 - 03/21/10 01:33 AM Re: Does premium unleaded burn hotter than regular [Re: RTBandit]
expat Offline
Loc: Canada
By and large,NO.
ANY substance added to the gas that helps prevent, or delays preignition with give the Gasoline a higher octane rating.
For may years a type of Lead compound was used, Methanol and Ethanol will also serve to raise the octane rating. But they will not cause the fuel to burn hotter.
#1825270 - 03/21/10 01:34 AM Re: Does premium unleaded burn hotter than regular [Re: RTBandit]
Shannow Online   content
Loc: Oz
Nope, not hotter, faster, slower, or any of the things that our local mower repair man keeps telling my co-workers.
It is merely more resistant to self igniting in the presence of pressure, temperature, and hot spots.
It used to (often) have a lower energy content, but modern refining has made high density high octane fuels.
2003 Navara 3.0Di - Edge 5W30/25W50
1997 Caprice L67 - Magnatec Stop Start 10W30
#1825272 - 03/21/10 01:35 AM Re: Does premium unleaded burn hotter than regular [Re: RTBandit]
expat Offline
Loc: Canada
It's not an explosion, it's a burn.
Or it should be!
#1825273 - 03/21/10 01:36 AM Re: Does premium unleaded burn hotter than regular [Re: RTBandit]
Trajan Offline
Loc: SE PA
Octane rating does not relate to the energy content of the fuel. It doesn't burn any hotter.
Lack of harm is not proof of benefit.
There are in fact two things, science and opinion; the former begets knowledge, the later ignorance. Hippocrates
#1825331 - 03/21/10 06:27 AM Re: Does premium unleaded burn hotter than regular [Re: Trajan]
Boomer Offline
Loc: Pennsylvania
Some cars had warnings years ago on running high octane fuels as they were set to use regular. The reason given was burning exhaust valves. This was not due to higher temps but to a slightly longer burn time that produced a hotter exhaust gas that caused the exhaust valve to run hotter. My wife's Saturn has a warning like this in the owner's manual and I think Buick may have had it as well.
2013 VW Passat TDI SE, 33,300 miles
2014 VW Jetta TDI SportWagen 18,055 miles
#1825352 - 03/21/10 07:04 AM Re: Does premium unleaded burn hotter than regular [Re: Boomer]
Bluestream Offline
Loc: Waterloo, ON
It burns slower, so my guess is it would be cooler
2000 Cavalier 2.2 A4
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#1825375 - 03/21/10 07:48 AM Re: Does premium unleaded burn hotter than regular [Re: Bluestream]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Is this on a bet? Having a Molotov Cocktail? If you want more energy out of a cylinder burn you have to add MORE fuel and MORE air. Or Nitrous (air) and more fuel. Not enough air will make the burn too hot.
2014 Nissan Rogue S CVT, OC#4 19671mi-Castrol EDGE EP 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#1825381 - 03/21/10 08:00 AM Re: Does premium unleaded burn hotter than regular [Re: RTBandit]
zulu Offline
Loc: Kansas
Not hotter, just slower.
09 Silverado 5.3 -> M1 5W-30/AC Delco PF48
12 Civic Si 2.4 -> Honda (CP Blend) 0W-20/Honda A02
#1825383 - 03/21/10 08:02 AM Re: Does premium unleaded burn hotter than regular [Re: ARCOgraphite]
cjhepburn Offline
Loc: Boston
I don't know if it burns hotter but it burns slower. That's why you need to adjust the timing on older cars to not ping on lower octane fuels.
'08 Civic LX, M1 EP 5w-20, 10000 OCI - 98k.
'03 Forester XRS, GC 0w-30, 5000 OCI - 78k
#1825384 - 03/21/10 08:03 AM Re: Does premium unleaded burn hotter than regular [Re: Bluestream]
Jax_RX8 Offline
Loc: Northern VA, USA
This is a mistake many people think - just because it is less prone to pre-ignite, through additives, does NOT mean it burns slower.
Once ignited, Premium burns at basically the same rate as Regular.
Edited by Jax_RX8 (03/21/10 08:04 AM)
#1825405 - 03/21/10 08:40 AM Re: Does premium unleaded burn hotter than regular [Re: Jax_RX8]
mikered30 Offline
Loc: PA
So running 93 octane in an engine that calls for 87 will not lead to increased carbon build up compared to running 87 all the time?
