Honda GX35 question
by dirtydannyd
07/25/16 02:08 AM
Need advices for oil filter inspection
by ST2008
07/25/16 01:45 AM
Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
07/25/16 01:06 AM
Clean battery with garden hose?
by SavagePatch
07/24/16 11:55 PM
Toyota 5w20 blend?
by researcher
07/24/16 11:36 PM
Smoked some baby backs today
by BeerCan
07/24/16 10:28 PM
Ford FWD axle replacement
by 2009Edge
07/24/16 10:27 PM
Saturn ac compressor
by spasm3
07/24/16 10:20 PM
looking for spray guns - analysis paralysis
by tomcat27
07/24/16 10:18 PM
WIX 51372 ADBV Failure
by WellOiled
07/24/16 10:11 PM
moly + engine coatings
by benjy
07/24/16 09:57 PM
Worth the upgrade?
by daves87rs
07/24/16 09:47 PM
NJ1911, SneakyTacos, DaveD, 8o8is, Texasdude74
58584 Registered Users
29 registered (alcyon, 1foxracing, car51, 182RG, 8o8is, 6 invisible), 811 Guests and 17 Spiders online.
58584 Members
66 Forums
252221 Topics
#1784063 - 02/16/10 05:28 PM Power Steering Fluid for 2005 Toyota Echo
51Plymouth Offline
Loc: Southwestern Ontario, Canada
My girlfriend has a 2005 Toyota Echo 130,000km. As far as I know, it still has the original power steering fluid. The dealership wanted to flush it at about 80,000km but I told my girlfriend not to since I could do it myself. Interestingly, they did not offer to flush the transmission. I would think for the average car owner that a transmission flush (or preferably change with filter and magnet cleaning) would be more productive than the power steering fluid. I changed the ATF later myself, good thing.
If they think the Type T-IV in the transmission never needs changing in this car, shouldn't the power steering fluid last even longer?
The dealership probably only wanted to flush the power steering since it is simple with almost no risk and they make a lot of markup on it.
Anyways, according to the owner's manual, and I think on the power steering cap, it states use Dexron type fluid. Well, the fluid in the car is quite clear and light tan, just like regular power steering fluid. Obviously I don't want to mix fluids. WHAT kind of factory fill is in there exactly?
To change the PSF myself I was planning on disconnecting the return hose while I fill the reservoir, with the car running.
#1784071 - 02/16/10 05:36 PM Re: Power Steering Fluid for 2005 Toyota Echo [Re: 51Plymouth]
simple_gifts Offline
Loc: Middlesex County CT
Sounds like a plan to flush....
I just extracted some fluid from the reservoir and refilled. Did this a few times over the next few weeks. Probably not as thorough as your method.
Not sure what is in there @ the factory. I refilled with Redline D4. Redline also makes a PSF.
A brake fluid exchange also might be in order.
2003 Echo >392K miles; Castrol 5W-50
2006 B2300;108K;ALM
Please conserve paper; it is not like it grows on trees.
#1784073 - 02/16/10 05:40 PM Re: Power Steering Fluid for 2005 Toyota Echo [Re: simple_gifts]
wiswind Offline
Loc: Wisconsin
Use a ATF that meets the Dexron III specification.
Many use Mobil 1 for the advantages of synthetic.....better cold flow and better heat tolerance.
The RED color of ATF is a dye.......and the clear stuff in the Toytota power steering is simply ATF without the dye.
My 2003 Sienna calls for Dexron III for the power steering and the transmission.
I plan to use Redline D4 in both.
#1784228 - 02/16/10 07:38 PM Re: Power Steering Fluid for 2005 Toyota Echo [Re: wiswind]
JHZR2 Offline
Loc: New Jersey
Our 94 previa takes ATF in the ps. I use pennzoil, and it is foment. I have tried different atfs in my BMW, and M1 is the best I've tried.
For the tan stuff, go to an MB dealer - their psf for 1980s diesels is an undyed dexron ATF. It is maybe $4/qt.
#1784570 - 02/17/10 01:40 AM Re: Power Steering Fluid for 2005 Toyota Echo [Re: JHZR2]
3Toyotas Offline
Loc: UT, USA
No problem mixing fluids, as long as it's Dex III ATF compatible.
I've drained and refilled all our toyota vehicles using Amsoil ATF, and no issues. Oh, and the steering is easier to steer as well. Even in fairly new vehicles!!
After you do it, ask your girlfriend if it steers any better.
If she pays attention to that stuff, she'll say yes.
07 Tundra 5.7L,Amsoil ASL 5w30,ATL
12 Camry 3.5L,Amsoil ASM 0w20, ATL
99 Epic 22 Inboard, ASL 5w30, ATF
12 Nissan NV 2500 5.6L,Amsoil ASL5w30,EAO
#1784681 - 02/17/10 07:12 AM Re: Power Steering Fluid for 2005 Toyota Echo [Re: 3Toyotas]
artificialist Offline
Loc: Florida
I have seen plenty of Toyotas with yellow PSF, but the cap says "Use Dexron."
I put in synthetic ATF, and I always get great results.
2010 Lancer Ralliart Sportback
#1785681 - 02/17/10 08:18 PM Re: Power Steering Fluid for 2005 Toyota Echo [Re: 3Toyotas]
kr_bitog Offline
Loc: South East Asia
Ditto, I also use Amsoil ATF and no issues too.
Hwever, thinking to try the thinner Redline PSF, not sure if anyone got experience before ?
Sidetrack, I find my brake require slightly less effort when I change the brake fluid from DOT 3 to DOT 5.1, but not sure if the effect will be the same with power steering when changing to thinner fluid.
