Hi all,
I've been waiting with baited breath for this oil report
Please read the background I've written prior to interpretation.
This UOA shows the following:
26-36k on engine: Amsoil Series 2000 0w30
36-50k on engine: Amsoil SSO 0w30
50k-66k on engine: Amsoil SSO 0w30
~66k-77k on engine: Pennzoil Platinum 5w30 (this UOA posted now)
Sump capacity: 5.5 quarts.
Consumption: From 0-26k miles, it was 1 quart every 1500-2000 miles. Switching to Series 2000 dropped that to 3-4k. Amsoil SSO was routinely 4-5.5k per quart.
The Pennzoil Platinum seemed to increase at first and then slow down towards the end. I added 2.5 quarts total to this sump, or about 1 quart per 4000 miles. Seems reasonable given my harder driving (see below).
Oil filters: Purolator PureOne every time, except 36-50k I used a Amsoil EaO oil filter
Air Filter on all: K&N Panel Filter. The K&N was cleaned at 36k and then run non-stop till 66k and freshly cleaned. So this most recent UOA shows the effects of, essentially, a completely cleaned and re-oiled K&N filter.
Additives: None
Gasoline: Any and all, almost always 93 octane and never below 92 octane.
Tune: Original state of tune. Valves have not yet been adjusted, original spark plugs.
Driving Conditions: I still commute 65 miles round trip each day, but for the past 4 months I've started doing some more in between trips (grad school). On this oil change, I've never driven the car harder. I cruise at 4000 rpms (about 80mph). I hit redline/tap the 8300 rpm fuel cut somewhere between 5-8 times a day, and usually in 2nd, 3rd, nd 4th gear. I sometimes let the engine brake at 6000 rpms for a minute or two.
I never beat on it till it reaches operating temperature (i.e. 15+ minutes of driving). I never drive it until it's been idling for 15-20 seconds, in the cold it's more like 45-60 seconds. I never idle it for more than 2-3 minutes straight. I typically drive it between 3000-4000 rpms to help it warm up.
So, enough with that, the results:
My interpretation: Fantastic! I am extremely pleased with the trending, the silicon considering a freshly cleaned K&N, the extreme lack of anything exhibiting a concern. The viscosity shear is reasonable and did not appear to affect the oil's ability to protect. Also, SSO definitely stayed in grade but was hanging on by a thread (albeit, given significantly more mileage). So I consider the fact that PP only sheared slightly out of grade to be ok.
Anyway, I'm overall just very very happy. My car used a total of 8 quarts of oil here (5.5 quart fill-up + 2.5 quarts top-off). That's $32 + a $6 oil filter for this 10k run. SSO was running me about $78 for 16k worth of oil interval (9 quarts @ $8 per quart + $6 oil filter), so I'm saving and I intend to run the next fill of PP to 12k miles.
Lastly, I took a look through my oil fill cap at the camshaft lobes I could see. They quite literally look brand new. I'm going to take the valve cover off next winter for my 100k tune-up and take some detailed pictures.
Any and all thoughts welcome.
Joe
Additives: None
Joe
