Am I cheap or? Oil and filters...
by sw99
05/26/16 09:14 PM
Bought a New Sentra Today!
by mcgophers
05/26/16 09:12 PM
Texas Refinery Corp V. Lubrication Engineers
by Hullthumper
05/26/16 09:06 PM
Motor mount troubles...
by buck91
05/26/16 08:58 PM
need some methods of burping ait out
by snake123
05/26/16 08:54 PM
2010 Mini Cooper, Castrol Edge 0W-30 GC 5153 miles
by nicrfe1370
05/26/16 07:26 PM
Toro (Homelite) string trimmer diaphragm needed
by trouts2
05/26/16 07:26 PM
Wix : 10k miles? (also comparison question)
by Kuato
05/26/16 07:14 PM
Witnessed accident and driver running from scene
by stranger706
05/26/16 07:06 PM
Initial Vehicle UOAs
by GumbyJarvis
05/26/16 06:20 PM
04 C1500 1/2 Ton; P/S Fluid Disappearing
by TexasTea
05/26/16 05:52 PM
TV logos
by chiefsfan1
05/26/16 05:51 PM
watergate528, iamtheanimal, 1991300sl, Rdyno, Darsahn
57993 Registered Users
109 registered (2015_PSD, addyguy, AirgunSavant, abycat, Atlantis, austinlunsford, 9 invisible), 1688 Guests and 188 Spiders online.
57993 Members
66 Forums
249453 Topics
#1683467 - 11/24/09 05:28 PM What Grade Bolt For A Bush Hog "Shear Pin"?
pharmer Offline
Loc: NW Tn.
I have an older Bush Hog rotary mower that doesn't have a clutch. Ran over a stump today & it sheared the PTO pin that goes into the Bush Hog gear box. Did what it was designed to do. Can't find a factory pin as my mower is over 30 yrs. old. Bush Hog dealer tells me to use a 3 inch long, three-eighths diameter bolt with a lock-nut. One dealer says to use a Grade 2 bolt, other dealer says to use a Grade 5 bolt. I don't want to damage my tractor's PTO so I'm inclined to go with the weaker Grade 2 Bolt. Any suggestions or advice? Thanx!
#1683484 - 11/24/09 05:41 PM Re: What Grade Bolt For A Bush Hog "Shear Pin"? [Re: pharmer]
MGregoir Offline
Loc: Bonnyville, AB
I would go with a grade 2. I think they each said a grade in reference to not being grade 8 more than anything.
#1683549 - 11/24/09 06:26 PM Re: What Grade Bolt For A Bush Hog "Shear Pin"? [Re: MGregoir]
HM12460 Offline
Loc: West Michigan
grade 2 bolts are generally accepted to be the norm for shear pins.
2007 Chevy Trailblazer
"Thirsty"
#1683555 - 11/24/09 06:30 PM Re: What Grade Bolt For A Bush Hog "Shear Pin"? [Re: HM12460]
pharmer Offline
Loc: NW Tn.
MGregoir & HM12460, Thanks to both of you for your quick responses. I definitely will be buying Grade 2 bolts to use as "shear pins". Thanks again.
#1683580 - 11/24/09 06:42 PM Re: What Grade Bolt For A Bush Hog "Shear Pin"? [Re: pharmer]
wwillson Offline
Administrator
Loc: Naperville, IL
+1 on the grade 2. I grew up chopping about everything you could think of with Bush Hog mowers - brush, corn stalks, gopher mounds, etc. The mowers are much tougher than the PTO of the tractor, especially if it's a 540rpm. You want the weakest link to be that shear bolt. I'll bet the grade 2 will be in there for years, or until you hit your next stump.
Fastener strength table
Wayne
Edited by wwillson (11/24/09 06:49 PM)
Edit Reason: added link to table
