adhesive for pea gravel?
by xfactor9
05/24/16 08:19 PM
Micro guard Gl14609 150 hours
by robo339
05/24/16 08:02 PM
walking thru a Harbor Freight is better than sex
by turtlevette
05/24/16 07:58 PM
'14 Durango 3.6L, PUP 5w20, 7.5k, TBN/TAN
by Mantooth
05/24/16 06:59 PM
Advice: Odyssey or Sienna?
by Barwich
05/24/16 06:43 PM
Any HR specialists out there?
by bustednutz
05/24/16 06:23 PM
Jawa 350/360 (two-stroke) motor oil
by volodymyr
05/24/16 05:52 PM
Red Line 20W60 Synth. 1k Miles '13 KTM DUKE 690
by albertdi
05/24/16 05:49 PM
Tire Suggestions - 2014 Dodge Grand Caravan
by Nick1994
05/24/16 05:38 PM
Completing your 80% lower receiver manually
by Merkava_4
05/24/16 05:18 PM
5.4 3V VCT solenoid replacement
by 04SE
05/24/16 05:11 PM
Changed the spark plugs on Sunday, and [censored]??
by SirTanon
05/24/16 04:46 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
119 registered (ABerns, AZjeff, 2004tdigls, 2009Edge, AandPDan, bchannell, 11 invisible), 1782 Guests and 110 Spiders online.
57973 Members
66 Forums
249365 Topics
#174648 - 02/01/06 06:21 PM can i mix 5w30 with 10w30?
tonttu Offline
Loc: sweden
i have gm 5w30 oils in the engine.i was thinking to put gm 10w30 in it,about 1/2,1 quart.is it ok,or should i only add 5w30 [Confused]
#174649 - 02/01/06 06:21 PM Re: can i mix 5w30 with 10w30?
ToyotaNSaturn Offline
Loc: Spring Hill, TN
Yes. As long as it's SL or SM rated, you'll be fine. It's completely safe to do so.
[Cheers!]
#174650 - 02/01/06 06:33 PM Re: can i mix 5w30 with 10w30?
tonttu Offline
Loc: sweden
yes,both, 5w30 and 10w30 are sl/sj rated [Burnout] [Burnout]
#174651 - 02/01/06 06:56 PM Re: can i mix 5w30 with 10w30?
TallPaul Offline
Loc: By Detroit
I've even mixed straight 30 weight in with 10w30 and no apparent problems. Oh, I've mixed worse things than that too.  -
#174652 - 02/02/06 01:38 AM Re: can i mix 5w30 with 10w30?
tonttu Offline
Loc: sweden
how about mixing 76 super synthetic blend about 1/2 or 1 quart to gm dino 10w30 4 quarts?
#174653 - 02/02/06 06:04 AM Re: can i mix 5w30 with 10w30?
m2200b Offline
Loc: Alamo, CA
The net effect of adding 1/2 or 1 gt of anything
in your 4.5 gt really doesn't change it much
as you can check in the shell viscosity mixer as its only changing it by 1/5 anyway. I do use add oil to aim the grade to where I want to try.
On my daughter's oil consuming tercel, I add 1 qt of 20-50 Castrol HM to see if thicker helps stop her consumption and rear main leak. On mine I add some moly laden VSOT or 10-40 to see if moly or thicker helps. Its like a low cost preview if you are going to change in 1k miles anyway.
On yours, you will change soon if you stay with 3K OIC so adding a blend with maybe 20% syn is like adding 5% syn. If you want to experiment and see how a blend works with GM dino I'd add all syn so at least you get a blend for the entire 4.5 gts. Costwise I'd add any dino since you'll drop it in a month.
