Volkswagen Looks to Build Its Own ‘Gigafactory’
by HTSS_TR
05/27/16 04:55 PM
QSAD 5W20 UOA 5,504 miles 2011 TAURUS 3.5
by dustyroads
05/27/16 04:48 PM
Why you need a dash cam
by Rand
05/27/16 04:12 PM
Performance exhaust question
by 007
05/27/16 04:08 PM
Positive results with BG109
by rainman49
05/27/16 03:11 PM
I have have put a lot of thought into this oil.
by Mathew_Boss
05/27/16 02:45 PM
CARQUEST Premium Oil Filter
by AirgunSavant
05/27/16 01:40 PM
The world's most harrowing route to school
by HTSS_TR
05/27/16 01:18 PM
STP 3614 Purolator cut and view
by sprite1741
05/27/16 12:58 PM
Finally saved up and bought my 1st car
by rocky8314
05/27/16 12:33 PM
Yellow dot and valve stem alignment
by qdeezie
05/27/16 12:30 PM
Shipping from Amazon
by grampi
05/27/16 12:14 PM
LEVY, Timmytimmy, Peakboy91, TimingBeltKing, watergate528
57997 Registered Users
71 registered (2oldtommy, aquariuscsm, 01_celica_gt, AlienBug, afree, 901Memphis, 3 invisible), 1754 Guests and 316 Spiders online.
57997 Members
66 Forums
249492 Topics
#1701996 - 12/09/09 07:21 PM Car runs rough at idle
DreamerGT Offline
Loc: austin,tx
This is the code I get. P0352 Ignition Coil Primary B / Secondary Circuit Malfunction, all the cops(coil on plugs)are new about 8 months old and the spark plugs were replaced a year ago. I starts fine, its when its idling at a stop light or whatever it will go rough. But when I start driving it will drive rough for a little bit, then snap out of it and drive fine and have full power again. Any idea's? thanks
02 Mustang GT,5w-30 Royal Purple, Redline D4
06 Pontiac Grand Prix GT 5w-30 Castrol Edge
05 Chevy Cobalt 5w-30 Mobile 5000
#1702026 - 12/09/09 07:38 PM Re: Car runs rough at idle [Re: DreamerGT]
tig1 Offline
Loc: Illinois
When the engine starts to idle rough pull over to a stop, leave the engine running and place a cloth up to the tail pipe. Don't completly close the pipe off but leave a slight gap between the pipe and cloth. If there is a miss it will suck the cloth up to the pipe with every miss fire. Ignition problem. It will make a pop pop sound with the miss. If no miss then look else where for your idle problem. Injector etc.
Edited by tig1 (12/09/09 07:40 PM)
2007 Ford Fusion 180,000 miles
M1 0-20 AFE
2007 Ford Focus 154,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#1702401 - 12/10/09 01:54 AM Re: Car runs rough at idle [Re: tig1]
mechtech2 Offline
Loc: Chicago Area
He already states that there is a miss.
Why check for it at the tailpipe? - that is silly.
Can you quickly disconnect power to each coil when it is misfiring?
A good coil/plug will show even worse, and a bad one no change.
Even though an ignition code is being thrown, it may be a vacuum leak or fuel delivery problem. Maybe even an EGR thing.
Sometimes computers give codes for left handed reasons.
#1702418 - 12/10/09 02:49 AM Re: Car runs rough at idle [Re: mechtech2]
mechanicx Offline
Loc: Ohio
I think that means there is a problem at coil number 2 or b. What kind of plugs and coils did you use as replacements? You might want to check the wiring harness to that coil.
#1703260 - 12/10/09 06:16 PM Re: Car runs rough at idle [Re: mechanicx]
DreamerGT Offline
Loc: austin,tx
I got the coils off of ebay. Non oem all 8 for $70 and the plugs are standard motorcarft plugs. I will check the wiring harness and see what I come up with.
#1703268 - 12/10/09 06:20 PM Re: Car runs rough at idle [Re: DreamerGT]
mechanicx Offline
Loc: Ohio
Also if possible I think you could swap coils and if the problem moves with the coil you know that's it. Or maybe you could check the coils primary and secondary resistance against specs.
#1703366 - 12/10/09 07:37 PM Re: Car runs rough at idle [Re: mechtech2]
Gary Allan Offline
Loc: Pottstown, PA
That would produce a rough idle that totally evaporated in the upper power levels.
If you have a vacuum actuated EGR, then pull the hose off of the supply side and apply vacuum (suck on it). If the engine stumbles ..then it's probably closed like it should be. If nothing happens then it's probably stuck.
http://lube-direct.com/gallan/
#1704879 - 12/12/09 08:32 AM Re: Car runs rough at idle [Re: Gary Allan]
another Todd Offline
Loc: Southern CA
Good point Gary.
2015 Ford F250 Diesel Crew Cab FX4
2005 Ford Focus ZX4
2007 Ford Focus ZX4
2005 Ford Escape
2006 Ford Escape
