I can't figure out how to link the results over, so i'll type them out i guess.
Oil filter--OEM for whole duration
Oil--ASL 5w30 with no makeup oil added
Driving--80 city/20 hiway
32,100 miles on unit
Air filter--K&N
Lab# 494054---SLC, Utah----OAI
Overall severity of report is 4 which is critical for low TBN.
Comments: Base number is essentially depleted. Abrasives (silicon/dirt) are at a MINOR LEVEL; flagged additive levels are lower than expected for the lubricant that is identified. This does not imply that the lubricant does not meet proper API, SAE OR ISO classifications. Lubricant and filter change acknowledged; Change oil and filters if not done when oil sample was taken.
WEAR METALS--PPM
IRON------20
CHROMIUM--0
NICKEL----0
ALUMINUM--7
COPPER----3
LEAD------2
TIN-------0
CADMIUM---0
SILVER----0
VANADIUM--0
CONTAMINANT METALS--PPM
SILICON---30--Flagged
SODIUM----7
POTASSIUM-0
MULTI SOURCE METALS--PPM
TITANIUM--0
MOLY------59
ANTIMONY--1
MANGANESE-0
LITHIUM---0
BORON-----46--Flagged as abnormal
ADDITIVE METALS--PPM
MAGNESIUM--14
CALCIUM----3682
BARIUM-----1
PHOSPHO----721
ZINC-------899
FUEL-------- SOOT-------- WATER------- VISC-100CCS--11.3
TBN----------1.88---Flagged for critical
I-R OXID----41
I-R NITRA---27
Is it the silicon that beat up the oil so bad, or what?
Any ideas or comments on this would be much appreciated.
Thanks
Air filter--K&N
WEAR METALS--PPM
IRON------20
CHROMIUM--0
NICKEL----0
ALUMINUM--7
COPPER----3
LEAD------2
TIN-------0
CADMIUM---0
SILVER----0
VANADIUM--0
SODIUM----7
POTASSIUM-0
TITANIUM--0
MOLY------59
ANTIMONY--1
MANGANESE-0
LITHIUM---0
MAGNESIUM--14
CALCIUM----3682
BARIUM-----1
PHOSPHO----721
ZINC-------899
I-R OXID----41
I-R NITRA---27
Thanks
