2015 F 150
by BISCUT
22 minutes 16 seconds ago
Ever have an "old guy" day?
by daves87rs
Yesterday at 10:25 PM
Fram Ultra C$11.87 (Ontario)
by dgunay
Yesterday at 10:16 PM
dodge 4.7 fram problem?
by joel95ex
Yesterday at 09:45 PM
ok until oil change 4.7 dodge
by joel95ex
Yesterday at 09:41 PM
0w20 vs 5w20 running on a Mazda 3 2014
by Stewie
Yesterday at 09:37 PM
5w20/30 4.4L Castrol Edge WM Canada $24.88
by Stewie
Yesterday at 09:31 PM
Back to greasing stuff...
by JHZR2
Yesterday at 09:04 PM
Castrol Import Multi question
by Carguy21
Yesterday at 08:20 PM
2005 F150 steering rack
by Colt45ws
Yesterday at 08:12 PM
Tinkering around today with my Cold Air Intake
by GumbyJarvis
Yesterday at 07:51 PM
Crude Oil at Historic Lows and 5W30 is High Priced
by cjcride
Yesterday at 07:35 PM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
20 registered (chrisri, CELICA_XX, BISCUT, 3800Series, Branson304, edhackett, 1 invisible), 601 Guests and 198 Spiders online.
56865 Members
66 Forums
244433 Topics
#1778802 - 02/12/10 01:22 AM Best oil for 71 chevy 350 engine
Gonz Offline
Loc: Virginia
Doesn't seem to burn any oil, no serious oil leaks. It's completely original inside with about 80k miles on it. It's a passenger car engine, still runs great.
#1778805 - 02/12/10 01:40 AM Re: Best oil for 71 chevy 350 engine [Re: Gonz]
genynnc Offline
Loc: OR
Any oil off the shelf should be fine with the very, very, mild stock GM cam and light stock spring pressures. Pick one and have at it.
03 Dodge Ram 1500 5.7= Kendal GT1 5w30, 55 Chevrolet 327/ Muncie= Valvoline VR1 10w30, 67 Chevelle Malibu 283= Quaker State Defy 5w-30
#1778861 - 02/12/10 04:57 AM Re: Best oil for 71 chevy 350 engine [Re: genynnc]
KW Offline
Loc: Central Arkansas
Any 10W30 or 10W40. Valvoline, Pennzoil, Castrol...
#1778931 - 02/12/10 08:08 AM Re: Best oil for 71 chevy 350 engine [Re: KW]
ARCOgraphite Offline
Loc: N.H, U.S.A.
You must be doing the right thing as far as oil, just keep doing it. If you want something a bit more robust, try rotella T5 (10w-30). If it seem a bit thick you can thin it with some Formula Shell 5w-30.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
#1778994 - 02/12/10 08:44 AM Re: Best oil for 71 chevy 350 engine [Re: ARCOgraphite]
Corvette Owner Offline
Loc: Waldorf, Maryland
I would run a quality synthetic, like M1 or PP. You did ask for the BEST OIL.
Vehicles:
98 Corvette
06 Murano
96 Chevy Van (Custom Conversion)
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
#1779046 - 02/12/10 09:35 AM Re: Best oil for 71 chevy 350 engine [Re: Corvette Owner]
artificialist Offline
Loc: Florida
Maybe the best synthetic here would be RTS 5w40.
2010 Lancer Ralliart Sportback
#1779160 - 02/12/10 10:52 AM Re: Best oil for 71 chevy 350 engine [Re: Gonz]
Indiana79 Offline
Loc: central pa
havoline or chevron 10w40 has a higher zinc and phos level around 1000 ppm if i rember correctly (good for your flat tappets) plus the higher viscosity will be good for the warm virginia summers. Another option mobil 1 high mileage 10w30 or 10w40.
#1779225 - 02/12/10 11:47 AM Re: Best oil for 71 chevy 350 engine [Re: Indiana79]
Bamaro Offline
Loc: Balto.
That's a flat tappet engine so that needs to be considered.
2015 Elantra
2009 Cobalt totaled by inattentive driver
1970 Camaro
2009 Civic
2015 Rogue
2014 Mazda3
#1779242 - 02/12/10 11:57 AM Re: Best oil for 71 chevy 350 engine [Re: Bamaro]
Robenstein Online   content
Loc: Central IA
Any good HDEO in your state would be fine. 15w40 or 10w30 Delvac, Rotella, Mystik JT8, Delo, ect would be fine. They have great antiwear packages and keep the engine clean. If you shop around you can get them as cheap or cheaper than regular PCMO varieties. I get Mystik for under 2.50 a quart.
2011 Triumph Speedmaster
1986 Chevy Monte Carlo SS
1970 Chevy Nova
2006 Scion TC
#1779247 - 02/12/10 12:00 PM Re: Best oil for 71 chevy 350 engine [Re: Bamaro]
mechtech2 Offline
Loc: Chicago Area
Bamaro - My new variable DOHC engine is a flat tappet type, also.
You have rollers or flat tappets. [Unless you have a Desmodromic system.]
Gonz - Are you going to drive this car? 500 a year? 10,000?
For hard use I'd use a diesel oil in 15-40. Those engines were not lovers of thinner oils - not yet.
You could use a 5-30 for light driving here and there, with no great heat to deal with.
Oils were not that great then. They got better in 20 years. And now, oils are castrated, but have substitute methods of anti wear.
BTW, your cam and lifters will still wear somewhat. They wore then, and they'll wear now.
#1781326 - 02/14/10 12:08 PM Re: Best oil for 71 chevy 350 engine [Re: mechtech2]
Loc: N.H, U.S.A.
How true - the higher zddp "back in the day" couldnt keep a cam alive much past 100k unless the induction hardening was very consistently applied.
