How long is sealed coolant good for?
by addyguy
05/29/16 04:08 PM
4T65E 2006 Buick Lucerne Normal decel gear banging
by deanm11
05/29/16 03:41 PM
California drought and 3" fish delta smelt
by HTSS_TR
05/29/16 03:18 PM
High SAPS & DPF Re-Gen
by userfriendly
05/29/16 02:50 PM
Decent little string trimmer
by Papa Bear
05/29/16 02:24 PM
Pirelli
by borgward
05/29/16 02:10 PM
'88 Cadillac smog (Emission test) fails
by momo
05/29/16 01:59 PM
Towing what to look for?
by Camprunner
05/29/16 01:48 PM
The Critic's Choice 2014 Yaris vs 2015 Accent
by Gasbuggy
05/29/16 12:52 PM
What Fram Ultra For 95 Cadillac Seville?
by crazyoildude
05/29/16 12:46 PM
Import Multi-Vehicle, Valvoline vs. Castrol, VI?
by Samzone
05/29/16 12:36 PM
Fram Ultra Bypass Valve Spring Life
by Digital2k2
05/29/16 11:32 AM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
94 registered (79Eldor, 2015_PSD, 66chevelle, AandPDan, 2cool, 2009Edge, 9 invisible), 1688 Guests and 321 Spiders online.
58013 Members
66 Forums
249565 Topics
#1306411 - 12/09/08 01:00 PM Oil for Yamaha 350 Big Bear 4x4 ATV?
bassadict69 Offline
Loc: Haughton, La
From what I have always been told, my 4 wheeler takes some kind of special oil so I have always bought the Yama-Lube from the dealer which is expensive as [censored] & supposedly has some special additive or something in it. Is there anything else I can use that may be a little cheaper?
It is not an auto transmission if that matters!
2002 Silverado 4x4, 4.8 Liter
2002 Monte Carlo SS
#1306413 - 12/09/08 01:03 PM Re: Oil for Yamaha 350 Big Bear 4x4 ATV? [Re: bassadict69]
bubbatime Offline
Loc: South Florida
What viscosity? A good motorcycle oil should be cheaper and readily available.
10 Acura TSX 2.4L Quaker State syn 5W20 Fram Ultra
09 Chrysler Town & Country 4.0L Chevron Supreme 10W30
06 GMC Sierra 4.8L QSGB 5W30 Delco PF46
#1306498 - 12/09/08 02:40 PM Re: Oil for Yamaha 350 Big Bear 4x4 ATV? [Re: bubbatime]
bassadict69 Offline
Loc: Haughton, La
That, I am not sure of...I will have to see if I can find out! I might still have a bottle of the high $$$ stuff at the house.
2002 Monte Carlo SS
#1306600 - 12/09/08 04:24 PM Re: Oil for Yamaha 350 Big Bear 4x4 ATV? [Re: bassadict69]
bassadict69 Offline
Loc: Haughton, La
10W40 Yama-Lube, the dealer says it has some additional friction additives.
2002 Monte Carlo SS
#1306819 - 12/09/08 07:39 PM Re: Oil for Yamaha 350 Big Bear 4x4 ATV? [Re: bassadict69]
ccdhowell Offline
Loc: Shreveport, Louisiana
That's entirely untrue as far as I know. I have 8 atvs and don't run Yamalube in any of them and three of them are Yamahas. Correct me if I'm wrong, but your Big Bear has a CVT auto transmission, which means the engine oil is only used by the engine and not in the transmission and wet clutch. Which means that you can run lots of different oils, anyone you like really. I'd say that an oil like Rotella T 15w40 would work great.
If I'm wrong and you're shifting gears and have a semiauto clutch, well, I'd still recommend Rotella T 15w40, just change it more often when you ride allot, maybe every 20 hours.
Hope this helps and good to see another local guy on the forum.
#1308357 - 12/11/08 07:26 AM Re: Oil for Yamaha 350 Big Bear 4x4 ATV? [Re: ccdhowell]
bassadict69 Offline
Loc: Haughton, La
Not real sure what a CVT auto transmission is, but my Big Bear is the old style manual shift.
2002 Monte Carlo SS
#1308560 - 12/11/08 11:10 AM Re: Oil for Yamaha 350 Big Bear 4x4 ATV? [Re: bassadict69]
Ben99GT Offline
Loc: MS
CVT is what the Grizzlies have; continuously variable transmission.
I've been running Amsoil 10W-40 Advanced Synthetic Motorcycle Oil in a '99 Grizzly for years and it's been doing great. Started out with Yamalube, but realized that at the local motorcycle shops Amsoil was selling for about $7/qt, almost the same as Yamalube!
2001 F150 Supercrew
1991 Mustang LX notch
1999 Mustang GT
#1708204 - 12/15/09 10:54 AM Re: Oil for Yamaha 350 Big Bear 4x4 ATV? [Re: Ben99GT]
bassadict69 Offline
Loc: Haughton, La
I never got back to this one due to a few problems, but, with my Big Bear having a regular manual shift type tranny, can another oil be used?
2002 Monte Carlo SS
#1708236 - 12/15/09 11:24 AM Re: Oil for Yamaha 350 Big Bear 4x4 ATV? [Re: bassadict69]
JTK Offline
Loc: Buffalo, NY
Assuming it's an air cooled 350cc w/ a semi-automatic (no clutch) 4 or 5spd gear shift, I'd use R-T 15w40 like ccdhowell suggests above, or Rotella-T 5w40. If it's liquid cooled I'd use a HDEO in the 30wt range or the 5w40.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#1708403 - 12/15/09 01:32 PM Re: Oil for Yamaha 350 Big Bear 4x4 ATV? [Re: JTK]
bassadict69 Offline
Loc: Haughton, La
Thanks for the help...I was just wanting to make sure before changing it tomorrow.
2002 Monte Carlo SS
#1708723 - 12/15/09 06:32 PM Re: Oil for Yamaha 350 Big Bear 4x4 ATV? [Re: bassadict69]
daman Offline
Loc: Bad Axe, MI
Run any HDEO and it'll be fine,thats what to use.
"Always"....Mobil 1
Current fill: AFE 0w30
#1717250 - 12/23/09 12:29 PM Re: Oil for Yamaha 350 Big Bear 4x4 ATV? [Re: daman]
Cmarti Offline
Loc: Ohio
I run Rotella 5W40 Synthetic in everything I own air cooled, a couple of those toys are Yamaha ATV's. I have had great luck and smooth shifting. It has even worked well in my Goldwing.
#1734046 - 01/07/10 07:12 AM Re: Oil for Yamaha 350 Big Bear 4x4 ATV? [Re: Cmarti]
porkchop01 Offline
Loc: Texas
Will the Rotella 5w40 synthetic help on cold starts better when the temps are around say 10F? or would a 10W30 be better?
08 Dodge 1500 4x4
03 Dodge 1500 4x4
08 Ford F250
70 Ford F100
06 Harley FXDI 88ci
07 Yamaha Grizzly 250
13 Kawasaki mule 610xc 4x4
#1751136 - 01/21/10 10:40 PM Re: Oil for Yamaha 350 Big Bear 4x4 ATV? [Re: porkchop01]
whitearrow Offline
Loc: philadelphia,ms
deffinently the 5w would be better than a 10w in 10 degrees!
2005 toyota camry xle on syntec 5w-30
2010 toyota tundra dc 4x4 5.7 liter V8 on toyota 0w-20 synthetic
2010 toyota highlander on toyota 0w-20 synthetic
