nearly 20k miles of research gone ....
by meborder
02/07/16 06:46 AM
New - smoke detectors for house.
by bmwjohn
02/07/16 03:45 AM
ProGauge PGO-4612 Oil Filter??
by andrewp1998
02/07/16 01:11 AM
Filter efficiency and diminishing returns
by ToadU
02/07/16 12:19 AM
Change PP after 1000 mi 6 month Short Winter Trips
by WillsYoda
02/07/16 12:00 AM
Tread Life & Curvy Roads
by Nick1994
02/06/16 11:46 PM
What paper engine air filter do YOU recommend?
by Georgiey22
02/06/16 11:20 PM
Power Steering Problems.......
by qwerty1234
02/06/16 10:58 PM
CLR repair of completely blocked heater core/hose
by DoubleWasp
02/06/16 10:55 PM
FS Ford racing Fiesta exhaust system
by mv6845
02/06/16 10:27 PM
Inner Tie-rod removal
by Sawdusted
02/06/16 09:54 PM
What's a good price for a 2013 4Runner?
by Gebo
02/06/16 09:34 PM
Nazmorgul, bhans, truthtracer, Recreator, 18LateModelFan
56842 Registered Users
49 registered (Al, Branson304, Astro14, Bandito440, BigCahuna, B767capt, 5 invisible), 748 Guests and 212 Spiders online.
56842 Members
66 Forums
244348 Topics
Page 1 of 2 1 2 >
#1708737 - 12/15/09 06:51 PM Valvoline Conventional
buster Offline
Loc: NJ
Quote:
About a year ago Valvoline conducted a survey of various 5W-30 conventional products on shear stability and stay-in-grade performance. We went to our local Advance Auto Parts and purchased quarts of the products listed below. We noted that each product was currently labeled with the API SM donut and carried the ILSAC GF-4 starburst. I have included the results of the ASTM D6278 Kurt Orbahn (Bosch diesel injector) test which is typically used to evaluate stay-in-grade shear performance for engine oils. The current API requirement for BOI or VGRA (baseoil interchange or viscosity grade readacross) purposes for a 5W-30 stay-in-grade limit is 8.5cSt. Any 5W-30 that shears below this viscosity does not meet this API requirement for BOI or VGRA. The 8.5cSt viscosity limit is actually below the SAE J300 lower viscosity limit of 9.3cSt. for a SAE 30 grade because the Kurt Orbahn test is more severe than the Seq VIII engine test used to evaluate shear stability when running an API oil licensing program. European ACEA requirements are more severe requiring a higher performance level and a stay-in-grade pass uses the SAE J300 viscosity lower limits. So a 5W-30 must retain a minimum of 9.3cSt after the test. Out of all the oils tested, only the Valvoline oil showed the ACEA level of stay-in-grade performance.
Product Name Valvoline Premium Conv, Castrol GTX, Havoline,Mobil Clean 5000, Quaker State, Pennzoil
SAE Grade all 5W-30
Kinematic Viscosity @40C,cSt: 60.17, 60.59, 54.90, 60.16, 62.46, 61.07
Kinematic Viscosity @100C,cSt: 10.66, 10.59, 9.71, 10.55, 10.43, 10.49
ASTM D6278 Kurt Orbahn Shear (30 pass)
Kin Vis @ 100C, cSt after Shear: 9.42, 9.04, 8.89, 8.8, 8.68, 8.63
From Valvman. 2008.
#1708758 - 12/15/09 07:09 PM Re: Valvoline Conventional [Re: buster]
defektes Offline
Loc: Hesperia, CA, USA
Good thing I use valvoline over the competetion!
well when chevron supreme is not on sale
heheh.
Edited by defektes (12/15/09 07:09 PM)
2002 GMC Sierra 5sp. 4.3L 145K ST3980 E-Core
Chevron Supreme 5w-30, Amsoil Synchromesh In Tranny
Valvoline SynPower 75w-90 Gear Oil In Rear
#1708769 - 12/15/09 07:19 PM Re: Valvoline Conventional [Re: defektes]
gfh77665 Offline
Loc: Southeast Texas
Val. has worked great for me! MaxLife rocks!
#1708784 - 12/15/09 07:40 PM Re: Valvoline Conventional [Re: defektes]
heypete Offline
Loc: Tucson, AZ
Orig: Original (pre-test) viscoscity.
AT: After test viscoscity.
%Diff: Percent difference.
Results are sorted by percent difference.
Code:
Brand		Orig	AT	%Diff
Havoline	9.71	8.89	8.82
Valvoline	10.66	9.42	12.35
Castrol GTX	10.59	9.04	15.79
Mobil 5000	10.55	8.8	18.09
Quaker State	10.43	8.68	18.32
Pennzoil	10.49	8.63	19.46
Looks like Havoline seems to shear less than the others, in this particular test.
2006 Toyota Camry LE (4-cyl, auto, 2AZ-FE) | Mobil Clean 5000 5W-30
#1708816 - 12/15/09 08:05 PM Re: Valvoline Conventional [Re: heypete]
river_rat Offline
Loc: Iowa
Havoline is great oil, IMO.
Valvoline, Castrol, and Havoline are my favorites.
Although, for some strange reason, Kendall GT-1 conventional 10W-40 and 20W-50 burns less than about anything in my air-cooled VW engine.
#1708872 - 12/15/09 08:59 PM Re: Valvoline Conventional [Re: river_rat]
ThirdeYe Offline
Loc: Walker, MI
Gotta love Havoline, sheared the least.
99 Pontiac Firebird - 91k - Pennzoil Platinum 5W-30/Fram Extended Guard XG3980
08 Scion tC - 112k - RP 0W-20/Fram Ultra XG4967
#1708939 - 12/15/09 09:53 PM Re: Valvoline Conventional [Re: ThirdeYe]
aquariuscsm Offline
Loc: South Texas,USA
Valvoline has always been my fave oil. I experiment alot,but in the end I always go back to Valvoline.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Syntec 10W40/Fram Ultra
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Mobil 1 ATF
Redline Water Wetter
#1708957 - 12/15/09 10:10 PM Re: Valvoline Conventional [Re: heypete]
gfh77665 Offline
Code:
Brand		Orig	AT	%Diff
Excellent info! By chance do you have more, regarding 5-20 and/or 10-30? Thanks!
#1708982 - 12/15/09 10:28 PM Re: Valvoline Conventional [Re: gfh77665]
heypete Offline
Loc: Tucson, AZ
It's just the information in the original post. I just tossed it into a spreadsheet, crunched the numbers on the percent difference, and posted it.
I'd be happy to crunch any numbers you throw at me. smile2
#1708986 - 12/15/09 10:30 PM Re: Valvoline Conventional [Re: heypete]
gfh77665 Offline
Maybe Buster has 5-20 & 10-30 numbers, too?
#1709000 - 12/15/09 10:42 PM Re: Valvoline Conventional [Re: gfh77665]
killagt Offline
Loc: MS
I though PYB is best choice for dino oil ? dint we all love PYB ? lol
#1709025 - 12/15/09 11:04 PM Re: Valvoline Conventional [Re: killagt]
defektes Offline
I kinda chuckled to myself seeing penzoil products at the bottom of the list.
#1709029 - 12/15/09 11:07 PM Re: Valvoline Conventional [Re: killagt]
doitmyself Offline
Loc: MI
I know nothing about oil chemistry, so take this for what it's worth.
A few years ago I had communications about HDEO with the late Stinky Peterson (RIP) of Butler Labs and, IF I REMEMBER CORRECTLY, he told me that the Orbahn shear test had "issues" when using it to compare oil shearing in the real world. In my case, JD Plus 50 ranked worst for shearing in a Schaeffer's Orbahn report, but in Mark's data of over a dozen HDEO's, it was in the middle for shearing (and better than some respected names).
I don't have those e-mails any more and I hope someone more knowledgeable will chime in. Mark "almost" implied that using that test alone was almost like using the 4 ball wear test.
Again, I confess no knowledge of this stuff, I don't report this as proven fact, and hope someone else will educate us.I offer this info to encourage debate and learning.
Here is one web report that questions the test:
ftp://ftp.astmtmc.cmu.edu/docs/diesel/hdeocp/minutes/2001/hdeocp.2001-06/0601ATT18.PDF
"Field data from multiple tests indicates:
Kurt Orbahn will rank oils differently than the field
OK within a VII chemistry but not across chemistries
Degree of protection assumed from KO test may be less than
in the real world"
Edited by doitmyself (12/15/09 11:21 PM)
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#1709365 - 12/16/09 09:43 AM Re: Valvoline Conventional [Re: doitmyself]
asamek Offline
Loc: Mississippi
Ruh Roh.
In my last trip into the sixth ring of Hades (Wal Mart), they were out of my standard Motorcraft 5W-20, so I picked up a jug of PYB instead for the next 5k OCI.
I'd go back and swap it out for some of the Valvoline, which was $2 a jug more, but that would mean another trip across the River Styx into the realm of darkness.
So the question is, will my little 3.3 be OK over the next 5,000 miles with the YB, or do I risk my eternal soul by again entering the gates of {edited for cuss word} to save it from certain destruction? hide
'06 Town & Country 3.3
'98 Regal GS 3.8
I'm OCD about OCD
#1709407 - 12/16/09 10:10 AM Re: Valvoline Conventional [Re: asamek]
river_rat Offline
Loc: Iowa
You'll be fine.
Page 1 of 2 1 2 >
