Mobil 1 Full Synthetic $3.99 AR Menards
by John_K
08/25/16 10:32 PM
Causes of steering wheel shudder
by buck91
08/25/16 10:14 PM
Brand new Focus ST...
by Striker
08/25/16 09:55 PM
Chevy Volt bad idea for BITOG members!
by kohnen
08/25/16 09:22 PM
Looking for oil suggestion Chevy Express 3500 6.0L
by Goofball1205
08/25/16 08:38 PM
What ATF? 2004 Toyota Sequoia 4WD
by ShadowSix
08/25/16 08:35 PM
Tundra steering wheel
by RN89
08/25/16 08:11 PM
98-02 Corolla and Oil Consumption
by mmorri16
08/25/16 08:10 PM
How does fuel dilution affect HTHS viscosity?
by HKPolice
08/25/16 07:58 PM
Volkswagen bets big on EV(Electric Vehicle)
by HTSS_TR
08/25/16 07:50 PM
Did I goof?
by mv6845
08/25/16 07:33 PM
Opinions on Indestro tools?
by Vern_in_IL
08/25/16 07:25 PM
sledhead1, AtillatheHunk, Goofball1205, Djlmedic, BigHoss256
58926 Registered Users
41 registered (cb4017, BrocLuno, Chris142, BrownParticles, bbhero, bdcardinal, 4 invisible), 1043 Guests and 23 Spiders online.
58926 Members
66 Forums
253566 Topics
Page 1 of 6 1 2 3 4 5 6 >
#1814632 - 03/12/10 02:28 PM Motorcraft Filter Specifications
roushstage2 Offline
Loc: Northern California
OK. I know where I need to go at Ford to get the exact specs, so I will have to work on that now. I know the exact catalog and the page even. That and some more information was possible due to a very nice and informative gentleman at Purolator talking with me for about 15 minutes on the phone today. Purolator has been nothing but stellar in their communication and service with me about all of this! Kudos!
I'm reposting the information I found about the FL1A to help clarify what I'm about to type:
Quote:
FL1A
Oil Filter Style Canister
Height (in) 5.190 in.
Outside Diameter (in) 3.780 in.
Filter Bypass Relief Valve Yes
Relief Valve Open (psi) 11-14 psi
Anti-Drainback Valve Yes
Smallest Particle Filtered 20 microns
Maximum Burst Pressure (psi) 200 psi
Thread Size 3/4-16 in.
Gasket Outside Diameter (in) 2.800 in.
Gasket Inside Diameter (in) 2.422 in.
Gasket Thickness (in) 0.203 in.
Some brief, overall facts about the Motorcraft gasoline engine oil filters:
The ratings such as the filtering efficiency (80% at 20 microns) and the 200psi burst pressure are simply the absolute minimum that Ford will allow.
Taking the FL1A as an example:
  • The actual filtering efficiency should be ~93% at 20 microns.
  • The canister can also actually withstand a burst pressure of somewhere about/up to ~280psi.
  • The holding capacity should be ~12g.
  • The Motorcraft filters are somewhere in between a Purolator Classic and a PureOne.
  • The "S" type filters, such as the FL-820S, are like the PureOne filters in that they both have a silicone ADBV.
  • The "non-S" type filters, such as the FL1A, are like the Classic in that they do not have a silicone ADBV (providing the equivalent Motorcraft filter model has one).
  • The Purolator filters have a dome-end bypass valve vs. the Ford-spec'd...end? bypass valve (the correct name is slipping me at the moment).
2003 Dodge Neon SE: PP 5W20, Fram Xtended Guard
2002 Roush Mustang Stage 2: Amsoil SSO, Amsoil EaO
1986 Ford F150 XL 4x4: SuperTech 30, SuperTech ST8A
#1814680 - 03/12/10 03:03 PM Re: Motorcraft Filter Specifications [Re: roushstage2]
postjeeprcr Offline
Loc: USA
Thread end or base end, either term has been used
If I agreed with you, we'd both be wrong.
#1814684 - 03/12/10 03:07 PM Re: Motorcraft Filter Specifications [Re: roushstage2]
AuthorEditor Offline
Loc: New York
On Purolator's Web site they list the Classic at 97.5% at 20 microns and the PureOne at 99.9%, so Motorcrafts are less efficient.
#1814696 - 03/12/10 03:17 PM Re: Motorcraft Filter Specifications [Re: roushstage2]
mechanicx Offline
Loc: Ohio
This is good info. I had suspected that the 80% efficency at 20 microns was the minimum spec not the actual spec. The 12 grams of holding capacity is pretty impressive. That is close to P1 but I'd think filter size would be a factor.
I tend to look at the MC filter as being the equal to the Purolator classic and then some. A better bypass and sometimes a silicone drainback all for about the same price as the Purolator Classic. If you have a Ford or an application that MC fits I think it'd be the filter to use.
#1814783 - 03/12/10 04:33 PM Re: Motorcraft Filter Specifications [Re: roushstage2]
SuperBusa Offline
Loc: WA
Where did you find these specs? Link? I've tried to get Motorcraft filter specs directly from Ford and the Motorcraft Division and they could tell me nothing whatsoever.
In terms of what spec?
Beta 1000
Condition 0
#1815202 - 03/12/10 10:06 PM Re: Motorcraft Filter Specifications [Re: mechanicx]
postjeeprcr Offline
Loc: USA
The 13 grams of holding capacity for Purolator PureOne is for the PL30001 filter.
#1815282 - 03/12/10 11:43 PM Re: Motorcraft Filter Specifications [Re: SuperBusa]
roushstage2 Offline
I found those specs online.
As far as "in terms of what spec," I don't know that all specs would be exactly in between necessarily. That was just a simple way I suppose to show how they are related to the Purolator filters over the phone. :)
#1815293 - 03/13/10 12:08 AM Re: Motorcraft Filter Specifications [Re: roushstage2]
roushstage2 Offline
OK. Here it is folks. These are from 2005, so they are not the most up to date, BUT, should be more than anyone has seen here to date according to responses I have seen and from what I've been told. These are the ratings for all Motorcraft filters, information circa 2005. Enjoy!! :D
If there would be a better place for all of these, let me know and I'll make a specific "Motorcraft Filter Spec" thread. I will still try and find 2009 spec sheets if possible for updated information, which I know there is. :)
#1815302 - 03/13/10 12:29 AM Re: Motorcraft Filter Specifications [Re: roushstage2]
SuperBusa Offline
Loc: WA
I really don't see where the specs shown above say that the 80% efficiency @ 20 microns is the absolute minimum that Ford allows. To me, it says the efficiency IS 80% @ 20 microns.
And the note at the bottom of the chart makes me wonder if this data was actually from Ford. The note says "Efficiency rating is not called out in the Ford Testing specification." If it wasn't called out in the testing spec, then were did those efficiency numbers come from?
Like I said earlier, I contacted Ford's Motorcraft Dept and asked if they had data like this and they said "No".
Beta 1000
Condition 0
#1815335 - 03/13/10 01:24 AM Re: Motorcraft Filter Specifications [Re: SuperBusa]
roushstage2 Offline
Purolator, the manufacturer of the Motorcraft filters, said that the rating is the minimum; not the actual.
I can guarantee the data is from Ford because I pulled it from their catalogs.
I've contacted Motorcraft too and was told "no." They are not the ones that carry this data, per them and FoMoCo.
#1815339 - 03/13/10 01:30 AM Re: Motorcraft Filter Specifications [Re: roushstage2]
SuperBusa Offline
Loc: WA
The way the data is presented is misleading then. If Purolator knows what the real efficiency is for each of those Motorcraft filters they manufacture, then why don't they (whoever generated this date - FoMoCo with Purolator data ??) just advertise the actual efficiency? Showing some mystical supposed minimum efficiency of "80% @ 20" microns (with no notes to show that intention) doesn't get too many points from the people who understand filter efficiency.
Beta 1000
Condition 0
#1815341 - 03/13/10 01:32 AM Re: Motorcraft Filter Specifications [Re: SuperBusa]
roushstage2 Offline
Good question. One to propose to Ford since they create the data. I'm just passing along what I have found since people asked. :)
#1815471 - 03/13/10 07:31 AM Re: Motorcraft Filter Specifications [Re: SuperBusa]
Sayjac Offline
Loc: The Old North State
That is some good information. With one/two exceptions, the FL 820S is all my son has run on his 4.6L Explorer. I still have one cut open from his last OC. It is a very well made filter, and to look at it as comapared to others dissected, it doesn't look to be 80% @20mu.
The rating, lowballed or otherwise, might keep some from choosing the Motorcraft over others. At ~$3.64 at Wally it is a good price.
But, based on it's overall construction, the rating is somewhat of a paradox.
#1815477 - 03/13/10 07:37 AM Re: Motorcraft Filter Specifications [Re: Sayjac]
Colt45ws Offline
Loc: Central Washington
You cant really eyeball efficiency.
-Colton
2002 Ford Crown Vic PI, 187k "Highwayman"
Ex-Kootenai County, ID Unit #42
Maxlife 5W20
Lubegard Bio/Tech oil treatment
Ultra XG2
#1815512 - 03/13/10 08:13 AM Re: Motorcraft Filter Specifications [Re: Colt45ws]
Sayjac Offline
True that. As I said, my comments were based on other dissected filters either posted here or by myself, which has been substantial. So, that would include things like media amount, length and type.
I now wish that I had sent river_rat an FL 820S, but he did cut open and test a Motorcraft FL-1A against a Donaldson and P1 here (scroll). Now, while it didn't test as well it those quality filters, it did hold it's own. IIRC, even r_r felt, based on his testing, that the Motorcraft was closer to a Puro Classic in results. In other words, not the rated 80%.
In any case, if you look at the MC Fl-1A construction in the link, as previously said, the rating doesn't seem to align with it's overall quality construction.
