Local Big Lots still has Valvoline next gen 10w30
by Electromotive
43 minutes 35 seconds ago
Best Value Differential Oil 75W-90
by KevinP
Today at 01:02 PM
kohler 17hp . changed oil , now will not run
by chad8
Today at 12:32 PM
Oil change recomendations for '11 Ranger 2.3 Liter
by ryan2022
Today at 11:49 AM
Suggestions for 94 Lexus LS400 ATF
by Gasbuggy
Today at 11:23 AM
GOST Diesel fueln
by m37charlie
Today at 11:10 AM
Old interesting finds
by car51
Today at 10:53 AM
Filling nail holes in drywall
by Drew99GT
Today at 10:47 AM
1987 ford 460 motorhome, which oil to use?
by digler
Today at 10:30 AM
My ride in a B-17
by cb4017
Today at 10:28 AM
Speaking of missing members
by Oldmoparguy1
Today at 10:10 AM
Wiper blades $3.88 at Home Depot
by Jimmy9190
Today at 09:57 AM
Ruturaj, derfderfgoose, ssnead, mtrev, redtacoma
58277 Registered Users
74 registered (-SyN-, 901Memphis, andyd, b1amgm47, Atesz792, 04SE, 7 invisible), 1950 Guests and 10 Spiders online.
58277 Members
66 Forums
250838 Topics
#1757173 - 01/26/10 10:08 PM pro and con with bulb grease
mrkdk Offline
Loc: sc
Can any body tell me a good reason to use bulb grease or good reason not use it.
#1757184 - 01/26/10 10:16 PM Re: pro and con with bulb grease [Re: mrkdk]
Billbert Offline
Loc: California
If you are talking about dielectric grease, helps stop corrosion, reduces arcing,and great to use on household bulbs, no more potatoes to get out the stuck bases
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
#1757186 - 01/26/10 10:16 PM Re: pro and con with bulb grease [Re: Billbert]
beast3300 Offline
Loc: Ohio
For: Seal moisture out, maybe aid in future removal.
Against: There may be some in there from the factory so addition isn't required.
Edited by beast3300 (01/26/10 10:17 PM)
'03 Regal GS L67 3.29 GR:, PUP 5w30/TG3980, Filtermag
'99 Grand Prix L36: QS Defy 5w30/TG3387A, Filtermag
#1757189 - 01/26/10 10:19 PM Re: pro and con with bulb grease [Re: beast3300]
Johnny Offline
Loc: Retired | Wausau, WI
Like anything else, to much is a bad thing. Very light coating is a good thing for the above reasons.
Never thought about using it in a household light bulb. I will have to give that a try.
#1757207 - 01/26/10 10:49 PM Re: pro and con with bulb grease [Re: Johnny]
XS650 Offline
Loc: Northern CA
I've used plain old silicone spray on 110V bulb bases. Keeps them from sticking in rasty old outdoor sockets.
Whenever you find yourself on the side of the majority, it is time to pause and reflect.
--Mark Twain
#1757242 - 01/26/10 11:38 PM Re: pro and con with bulb grease [Re: XS650]
mrsilv04 Offline
Loc: Illinois
There's a simple solution that doesn't require grease in most cases....
Don't tighten light bulbs so tightly! They aren't going anywhere.
Whatever you do... do NOT speed through the town of Gauley Bridge, WV.
#1757253 - 01/26/10 11:57 PM Re: pro and con with bulb grease [Re: mrsilv04]
oilboy123 Offline
Loc: Everett, Washington
I notice the fluorescent bulbs use stainless on the bases which keeps things working as opposed to aluminum bases. I have used dielectric grease on the old style auto bulbs. I guess I should probably use it on any style.
“Loyalty to country ALWAYS. Loyalty to government, when it deserves it.”
― Mark Twain
#1757524 - 01/27/10 09:11 AM Re: pro and con with bulb grease [Re: oilboy123]
cchase Offline
Loc: New England
I use dielectric grease on every single electrical connection on my cars... once you have a 17 year old vehicle and you need to disconnect something that hasn't been disconnected in that long you'll put it on everything so it doesn't happen again.
I also have aquarium lights (CF) that have a pin base that love to corrode together, the grease makes them easy to pop on and off.
Cons... it's grease, attracts dirt. Don't use so much and it's not a problem.
#1757564 - 01/27/10 09:40 AM Re: pro and con with bulb grease [Re: cchase]
eljefino Offline
Loc: ME
The yellow earwax snot in GM cars works quite well against corrosion, but the bayonet bulbs (twist & turn) still seem to have their base contacts lose springiness and cause issues. I never have to add more grease, they seem to put in 10x as much as was needed.
#1757574 - 01/27/10 09:49 AM Re: pro and con with bulb grease [Re: eljefino]
mechtech2 Offline
Loc: Chicago Area
On cars? For bulbs and connections this is a great thing.
It keeps water/humidity out This is it's primary benefit. Also, there is some direct corossion protection.
