During a google search, I found some information posted by an engineer from Fram. Here is what I found:
Quote:
I am the technical training manager for FRAM. I would love to tell you all about the extended guard filter from FRAM with facts and engineering knowledge. We just did some testing that clearly shows we have more dirt holding capacity than Mobil 1 extended life filter. We also have a higher efficiency rating and are the only filter to guarantee 10k oil change intervals when used with synthetic oil. There is already a bunch of mis-information in this string about who makes what. In addition, I will only answer questions based on accepted engineering testing, not 15 yr old internet studies of cut open oil filters. Our filters are only made in Canada (Stratford), and USA (Greenville, OH and Clearfield, UT). The xtended guard filter is a two ply full synthetic media that is wrapped around a stainless steel screen backing. This is held in place by metal end caps. It also has a silicone antidrainback valve to remain pliable with extended drain intervals. I welcome your questions about filtration as well as any questions from this forums members.
Quote:
Concern:
Pass on the Fram and get anything else. Cardboard doesn't have a place in your engine.
Answer:
there is no "cardboard" in any FRAM filter. The end caps in the lower level models are an engineered media, just like the filter media itself.
Quote:
Question: Motorking:
Welcome to CleanMPG! Thanks for joining and offering info. I will dig in my archive drives and try to find pics that I have questions about. So now you offer Extra, Tough, Extended Guard and High Mileage models. Is Extra Guard your bottom end model?
Answer:
Extra Guard- This is our entry level, least expensive filter. It is designed for those using regular or synthetic oil and changing oil every 3-4k miles. It has a 95-96% efficiency rating. This filter is very good, yet takes a beating on the internet for having fiber end caps. The end caps are not part of the filter structure, they are there to seal the ends of the filter media (which is also a fiber on all filters).The guys who comment on the net that this is some kind of weakness really do not understand filter construction at all. We build millions of these filters per year and have zero issues with them.
Tough Guard- The next step up. This filter is similar to the extra guard except is has a synthetic blend media that is 99% efficient. It also is recommended for the 5-7k oil change interval. It has a stainless screen over the bypass valve for added protection and a silicone antidrainback valve for longer life.
High Mileage- This is very cool filter. It is designed for high mile engines. It is similar to extra guard in construction except it has a "timed release" basket containig a oil conditioning chemical. This chemical replenishes the additive package in the oil that a high mile engine can consume pretty quickly. This technology is being developed farther along in the hopes that someday you could change only your filter and not the oil.
HP Racing Filter- Not likely much interest in this among this board but- This is a very high flowing and mechanically robust filter for those running higher than normal oil temps and pressures in racing engines. not really designed for street use.
Extended Guard- The flagship of the FRAM line and our best filter. Two ply full synthetic media wrapped around a stainless steel screen. This filter is totally designed for the 10k oil change. It has great 97% filtering efficiency and excellent dirt trapping ability up to 26 grams on the larger filters! It also has a silicone antidrainback valve for long life. We say right on the box it is recommended for up to 10k change intervals when used with quality synthetic oil.
Thanks for listening and I am always at your service to answer any filtration, spark plug or coolant/cooling system issues you may have.
Quote:
Question: Motorking,
Glad to see your reply as I've been a lifetime fan of your product. For some reason there is alot of negative publicity surrounding your company on the internet. What is your company doing to dispel these myths?
Answer:
Well, we have really just ignored it for a long time. That has had the unfortunate effect of making some believe what they hear is true. So what are they doing about it? They are having myself and the other technical trainers in my group answer filter, spark plug and coolant questions on various internet forums with engineering facts, no marketing [censored], just facts. I hope you buy my companies products but I am only here to educate, not sell.
Sources:
Thread: http://www.cleanmpg.com/forums/showthread.php?t=25117
User: http://www.cleanmpg.com/forums/member.php?u=11210
Enjoy!
Quote:
Concern:
Answer:
Answer:
Answer:
Sources:
Enjoy!
