Yokohama AVID Acend 195/60R15. $190
by Sam_Julier
04/30/16 07:24 AM
Hate those adds that start with, "Lean 1 weird ...
by OneEyeJack
04/30/16 05:11 AM
How Much Olive Oil Do You Use?
by GrtArtiste
04/30/16 03:20 AM
Hyundai filter 26300-35503 10PK for 35.40 FREE S&H
by GumbyJarvis
04/30/16 01:10 AM
Dope smoking genius Laremy Tunsil NFL Draft Pick!
by GiveMeAVowel
04/29/16 09:50 PM
'13 Honda VFR1200 Motul 10w-50, 5,300 miles.
by montero1
04/29/16 09:35 PM
Anyone Using Spline Sockets?
by JHZR2
04/29/16 09:33 PM
Anyone Tryed Spectra Premium O2 Sensors?
by Mr_Accord
04/29/16 09:16 PM
UPS package tracking is so confusing!
by Klutch9
04/29/16 07:52 PM
Dupont non-stick lube
by buck91
04/29/16 07:47 PM
House electrical wiring question
by road_rascal
04/29/16 07:46 PM
Air pressure question
by aquariuscsm
04/29/16 07:43 PM
hdwizard21, raihan, aceracres, kg4geq, red_bulldog
57748 Registered Users
77 registered (AandPDan, AirgunSavant, Bandito440, 2002 Maxima SE, andyd, 10 invisible), 1329 Guests and 118 Spiders online.
57748 Members
66 Forums
248235 Topics
#1767776 - 02/04/10 01:11 AM search oil filters by thread size?
Texan4Life Offline
Loc: Texas
Is there a way to search oil filters by thread size and/or other characteristics?
I want to see if I can find a filter with a better beta ratio.
2005 Dodge Ram 1500, 5.7L
[Current Fill: PP 0w-20][Baldwin B2-HPG]
#1767818 - 02/04/10 03:19 AM Re: search oil filters by thread size? [Re: Texan4Life]
chad8 Offline
Loc: michigan
#1767835 - 02/04/10 03:59 AM Re: search oil filters by thread size? [Re: chad8]
Texan4Life Offline
Loc: Texas
yeah that's what I have been using. you have to search by make/model/year/engine. If there is a way to search using other info I haven't found out how.
I got lucky just hitting different engines and searching manually.
the two sizes im after are 3/4-16 with a gasket max OD 3.10 and min ID of 2.20
and 13/16-16 with about OD 2.7 ID 2.4
so far the best I have found for the 3/4-16 is #51307 [2/20=7/18]
the 13/16 is going to be hard to vary from stock as it is in a tight space and I need to measure the filter head gasket area to be more definite on the possible gasket OD and ID.
otherwise some possible matches for the 13/16 is #51061 [2/20=11/27] and #57202 [2/20/75=8/20/25]
#1767897 - 02/04/10 07:09 AM Re: search oil filters by thread size? [Re: Texan4Life]
ARCOgraphite Offline
Loc: N.H, U.S.A.
I think the clarecore site (Hastings/Baldwin) will get you a reverse lookup. Thats where I found a B1431 4" long filter for current subaru applications w/ M20 x 1.5 threads (but never bought it due to and engine knock - stuck with the marginal oem service honeywell blue 12A)
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
#1767900 - 02/04/10 07:13 AM Re: search oil filters by thread size? [Re: Texan4Life]
Loc: N.H, U.S.A.
My mom has a 89 deville coupe with the continental kit. All white leather with red carpeting and dash. ON her 3rd motor in 70K miles. Last one ran good but the coolant ate thru the rear of the block inside the trans bellhousing. Nice car though, drives easy and good visibility. Back when GM still remembered how to make a good driving car.
#1768149 - 02/04/10 10:03 AM Re: search oil filters by thread size? [Re: ARCOgraphite]
Gary Allan Offline
Loc: Pottstown, PA
https://dynamic.donaldson.com/webc/WebStore/search/attribute.html
Use the pull down menu and select "lube filters". Insert all forms of the thread size (example: 3/4-16, 3/4 - 16, etc.) from the list of thread sizes. Ignore the term "inches" where your thread may be metric. All available filters in that thread will be listed. Xref those to Wix or whomever's xref utility ..
http://lube-direct.com/gallan/
#1768226 - 02/04/10 10:56 AM Re: search oil filters by thread size? [Re: Texan4Life]
OAS Offline
Loc: NM
Dont forget to research the micron rating, flow rate, contaminate capacity, etc.
Also, is your vehicle under a factory or aftermarket warranty?
Use the wrong filter, and POOF kiss that warranty goodbye!
But you only have to worry IF something breaks.
As long as you are using the equivelent to a factory filter (in your fav brand of course) your o.k.
#1768704 - 02/04/10 05:44 PM Re: search oil filters by thread size? [Re: Texan4Life]
SuperBusa Offline
Loc: WA
Isn't there a PureONE in your size?
Beta 1000
Condition 0
#1769116 - 02/05/10 12:28 AM Re: search oil filters by thread size? [Re: SuperBusa]
dwendt44 Offline
Loc: Central Wisconsin
I talked a auto parts guy into giving me a filter master catalog(Purolator).
One that a repair shop might get. Last years issue.
In the back, all the dementions of each filter is listed.
Took a little digging but found each filter with the thread size I was looking for.
Listing them checked what they fit and ther pop number. (population number-A most popular/C least popular-etc..).
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
