Originally Posted By: morrison250r
AV gas is not suitable for a surface engine. It is designed for an entirly diffferent purpose. Example, widely varying tempatures and altuide, prolonged peroids of near constant loads and engine speed, exc. Lead works well as a lubircant. Engines will run cooler and last longer. For best results the jetting should be rechecked and yes it is bad for the earth. If you do not require the extra octant in your fuel it will be of no bennefit. Why do you want to use it?
Visit macdizzy.com there is a lot of info. the forum is members only (must pay) If you are serious about your 2-strokes it is a must!
AVGAS is a fantastic fuel for certain applications. It works very well in larger two strokes. Plus, it contains NO ALCOHOL. So engine life, jetting and performance are all properly managed using AVGAS.
However, it does not provide the worlds best throttle response in smaller, high RPM two strokes. There are many reasons for this. But, larger engines, like sno toys will do perfectly well on AVGAS.
Still, I dare you to find pump auto gas that is higher quality, more consistent and higher octane.
