businesses charging extra sales tax?
by motor_oil_madman
02/11/16 10:51 AM
Why do many WEST states have MAX of 91 Octane?
by tempnexus
02/11/16 10:47 AM
CERATEC in a newishing eninge (7k miles)?
by tempnexus
02/11/16 10:42 AM
Penzoil synthetic 5w 30 in my 06 4.6 Mustang
by gmh101357
02/11/16 10:26 AM
recomendations for sub $10k used hatch?
by earlyre
02/11/16 10:26 AM
How to handle dangerously bad work by a shop
by Mykl
02/11/16 10:13 AM
Is ATF an oil?
by skaughtz
02/11/16 09:59 AM
Nexen Tires?
by 2015_PSD
02/11/16 08:02 AM
Wishing for shut off and cold atf level checks-
by Lapham3
02/11/16 07:01 AM
1997 Gand Marquis
by fordman65
02/11/16 03:50 AM
Better micron rating than a 40u for a 4967/14476?
by ziggy
02/11/16 02:59 AM
Weapon Shield
by Ws6
02/11/16 12:33 AM
tempnexus, cobra1616z, meyer, biyogo, Jandry
56894 Registered Users
102 registered (440Magnum, Andrei, AlaskaMike, akela, A310, 10 invisible), 1570 Guests and 203 Spiders online.
56894 Members
66 Forums
244542 Topics
Page 1 of 4 1 2 3 4 >
#1724734 - 12/30/09 11:02 AM Older car? thicker oil?
edwardh1 Offline
Loc: Coastal South Carolina
If a car NEW uses 5w 30, when it gets say 110,000 miles on it should you put 10w 40 in it? to compensate for wear?
seems there is SOME wear in 100,000 miles.
#1724742 - 12/30/09 11:09 AM Re: Older car? thicker oil? [Re: edwardh1]
coffee Offline
Loc: Chandler, Arizona, USA
My cars have very high mileage and I am using MaxLife 5w20 in them with great results.You can use whatever grade you want and be fine as long as it is not a thick oil for a cold climate.
Java Joe
1994 Volvo 945
Motorcraft 5w20
#1724757 - 12/30/09 11:18 AM Re: Older car? thicker oil? [Re: coffee]
Captain_Klink Offline
Loc: Afghanistan
my 1995 dodge colt, 1.5l 12v 4 cylinder has 200,000 miles on it. everything is original. it is a daily driver. it does not get babied, and it does not get abused either. regular oil changes every 3k all its life with conventional oil.
currently i use 3 parts 5w30 and 1 part 5w20.
heavier oils actually INCREASE the wear. thinner oils flow faster and lubricate better, and keep the engine parts cooler. using a thicker oil is asking for trouble.
#1724768 - 12/30/09 11:23 AM Re: Older car? thicker oil? [Re: edwardh1]
demarpaint Offline
Loc: NY
Why? If it aint broke don't fix it.
God Bless Our Troops
#1724770 - 12/30/09 11:24 AM Re: Older car? thicker oil? [Re: Captain_Klink]
98dakarM3 Offline
Loc: Oregon
As a rule, no.
But sometimes it makes sense to use a thicker oil if you are trying to cure an issue such as oil burning.
10 VW TDI - FF
09 FOCUS SES - MC 5W-20 & MC FL-910
09 SONATA - PYB 5W-20 & WIX GOLD
05 SUBURBAN - NAPA Synth 5W-30 & Napa Gold
#1724775 - 12/30/09 11:30 AM Re: Older car? thicker oil? [Re: 98dakarM3]
bepperb Offline
Loc: Milwaukee, WI
"As a rule, no.
But sometimes it makes sense to use a thicker oil if you are trying to cure an issue such as oil burning."
+1
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
#1724814 - 12/30/09 11:49 AM Re: Older car? thicker oil? [Re: bepperb]
JHZR2 Offline
Loc: New Jersey
Thicker has a slight correlation with less volatile, two schools of thought here, one, a less volatile oil will burn less in a consumption prone high mileage engine. However, a less volatile oil may also leave deposits, so it is a game of relevance.
Thicker willy-nilly for thickness sake without reason doesn't do anything for you, IMO.
#1724819 - 12/30/09 11:55 AM Re: Older car? thicker oil? [Re: edwardh1]
tig1 Offline
Loc: Illinois
If you have taken very good care of you engine then it would be NO. My sons 91 Ranger has 338,000 miles and still uses 10-30 M1. as it was when it was newish. I have had the same experience myself.
2007 Ford Fusion 173,000 miles
M1 0-20 AFE
2007 Ford Focus 151,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#1724833 - 12/30/09 12:08 PM Re: Older car? thicker oil? [Re: Captain_Klink]
Zaedock Offline
Loc: Massachusetts
Misinformation.
2012 F150 Ex-cab 5.0L/2004 Malibu Maxx LT
1992 YJ "The Heep"/1994 Olds Cutlass Ciera 3.1/auto
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#1724839 - 12/30/09 12:10 PM Re: Older car? thicker oil? [Re: tig1]
labman Offline
Loc: Nothern USA
My 77 LUV with 144K still holds 60 psi oil running 70 on the interstate with 5W-30. The oil light never comes on at idle. Oh, I never have to add more oil either.
#1724840 - 12/30/09 12:11 PM Re: Older car? thicker oil? [Re: Captain_Klink]
seremban Offline
Loc: Malaysia
Can anyone explain why using heavier weight oil increase wear ?
Thank You.
#1724848 - 12/30/09 12:20 PM Re: Older car? thicker oil? [Re: seremban]
Zaedock Offline
Loc: Massachusetts
Thank You.
Thicker oils can't lubricate either. smirk
...and your engine will run hot.
#1724885 - 12/30/09 12:40 PM Re: Older car? thicker oil? [Re: edwardh1]
PT1 Offline
Loc: near the mistake
No, 210,000 maybe. But 5w30 is fine all the way if you maintain the engine with reasonable oil change intervals.
Oils well that ends well...
#1724887 - 12/30/09 12:43 PM Re: Older car? thicker oil? [Re: labman]
mechtech2 Offline
Loc: Chicago Area
5-30 to 10-40 is a decent jump thicker.
I would never want that cold rating larger, only smaller [the 5 and 10 #s].
110K is not the great achievement it once was. It's not really a lot on a newer style car.
If you are not burning oil, there should be no reason to switch.
If there is an odd known problem like low oil pressure when hot, you cold try a thicker oil.
#1724904 - 12/30/09 12:50 PM Re: Older car? thicker oil? [Re: edwardh1]
Nickdfresh Offline
Loc: Buffalo, NY
Ten to fifteen years ago, maybe--as a general rule. Now, not-so-much, unless there has been a history of lack of maintenance, severe service, excessive consumption, etc.
That being said, almost all "high mileage" oils are thicker at temp in the same grades, which is why I would only ever use one in the warmer months...
