Juicers: anyone have one?
by car51
06/25/16 10:57 AM
Tips for cooling down a hot car
by mclasser
06/25/16 10:52 AM
Battery bit the dust
by aquariuscsm
06/25/16 09:58 AM
Walmart.com Chevron Supreme 5 quart in stock.
by BigD1
06/25/16 09:56 AM
Consensus on 12 month interval oil changes
by accobra66
06/25/16 09:11 AM
Truck Wars
by AirgunSavant
06/25/16 09:06 AM
A good read....The more things change....
by ryan2022
06/25/16 08:46 AM
Opinions on linksys 1900acs router
by madRiver
06/25/16 08:18 AM
Pick my oil change
by ram_man
06/25/16 08:09 AM
Weird!
by AirgunSavant
06/25/16 08:05 AM
Good Deed?
by AirgunSavant
06/25/16 08:02 AM
Vibration after rotating tires and painting wheels
by Drew99GT
06/25/16 08:02 AM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
82 registered (ag_ghost, andyd, adolan21, 007, AirgunSavant, 901Memphis, 7 invisible), 2119 Guests and 11 Spiders online.
58257 Members
66 Forums
250781 Topics
#1708882 - 12/15/09 09:08 PM can thick oil cause a leak?
exls Offline
Loc: San Francisco
People always say that thin oil can cause leaks, but does thick oil cause leaks? My dads always uses 10w40 in his 94 subaru impreza and the valve cover gasket is leaking. The car calls for 5w30 and were in california.
1990 Acura Integra Havoline DS 10w30 Motorcraft FL810
1999 Honda Civic Mobil 1 10w30 Wix 51334
#1708890 - 12/15/09 09:17 PM Re: can thick oil cause a leak? [Re: exls]
lipadj46 Offline
Loc: Western NY
He probably needs to tighten his valve cover bolts.
2002 Toyota Corolla, 65k miles, Mobil 1 0w30
2004 WV Passat Wagon 94k Miles, Rotella T6
2002 Land Rover Discovery Totaled RIP
#1708897 - 12/15/09 09:19 PM Re: can thick oil cause a leak? [Re: exls]
Gunatics_Adler Offline
Loc: Iowa, USA
The only thing I can think is that the gasket is going out on its own, and a thicker oil might be pooling a bit more since it wont drain down as fast as a 30 weight oil. But no, it should not cause a leak. The gasket just needs replacing.
1970 Nova SS 396
1986 Monte Carlo SS
2006 Scion tC
2007 Yamaha Virago XV250
1969 Honda CB750
#1708898 - 12/15/09 09:19 PM Re: can thick oil cause a leak? [Re: lipadj46]
JohnBrowning Offline
Loc: USA
No thick oil cannot cause leaks. Have you ever stoped and thought about how much empty space their is in an engine???Oil viscosity has nothing to do with leaks any more then sacrificing a chicken would!No voodoo in motor oil!
#1708912 - 12/15/09 09:32 PM Re: can thick oil cause a leak? [Re: JohnBrowning]
CROWNVIC4LIFE Offline
Loc: Miami-Dade County
I was trying to figure out why exls said thin oil would cause leaks..If that was the case there would be a ton of leaks out there with all those people using 5w20...That would include a ton of patrol cars.
05 Ford Crown Vic
5W20 Motorcraft Full Synthetic
Bosh D3410 Filter
07 Merc Grand Marquis
Motorcraft Filter.
#1708932 - 12/15/09 09:46 PM Re: can thick oil cause a leak? [Re: CROWNVIC4LIFE]
exls Offline
Loc: San Francisco
I may have said it in a wrong way. I meant to say that people say thin oil can cause leaks in cars that have been abused.
#1709006 - 12/15/09 10:50 PM Re: can thick oil cause a leak? [Re: exls]
calvinnnnnnnnn Offline
Loc: ca
reason why it is leaking is because the seals are worn
Valvoline Synpower all day every day
#1709027 - 12/15/09 11:06 PM Re: can thick oil cause a leak? [Re: calvinnnnnnnnn]
Black_Thunder Offline
Loc: Wisconsin
gaskets get worn/brittle over time, excessive heat and cool-down and what not over and over again in cycles.
sucks :)
I'd buy Callahan autoparts if I could.
#1709092 - 12/16/09 12:25 AM Re: can thick oil cause a leak? [Re: Black_Thunder]
haci_corolla Offline
Loc: IA
why does everyone think that using diff. weight oils can stop leaks that is a result of not maintaining your car.. yes there are other things to do other than changing oil.
#1709184 - 12/16/09 06:11 AM Re: can thick oil cause a leak? [Re: haci_corolla]
Zaedock Offline
Loc: Massachusetts
Are you saying that engine leaks are caused by a lack of maintenance? What about poor materials? The rear main seal on my wife's Malibu Maxx started seeping oil at 45K miles with perfect maintenance. There was no way in heck I was changing it! After several OCI's of Supertech HM, the seepage has almost stopped and not returned and it just hit 68K miles.
2012 F150 Ex-cab 5.0L/2004 Malibu Maxx LT
1992 YJ "The Heep"/1994 Olds Cutlass Ciera 3.1/auto
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#1709225 - 12/16/09 07:20 AM Re: can thick oil cause a leak? [Re: Zaedock]
cchase Offline
Loc: New England
I think there are always cases of seals just going, regardless of maintenance, care, or usage.
#1709359 - 12/16/09 09:36 AM Re: can thick oil cause a leak? [Re: cchase]
rengnath Offline
Loc: Milwaukee, WI
+1
I have heard about alot of rear seal problems from chevy v6 engines in the malibus.
I changed to sythetic in my truck at 90k and it started to leak from the front main seal - the guy before me had all the records of oil changes, and the truck was a 2005 so it wasnt old. Just bad luck I guess.
I agree completly though with seals going, regardless. Its part of having a car.
Edited by rengnath (12/16/09 09:36 AM)
05 Dakota SLT - Quad Cab - 4.7l - 4x4
SC Equipped - Airaid CAI - MBRP T304 Duals - Ported TB
105k - Valv Max Life Syn Blend - K&N Oil Filter
#1709454 - 12/16/09 10:36 AM Re: can thick oil cause a leak? [Re: JohnBrowning]
PT1 Offline
Loc: near the mistake
Not what I hear...chicken blood will degrade seals....... hornets
Oils well that ends well...
#1709672 - 12/16/09 01:57 PM Re: can thick oil cause a leak? [Re: Zaedock]
mechtech2 Offline
Loc: Chicago Area
Using a thicker oil is going to slow down leaks and burning, because it's THICKER!
This is the oldest oil fact in the book!
Thicker oil does not fix mechanical problems, but can attenuate them.
#1710120 - 12/16/09 08:43 PM Re: can thick oil cause a leak? [Re: rengnath]
bluesubie Offline
Loc: NJ
+1 ...
+2
My wife's '99 OB is developing a left valve cover seal leak and I (or the dealer) have done all of the oil changes on it since new mainly using xW-30 with a couple of experimental runs on xW-40.
Recently had both valve cover seals replaced on a '00 Impreza RS, although it was bought used with 60k on it and it currently has 90k.
-Dennis
'04 Subaru Forester 2.5XT
Motul X-clean 5W-30
