Camshaft Adjuster Bolts - Replacement ?
by Ndx
06/26/16 05:45 PM
STP Synthetic
by travlnman
06/26/16 04:37 PM
Myliftstand alternative jack stand
by momo
06/26/16 03:33 PM
Kmart sale on Smitty's oil and ATF
by slacktide_bitog
06/26/16 02:53 PM
Napa master pack oil filter price
by Electromotive
06/26/16 02:39 PM
Local Big Lots still has Valvoline next gen 10w30
by Electromotive
06/26/16 01:25 PM
Best Value Differential Oil 75W-90
by KevinP
06/26/16 01:02 PM
kohler 17hp . changed oil , now will not run
by chad8
06/26/16 12:32 PM
Oil change recomendations for '11 Ranger 2.3 Liter
by ryan2022
06/26/16 11:49 AM
Suggestions for 94 Lexus LS400 ATF
by Gasbuggy
06/26/16 11:23 AM
GOST Diesel fueln
by m37charlie
06/26/16 11:10 AM
Old interesting finds
by car51
06/26/16 10:53 AM
Ruturaj, derfderfgoose, ssnead, mtrev, redtacoma
58277 Registered Users
84 registered (Al, Bandito440, aquariuscsm, Astro14, Best F100, BigRalphie, 8 invisible), 1803 Guests and 6 Spiders online.
58277 Members
66 Forums
250841 Topics
#1678999 - 11/20/09 05:41 PM How to read the meter on a battery charger
GhostFlame Offline
Loc: Doylestown, Pennsylvania
Forgive me if this has been discussed.
I have a 4amp 12.6 volt battery charger. No extra settings. the meter jumps to 6 amps when the battery is drained. it moves slowly left to the lower amperage numbers after a while of charging. from left to right the meter reads 1 2 3 4 5 6
When do I know the battery is fully charged? there is no volt meter on the charger.
I had my daughter's battery on the charger for about 16 hours after she left the lights on for like 2 days. the battery jumped to 6 and after about 2 hrs settled down to 4 but never went any lower. the car started but, I would like to know.
Would my handy volt meter be a better indicater? I think 12.6 or 13.2 is the magic number when it's fully charged.
Any help , thanks
2002 BMW X5 3.0 M1 0w-40 trying RT6
1998 VW Jetta 2.0
2004 Honda 1800c V-Twin 110 ci M1 4t Racing 10w-40
#1679005 - 11/20/09 05:46 PM Re: How to read the meter on a battery charger [Re: GhostFlame]
EricF Offline
Loc: SF Bay Area
what happens is the meter shows the amount of amps being pulled.
so when the meter was at 6amps, the battery was drawing 6amps of power to recharge itself. after a while as the capacity gets fuller, it draws less amps, so now you're at your 4. when it gets to 1 or 2, you're at a trickle, and the battery is/should be/close to full capacity.
you have a slow charger, 6amps, so charing for 16hours is normal for an extremely drained battery.
the magic number for a charged battery voltage with no load is 12.3 - 12.5volts at rest.
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
#1679006 - 11/20/09 05:48 PM Re: How to read the meter on a battery charger [Re: EricF]
GhostFlame Offline
That was fast thanks!! very informative.
1998 VW Jetta 2.0
#1679040 - 11/20/09 06:29 PM Re: How to read the meter on a battery charger [Re: GhostFlame]
Mr Nice Offline
Loc: Orlando, FL
Eric,
what is the voltage of the battery when the engine is running ?
What is the range of voltage as the engine RPM increases to redline ?
Thanks
2007 Civic EX
2006 Accord SE
2005 RSX base
#1679104 - 11/20/09 07:24 PM Re: How to read the meter on a battery charger [Re: EricF]
JHZR2 Offline
Loc: New Jersey
If your battery is 42Ah, and flat, it could take 7+ hours at 6A charge to go full. The rates do change, so in reality it takes a bit longer.
Two things though... First, the battery will charge at up to 14.1V - some may feed at a higher voltage. Even after it is full, the battery will have a "surface charge", which keeps it over 13V open-circuit.
Second, a full battery at normal temperature is roughly 12.72V at OCV.
