whole hog cook w/ pics
by 04SE
18 minutes 57 seconds ago
redo a/c in 1994 dakota 2wd
by bmwjohn
53 minutes 21 seconds ago
How to post UOA's on here?
by motor_oil_madman
56 minutes 34 seconds ago
Remanns Brand Remanufactured engines
by TiredTrucker
Today at 09:11 PM
Best long lasting door hinges lurbicate ?
by MetalSlug
Today at 08:59 PM
How do you clean trunk area (not inside the trunk)
by MetalSlug
Today at 08:57 PM
Gas prices do the ol' switcheroo
by grampi
Today at 08:44 PM
Possible Valve adjustment needed?
by andrewp1998
Today at 08:16 PM
Hey Dad, can I have some corn syrup, corns starch
by Shannow
Today at 06:47 PM
Idling question
by thunderfog
Today at 06:39 PM
Lodge Sportsman Grill
by hatt
Today at 06:07 PM
2016 Honda Civic factory filter, CUT OPEN
by car51
Today at 05:34 PM
LatitudeDancer, AKN, NickGB, Marcusd1979, emar520
58644 Registered Users
74 registered (AirgunSavant, AZjeff, 2015_PSD, 04SE, ActiveWolf, ag_ghost, 4 invisible), 1575 Guests and 8 Spiders online.
58644 Members
66 Forums
252423 Topics
#1730209 - 01/04/10 06:36 AM Mixing ATF (Diamond SP3 with Dexron II)
Jensen Offline
Loc: Brazil
I've got a Pajero/Montero with V4AW3 tranny.
It was originally filled with the ATF Diamond SP3 (equivalent).
In the last revision i did, the mechanic identified the level of ATF was low and completed the level with about 2.5 liters of Dexron II compatible oil.
The MMC recommends the Dexron II for this tranny (no problem with that), but, as it was previusly filled with SP3 ATF, so my question is: is there any problem mixing SP3 ATF with Dexron II ATF ?
Thanks
#1730229 - 01/04/10 07:22 AM Re: Mixing ATF (Diamond SP3 with Dexron II) [Re: Jensen]
caravanmike Offline
Loc: ohio
i don't think so.
Oils I use: Any 5w-30,5w-20 conventional
#1730269 - 01/04/10 08:47 AM Re: Mixing ATF (Diamond SP3 with Dexron II) [Re: caravanmike]
JustinC25 Offline
Loc: NH
I don't think you will have an issue.
I mix dexron III and T-IV all the time in transmissions that call for Dex II/III.
I actually have about 30% T-IV in my A140E in my Camry now.
It fixed a "lazy to go in to gear in cold weather" issue that I had.
I've had it in there for a while now with no ill effects.
'95 Camry 2.2 298k R.I.P.
'10 Camry 2.5 6 spd 78k PP 0w20
Toyota 04152-YZZA1 Filter
'02 Outback 2.5 194k Total Classic 5w30 Union Sangyo C-840 Filter
#1730355 - 01/04/10 10:19 AM Re: Mixing ATF (Diamond SP3 with Dexron II) [Re: JustinC25]
unDummy Offline
Loc: RI
Upgrading is not a problem.
Downgrading is.
Mixing isn't a problem.
You downgraded your SPIII with DexronII.
You upgraded your DexronIII with T-IV.
And, how are you originally filled with SP3 while the MMC recommends DexronII?
The real question is "why are you 2.5liters low" and "was the level checked correctly"?
Learn to use the dipstick!
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
#1730361 - 01/04/10 10:23 AM Re: Mixing ATF (Diamond SP3 with Dexron II) [Re: unDummy]
wgtoys Offline
Loc: California
2.5 liters low says their either the mechanic measured wrong or you have a massive leak. Both are a bigger concern than the mixing.
#1730396 - 01/04/10 10:46 AM Re: Mixing ATF (Diamond SP3 with Dexron II) [Re: wgtoys]
Jensen Offline
Loc: Brazil
I've used the original dipstick of the car. To measure the level, i've drive the car for about 20km and with the car stopped and the engine running, i put the transmission on all positions (P, R, D, N, 2, L) for about 30 secs each. After that i put it on "N" and used the dipstick. Not sign of oil at all on dipstick.
I just bought the car 2 months ago and i have no idea why the level was so low. There is no sign of leak. I don't have mainteinance history of the car, but it is a Pajero/Montero, year 2000, with about 110.000kms.
It was using the SP3 because, here, in Brazil, the Mitsubishi only uses SP3 from Castrol. Probably because they have an commercial deal. I've checked the recommendation for my tranny in other markets (US, Japan) and they all recommend the Dexron II.
Thanks for all the answers,
