Abnormal Styling ?
by HTSS_TR
05/06/16 07:22 PM
It's that time again.... Ford front-end stuff
by OVERKILL
05/06/16 07:03 PM
Addicts using anti-diarrhea medication to get high
by Mr Nice
05/06/16 06:36 PM
PureOne PL24011 cut open
by AuthorEditor
05/06/16 06:21 PM
Hidden gem for ex-K&N Filter users
by Reddy45
05/06/16 05:54 PM
Chemical Guys Car Wash 1 Gal $13 Amazon
by gallydif
05/06/16 05:43 PM
2006 Charger - rack getting replaced
by OVERKILL
05/06/16 05:38 PM
A Story Worth Living
by LoneRanger
05/06/16 05:37 PM
Snake Oil Detergent - 0.37 Cents
by Greg L
05/06/16 04:35 PM
Wax for silver car
by 007
05/06/16 04:32 PM
Trump's empty picture frames
by SumpChump
05/06/16 04:05 PM
Is 0w40 slightly Thicker than 5w30?
by Greg L
05/06/16 03:53 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
86 registered (aquariuscsm, Astro_Guy, 2015_PSD, Al, 137_Trenton, 9 invisible), 0 Guests and 1 Spider online.
57814 Members
66 Forums
248563 Topics
Page 1 of 2 1 2 >
#1798894 - 02/28/10 09:11 PM Hyper-Lube oil additive
Durango Offline
Loc: Los Angeles, California
Hey guys/gals,
Ever use it????? Comes in a small clear bottle that looks just like water.
Durango
#1798903 - 02/28/10 09:23 PM Re: Hyper-Lube oil additive [Re: Durango]
postjeeprcr Offline
Loc: USA
Are you talking about the Hy-per Lube ZRA Additive? Their oil supplement is not clear. I have not used the ZRA but according to the label is has esters which is interesting. A guy at a local auto parts store told me it is good stuff, they got some in I guess and sold out of it....lol
If I agreed with you, we'd both be wrong.
#1799327 - 03/01/10 09:31 AM Re: Hyper-Lube oil additive [Re: postjeeprcr]
Durango Offline
postjeeprcr,
No this stuff is clear liquid in a small bottle.
Just wondering.
Durango
#1799725 - 03/01/10 03:30 PM Re: Hyper-Lube oil additive [Re: Durango]
axjohn Offline
Loc: SoCal
I used a product called Hyper-Lube when I lived in Columbus, Ohio in the eighties and nineties. The product claims to have--at least the one I used claime to have--jojoba oil in it.
There were a couple of formulas available, one "regular" and one "premium" (the Premium cost a buck more per quart). Bought the product at Meirs (Meyers?) in Dublin, Ohio.
It sure SEEMED to work in my 4-banger 1988 Acura integra. I used it in the manual transmission (shifted smooth as silk after that) and a little less than a quart in the oil. Like I seem, engine was smoother, and it sure seemed like I got a little better acceleration.
Supposedly, jojoba oil is pretty slippery. Maybe one of the resident tribologists can chime in on it's chemistry.
Maybe using it in the oil helped balance the compression between cylinders so it SEEMED more powerful. I know it was definitely smoother, quieter, and shifted slicker than (fill in the blank), even in below zero weather.
#1799898 - 03/01/10 05:30 PM Re: Hyper-Lube oil additive [Re: Durango]
dailydriver Offline
Loc: Bucks County, Pa.
Originally Posted By: Durango
postjeeprcr,
Just wondering.
Durango
That's what post was saying, that this stuff (Hy-Per Lube Zinc Replacement Additive) is the ONLY clear Hy-per Lube product in a small bottle.
It does sound interesting. I just read on their site that it contains NO ZDDP at all! (I thought it was just another ZDDP additive, like Red Line's/RP's/etc. when I'd seen it on Pep Boys' shelf.)
I'm going to call their tech dept. and see if they'll tell me whats in it (and not just cop-out with the tired, old standard, "proprietary info" response) besides said esters.
Boron, maybe???
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#1800400 - 03/02/10 03:22 AM Re: Hyper-Lube oil additive [Re: dailydriver]
postjeeprcr Offline
Loc: USA
postjeeprcr,
Just wondering.
Durango
Boron, maybe???
Let us know what you find out.
#1801167 - 03/02/10 06:56 PM Re: Hyper-Lube oil additive [Re: postjeeprcr]
dailydriver Offline
The tech called back today, and said that this stuff contains NO; ZDDP (we already knew that), moly (in ANY form), boron, antimony, calcium, or any other 'typical' anti-wear, anti-corrosion type elements/compounds.
He stated that it was just pure friction reducing, anti-wear esters (he did not, nor would not say what type of esters), made to act as (and take the place of) the above sacrificial elements (especially ZDDP for older flat tappet designs) would.
I wonder if it is the same esters as in the Lube Gard engine oil supplement??
M1-206 oil filter
#1801471 - 03/02/10 10:07 PM Re: Hyper-Lube oil additive [Re: dailydriver]
axjohn Offline
Loc: SoCal
I wonder if jojoba oil contains, or can be, "esterized" to produce a low friction additive. I clearly remember seeing jojoba oil mentioned on the hyperlube products i used.
They also showed a with and without comparative horsepower comparison over the idle to 7 or 8k rpm range, with a clear advantage throughout the rpm range for the addition of the hyperlube. IIRC, the standard product showed about a 4 hp consistent gain throughout the range, and the premium product showed a 7 or 8 hp gain throughout that same range. And this for a 4 cylinder engine of about 2 liters or so.
This was 20 years ago, so I don't have an empty container to post a piture of ("BAD BITOGER, no photo!).
Probably hyperlube.com or something of the sort.
Maybe dailydriver could follow-up with the tech dept to inquire about the possible jojoba connection. I know the product clearly made a difference in my 1988 Acura Integra 5sp.
#1802904 - 03/04/10 12:03 AM Re: Hyper-Lube oil additive [Re: axjohn]
postjeeprcr Offline
Loc: USA
I have talked briefly to Molakule about this product and he said they are olefin copolymer esters. I mixed some stuff in a bottle and it did something I had never seen before, so I sent him a pic. I do not know this but I would think it is different esters then in LubeGard.
Also the jojoba is in the "racing" version of the supplement which from labels seems exactly like the regular stuff except for the jojoba.
#1804266 - 03/04/10 10:28 PM Re: Hyper-Lube oil additive [Re: postjeeprcr]
axjohn Offline
Loc: SoCal
"I mixed some stuff in a bottle and it did something I had never seen before, so I sent him a pic."
So what exactly did this stuff do that surprised you so much that you took a picture and sent it to Molakule? Like I said, I've used it, and felt it was worth it, so I'd be interested in what you have to say on this!
Thanks.
#1815257 - 03/12/10 11:16 PM Re: Hyper-Lube oil additive [Re: axjohn]
axjohn Offline
Loc: SoCal
Still no answer?
Found pictures of the product I used via google. Also found the MSDS:
http://www.hyperlube.com/documents/MSDSHPL302.pdf
Can you elucidate on your comments, postjeeprcr, unless the conversation between you and Molakule was private and not for forum consumption?
Thanks,
#1815333 - 03/13/10 01:23 AM Re: Hyper-Lube oil additive [Re: axjohn]
postjeeprcr Offline
Loc: USA
Thanks.
Was the stuff you used the Racing Supplement or was it the ZRA stuff? The stuff that surprised me was the ZRA, and it was informative why it congealed, lack of dispersants in the additive and what I mixed it with. I will have to look for the pic, when I find it I will show you.
#1834920 - 03/28/10 12:38 PM Re: Hyper-Lube oil additive [Re: postjeeprcr]
ARCOgraphite Offline
Loc: N.H, U.S.A.
I just saw the ZRA at pep boys when looking for MT gear lube. It was crystal clear/transparent in a clear bottle with a big ZINC on the label (and a small replacement under the zinc) and said on the back it contained polymer esters and NO converter damaging additives. I think it also said it could show 4x less cam wear than traditionl ZDDP additives. I think it was 15 bucks a pint or less $$$.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#5 31478mi-PEAK 0W20+Subaru Filter
#1834936 - 03/28/10 12:54 PM Re: Hyper-Lube oil additive [Re: ARCOgraphite]
Loc: N.H, U.S.A.
HY-perlube ZRA AD
Edited by ARCOgraphite (03/28/10 12:56 PM)
#1835156 - 03/28/10 03:29 PM Re: Hyper-Lube oil additive [Re: ARCOgraphite]
dailydriver Offline
Yes, that's what we are talking about. ^^^
Just waiting on post's pics to see the funny reaction this stuff had in solution (even though the label claims it is miscible/compatable with EVERYTHING out there (including other ester based synthetic oils).
M1-206 oil filter
Page 1 of 2 1 2 >
