Originally Posted By: XS650
Originally Posted By: labman
Equal numbers of molecules in any gas take up the same space. 22.4 liters of any gas, or mixture contain 6.22 x 10^23 molecules.
Only at STP (Standard Temperature and Pressure), you know that, but not all the spectators do.
Good point. Thank you for the friendly correction.
Yes Steve S, a whole lot of pushing and shoving going on. First the hot gases push the piston and crank shaft journal down, then when the exhaust valve opens, they flow out it with a shove from the piston. The smaller area works because the pressure is higher.
