Originally Posted By: e36'n
Better oil circulation during -30C start-ups, slightly better gas mileage and not having to buy the oil from the dealer for the great discounted price of $18/L
Spirited. I rev it to 8000rpms a couple times a day, after it's fully warmed up of course. I'll be doing it less with my winter tires on though. OCI's would be 7000-10000kms.
So, in other words, you want it to be cheaper than TWS and better in the extreme cold, but you don't want to have to drive like a granny. That narrows it down quite a bit.
If you want it to be cheaper, that cuts out the usual no. 1 suspect, Motul 300V. Just as well, since no 300V has a pour point below -36C, and -- here's something I had forgotten -- TWS has a pour point of -51C:
http://www.castrol.com/liveassets/bp_int...ort_06_08_d.pdf
We also have to cut out Motul's other oils, as well as anything else from overseas.
Everything cheaper than TWS that also flows better in extreme cold is also a LOT lighter when hot.
Red Line and Mobil 1 have 0w-40s that look tempting. If I had a gun to my head and had to pick one of those two, I'd pick Mobil 1; it carries pretty much every OEM certification in the book, is used by factory race teams, and is significantly cheaper than TWS. Mobil also used to recommend it for M engines. However, it's worth noting that they have since withdrawn that recommendation (albeit for reasons unknonwn).
Anything thicker from Red Line has a higher pour point. Mobil 1 15w-50 wouldn't give enough of a benefit in cold weather to be worth the gamble. Anything remotely suitable from Amsoil would either be an outdated street formulation or a racing oil that wouldn't last long between changes. I'm having a hard time thinking of any more examples but the trend seems clear.
-51C is a REALLY low pour point for a 10w-60. There is something special about that oil.
It also must be stressed that TWS is to some extent matched specifically to the metallurgy of your engine, whereas no other oil is.
See what I mean?
Take the gamble if you must, but I can't say I would.
