WRX or GTI?
by GumbyJarvis
58 minutes 8 seconds ago
Single cylinder versus twin
by mjoekingz28
Today at 01:12 AM
Mobil Super Syn vs ...others
by Yup
Today at 12:45 AM
2016 WRX
by Silver02ex
Yesterday at 11:58 PM
Class Action Lawsuit Against Oil Filter Company?
by crazyoildude
Yesterday at 11:42 PM
PL10241 Cut Open
by Vegoose
Yesterday at 11:15 PM
Seems like common sense to me......
by Doog
Yesterday at 11:14 PM
Thinking of buying an old diesel Benz
by Diego3336
Yesterday at 10:46 PM
Mobil 1 5W30 5279 Miles 06 Toyota Tacoma V6 401k
by qnyla
Yesterday at 09:43 PM
2007 corolla oil pan steel or aluminum?
by Rolla07
Yesterday at 09:07 PM
Taiwan DMV "Mechanical Knowledgee" Test Question
by Ducked
Yesterday at 08:56 PM
Paint correction
by mjoekingz28
Yesterday at 08:55 PM
engus, Rob_Pol, Nick24w, SkipKaye, MikeHancho
56899 Registered Users
29 registered (crinkles, Ducked, dgunay, DSparks, c502cid, deoxy4, 3 invisible), 423 Guests and 187 Spiders online.
56899 Members
66 Forums
244581 Topics
Page 1 of 2 1 2 >
#170185 - 01/05/06 09:23 AM Dexron III ATF in the engine
ekincam Offline
Loc: SoCal
I accidentally poured 1/2 qt of Mobil 1 Synthetic Dexron III ATF into my engine thinking it was motor oil.
Is it safe to leave it in there and drive the car? Do I need to do a drain and refill? Or...???
#170186 - 01/05/06 09:25 AM Re: Dexron III ATF in the engine
ARB1977 Offline
Loc: North Texas
It might clean things out but for safe measure drain it out.
#170187 - 01/05/06 10:05 AM Re: Dexron III ATF in the engine
Big Jim Offline
Loc: Thousand Oaks, CA
Not all that many years ago, it was common to use ATF as an oil additive, especially to clean up a little bit of lifter tick.
Today's oils are much better, and instead of improving it, the ATF probably slightly degraded it. I wouldn't worry about it unless you are going after an ultra long oil change interval. Just get rid of it with the next oil change.
#170188 - 01/05/06 10:11 AM Re: Dexron III ATF in the engine
dj215 Offline
Loc: philly
i think the small amount of money to replace the oil is worth not putting ur engine in any danger of shortening its life span
#170189 - 01/05/06 10:16 AM Re: Dexron III ATF in the engine
Strjock81 Offline
Loc: Illinois
I accidentally did the same thing in my 99 powerstroke a couple years ago--had a case of oil I had set on the shop floor--wife took a bottle of atf out of the garage when she was cleaning up and stuck it in there thinking it was just random stuff. Bottles were similar and I had 1/2 a quart or so in before I realized it. I left it in and it didn't seem to hurt anything. Of course that is a 15 qt. sump too. [Smile]
#170190 - 01/05/06 10:29 AM Re: Dexron III ATF in the engine
CATERHAM Offline
Loc: Burlington, Ontario, Canada
What engine oil is in you sump and how many quarts? Mileage on oil?
ATF is very light; about 7.5 cSt @ 100C so you've lightened up the oil abit; say 0.25 cSt assuming a 30wt oil and a 5 qt sump. I personally wouldn't worry about it.
Peter
#170191 - 01/05/06 10:30 AM Re: Dexron III ATF in the engine
ekincam Offline
Loc: SoCal
4.5qt vs 15qt makes a difference I would think.
I guess I'm gonna drain and refill.
#170192 - 01/05/06 10:43 AM Re: Dexron III ATF in the engine
Steve S Offline
Loc: East of IGO
The half qt of atf won't hurt a thing.
#170193 - 01/05/06 06:46 PM Re: Dexron III ATF in the engine
rmattingley Offline
Loc: La Crosse, Wi
I would drain it. My old man tells a story of how he locked up a motor with atf. Oil is cheap! Enginesx are expensive. It might not seem to hurt now, but what about 50k later. Just drop the oil and start with new.
#170194 - 01/05/06 07:48 PM Re: Dexron III ATF in the engine
TallPaul Offline
Loc: By Detroit
Don't worry about it. You could add half a bottle of Synpower Oil Treatment to bring the additives back up (and beyond), but unless you have a small sump, like 3 quart, I don't see a problem.
How do you lock up an engine with ATF unless poured too fast into the intake and hydrolocking a cylinder?
#170195 - 01/06/06 08:03 AM Re: Dexron III ATF in the engine
Curious Kid Offline
Loc: Vermont
A co-worker brought his older BMW in the shop for some work (BMW dealer?), and he also mentioned about the ticking at start-up. He told me they changed out about a qt of engine oil with ATF. It cured the start-up ticking mostly due to lowering the cold temp. viscosity enough as ATF as little in the way of additives as compared to engine oil. This has been mentioned around here - do a seach on ATF.
The only concern other than additive dilution is how the atf may react with the mosture and other blow-by contaiminents that that would otherwise not be present in a transmission. How about thermal stability also?
Others know a lot more than I on these matters, be this is just some things that pop up in my mind.
By the way, the last I heard of this coworker's BMW is it's still running fine, espcially after replacement of his right rear wheel bearing.
#170196 - 01/06/06 08:44 AM Re: Dexron III ATF in the engine
Bio-T Offline
Loc: London, AR
20W oil with a red tint will not cause a catastrophic result. Not something I personally would do, but in this case, not a real problem. In fact we have a BITOG member that ran a quart of ATF in a 4 cylinder engine. It did not remove varnish or any other claimed cleaning. He ran it 6K as I remember. This was about 3 years ago and Rugerman, Patman, Joe12, Bob, myself all saw the pictures and explanation. The gent did not want it published.
[Cheers!]
#170197 - 01/06/06 08:47 AM Re: Dexron III ATF in the engine
Mitch Alsup Offline
Loc: Austin Texas
I have a friend that cleaned out his Q45 motor by draining the oil, adding ATF and then idling the engine for an hour and then draing and refilling with normal oil.
#170198 - 01/06/06 08:56 AM Re: Dexron III ATF in the engine
Johnny Offline
Loc: Retired | Wausau, WI
Last year the regional Shell tech rep decided to see what would happen if you ran ATF in your engine. He changed the oil on his company car with all ATF and ran it 3,000 miles. Car never missed a beat and it did not use any ATF. Your 1/2 quart won't hurt anything.
#170199 - 01/05/06 09:01 PM Re: Dexron III ATF in the engine
TallPaul Offline
Loc: By Detroit
I like that story Johnny. Wish I had a company car to experiment on. Always wanted to see what would happen if you ran a tranny filled with only Rislone Engine Treatment.
BTW, the ATF is probably no better or worse than running Rislone and I ran a quart of Rislone every oil change for 175,000 miles and the truck's current owner has it up to 225,000 and running great.
Page 1 of 2 1 2 >
