The point is not the corrosion, it is the wear. The GL-5 DOES pull off brass from the synchronizers. Too many people are hung up on the corrosion thing, which is probably higher in the GL-5, but the issue is wear.
I'm curious myself about the Delo. I like it in the differencial, the time I put it in my 4Runner transmission, I had hard shifting, but I replaced the 80W-90 Delo with 75W-90 GL-4, so I don't know how much effect was by either.
The Delo, with it's borate, will not peel off any brass at all, and can only be corrosive in the presence of water (it is a salt). I know its polar attraction is great in gear boxes, but do not know how well they release in the synchronizer. I should mix up some with the 75W-90 and try it in one of the vehicles where I have GL-4 75W-90, but lets make that a maybe. (I have Borate gear oils in every viscosity from ISO 68 to ISO 680, so mixing isn't a problem. just time.
