Anybody use Shell Rotella T1 SAE 40 in boats?
by Bgallagher
4 minutes 31 seconds ago
"Scrub Radius"
by George Bynum
28 minutes 50 seconds ago
Any Subaru gurus here? EJ25 DOHC vague knock
by Why_Anything
33 minutes 22 seconds ago
Erdogan apologizes to Russia
by Jetronic
37 minutes 6 seconds ago
Terrible accident in So Cal last night.
by HTSS_TR
Today at 01:30 PM
Bought my first 0w-20 oil today
by shDK
Today at 01:22 PM
Tacoma Extended OCI
by 13Tacoma
Today at 01:07 PM
Gear oil mixed in with Diesel Engine Oil ...
by Miller88
Today at 12:07 PM
DELO ELC Antifreeze/Coolant??
by Griz95
Today at 12:06 PM
Higher oil pressure. Oil? Filter? Jeep 4.0
by RegDunlop
Today at 11:16 AM
NJ's gas tax increase
by Whimsey
Today at 11:11 AM
PAO in Mobil 1 0w-40
by loneryder
Today at 10:33 AM
dpaldino, T_Bortz, rebelx, dougsangster, CrazyCalvinW
58314 Registered Users
98 registered (4wheeldog, adamrc, ag_ghost, AandPDan, 10 invisible), 2108 Guests and 14 Spiders online.
58314 Members
66 Forums
250988 Topics
#1755221 - 01/25/10 03:00 PM Motorcraft FL 910
lizzyfan Offline
Loc: Magnolia, De
Will it fit a 2008 Mazda3 with a 2.0?
#1755300 - 01/25/10 03:58 PM Re: Motorcraft FL 910 [Re: lizzyfan]
sdude2k2000 Offline
Loc: Southern Oregon, USA
Yep. It's the ford equivalent spec for their 2.0 in the late model Focus (same engine). I'd personally recommend using the FL-400S if you're going to use a motorcraft filter. It has the same dimensions as the FL-910 with the one exception of being about 1/2" longer. It uses the threaded end bypass valve -vs- dome end, plus has a silicon anti-drainback valve where the FL-910 only has a rubber.
The FL-910 is simply a Purolator Classic filter whereas the FL-400S is made specifically for Ford by Purolator.
'08 Ford Fusion SEL 3.0L
Pennzoil Ultra Plat 5w20 | Fram Ultra
'15 Toyota Prius
Pennzoil Ultra Plat 0w20 | Fram Ultra
#1755718 - 01/25/10 08:57 PM Re: Motorcraft FL 910 [Re: sdude2k2000]
mshu7 Offline
Loc: Brownsburg, IN 46112
Just last week I changed the oil on my Mazda3 2.3L and replaced the FL-910 I was using with the FL-400S. The FL-400S went on with no problems and there don't seem to be any clearance issues with the extra length.
*Note - I swapped the factory cartridge setup for the 2.0L factory spin-on setup.
2004 Chevy Colorado Z71 4x4 3.5L 142K
Mobil Super High Mileage 5w30 | Pure1
2006 Toyota Sienna 3MZ-FE 120K
Toyota 0w20 | Pure1
#1755794 - 01/25/10 10:06 PM Re: Motorcraft FL 910 [Re: mshu7]
sdude2k2000 Offline
Aren't you on mazda3forums.com as well? Pretty sure I remember you from there... I'm SiXX.
Edited by sdude2k2000 (01/25/10 10:06 PM)
'15 Toyota Prius
#1755857 - 01/25/10 11:12 PM Re: Motorcraft FL 910 [Re: sdude2k2000]
lizzyfan Offline
Loc: Magnolia, De
Will it fit ok with the underbody panel
#1755887 - 01/25/10 11:37 PM Re: Motorcraft FL 910 [Re: lizzyfan]
sdude2k2000 Offline
Obviously you should measure first just to be safe... however I can tell you that the FL-400S is approx 1/2" longer than the FL-910. You still want extra clearance for engine shifting under accel, decel, turning, etc. My 2.0L in my '06 mx-5 is mounted front to back, not side-to-side like a mazda 3... so I can't tell you "yes or no" for your application, but I can tell you that I have no clearance in my application. If mshu7 says his fits on his Mazda 3, then it should also fit on yours as you have the same engine layout & design (the 2.0L - 2.3L is irrelevant).
Edited by sdude2k2000 (01/25/10 11:37 PM)
'15 Toyota Prius
#1756347 - 01/26/10 11:37 AM Re: Motorcraft FL 910 [Re: sdude2k2000]
ThirdeYe Offline
Loc: Walker, MI
Keep in mind that the FL-400S has shrunk a little bit in size, I'm not sure if you're taking that into account or not when comparing it to the 910. I don't know what the 910 looks like, just thought I'd mention it.
99 Pontiac Firebird - 93k - Havoline 10W-30/Purolator PureOne PL10111
08 Scion tC - 119k - RP 0W-20/Purolator Classic L14477
#1756646 - 01/26/10 03:19 PM Re: Motorcraft FL 910 [Re: ThirdeYe]
sdude2k2000 Offline
Yep! I thought I mentioned that already, but just reread my posts and realized I hadn't. The FL-400S used to be approx 1" longer... but they shortened it about 1/2". That extra 1/2" is what allows it to fit under my car now and still allow proper clearance for engine movement.
To the original poster... my recommendation is to make sure you get the shorter version (very obvious if you have one next to the other). Otherwise, here's a "make shift" way to tell which one you have... the newer version is approx ONE finger width longer than the FL-910 while the older version is TWO finger widths.
Edited by sdude2k2000 (01/26/10 03:22 PM)
'15 Toyota Prius
#1757438 - 01/27/10 08:14 AM Re: Motorcraft FL 910 [Re: sdude2k2000]
mshu7 Offline
Sorry for the late response.
YES, the FL-400S fits nicely under the Mazda 2.0/2.3 engine.
Toyota 0w20 | Pure1
#1757832 - 01/27/10 01:42 PM Re: Motorcraft FL 910 [Re: mshu7]
lizzyfan Offline
Loc: Magnolia, De
Thanks!
