33022 Members
60 Forums
137289 Topics
Max Online: 941 @ 06/02/10 01:33 PM
#1678155 - 11/19/09 10:44 PM
Significance of an oil having a dual rating?
Loc: ohio, usa
I was looking at oil and I noticed Mobil 5000 was the only conventional oil that had a dual API rating for spark engines and diesel, SM/CF. And Mobil 1 and Castrol Syntec were the only synthetics that had the dual rating of SM/CF.
What is the significance of the oil having a dual rating besides use in a diesel and for gasoline engine use? I imagine some of these other oils probably are CF rated, it's just not listed on the product but is in its datasheet. Also, CF is a pretty low/old diesel rating, so what's the signifance of a higher or lower diesel rating in regard to gasoline engine use?
#1678180 - 11/19/09 11:10 PM
Re: Significance of an oil having a dual rating?
[Re: mechanicx]
Loc: Canada
It means the oil is slightly more robust than an SL/SM oil with no C rating......
2002 Chevrolet Cavalier, 2.2 OHV, Auto, 147k miles. Petro-Canada Supreme 5W-30; Purolator oil filter; Motomaster air filter.
#1678187 - 11/19/09 11:20 PM
[Re: addyguy]
Loc: ohio, usa
It means the oil is slightly more robust than an SL/SM oil with no C rating...... Yeah I figure it means the oil has a higher TBN, possibly detergent etc. I guess what I was asking about is the specifics and the pros and cons of having a Cx rating or a higher/lower C rating for use in gasoline engines without having to do a bunch of researching it myself.
#1678209 - 11/19/09 11:50 PM
[Re: mechanicx]
Loc: Chicago Area
Oils like Delo,Delvac, Rotella, etc., also have dual ratings . I don't think there is significance in the dual rating other than what it plainly stated.
As to having an older diesel rating, it may have more sulfur.
#1678291 - 11/20/09 03:10 AM
[Re: mechtech2]
Loc: Kuwait
Almost all oils on the market here (except Motorcraft, Mopar and ACDelco amongst a few others) have a dual gas/diesel rating - the most common being SL/CF, but there's one or two cheaper SJ/CF oils available.
With a CF rating, I do not think there's too much of a benefit, although it's probably more robust than a standalone SM oil in your case.
Now if it's an oil intended for diesel use with a gasoline rating, such as Pennzoil Long Life Gold, I reckon it's a much tougher oil - a CJ-4/SM rating in case of Pennzoil LL Gold.
00 Mitsubishi Pajero/Montero: Pennzoil Platinum 5W-30/Hyundai 26300-35503 01 Grand Marquis: Liqui-Moly Synthoil Energy 0W-40/Motorcraft FL-820S
#1678447 - 11/20/09 08:51 AM
[Re: Falcon_LS]
Loc: Chicago Area
I don't think it matters which rating comes first or second. If the ratings are there at all, they apply fully.
#1678846 - 11/20/09 03:42 PM
[Re: mechtech2]
Loc: ohio, usa
Well let me ask the question a different way. What is the difference between a CF oil and a higher rated on like CJ?
#1679450 - 11/20/09 11:46 PM
[Re: mechanicx]
Loc: Airlie Beach Australia
Hi, mechanicx - You asked this: "Well let me ask the question a different way. What is the difference between a CF oil and a higher rated on like CJ?"
Answer - a great deal!
If you use a CF lubricant in an engine calling for a CJ-4 you will have problems - usually major ones! Mostly these will be typically but not exclusively deposit related. CJ-4 lubricants have much better soot handling abilities than CF versions amongst many other things
If you use a CJ-4 lubricant in an engine that specifically calls for a CF lubricant and the same situation is likely to occur. Mostly this will typically be glazing and etc
Many CJ-4 lubricants are rearwards compatible - some are not!
The CF spec. (from around mid 1990s) requirement was usually directed at pre-combustion type engines and where higher sulphur fuels may be encountered. It was not directed at heavy high speed heavy diesel engines of that area - CF-4 was!. Now, high speed late technology small displacement diesels also easily use CF
Mechtec2 - The order of the API's ratings denotes the "primary" purpose of the lubricant. If the "C?" rating comes first it is a HDEO as we call them. If the "S?" rating is first it is primarily a PCMO. The formulations apply accordingly
Edited by Doug Hillary (11/20/09 11:52 PM) Edit Reason: Accuracy - spelling
Regards Doug
06 Mercedes Benz CLK (M1 0W-40 SM/CF) 01 Porsche Boxster (Delvac 1 5W-40 CI-4/SL) 08 Suzuki Burgman AN650K8 (Castrol R4Superbike 5W-40 SG/MA)
#1679463 - 11/20/09 11:57 PM
[Re: Doug Hillary]
Loc: ohio, usa
Thanks Doug Hilliary. I guess what I'm getting at is could an SM oil that also has at least a CF rating be better and a better oil for a spark engine than one that has no diesel rating? And could an oil that has a SM rating and an CJ rating be even better still than the other 2 examples for a spark ignition gas engine?
#1679474 - 11/21/09 12:09 AM
[Re: mechanicx]
Hi, mechanicx - You said: "I guess what I'm getting at is could an SM oil that also has at least a CF rating be better and a better oil for a spark engine than one that has no diesel rating? And could an oil that has a SM rating and an CJ rating be even better still than the other 2 examples for a spark ignition gas engine?"
1 - The CF rating on an SM lubricant is only relevant if it is to be used in a corresponding diesel engine. That said it has been commonplace among many engine makers to require both (ACEA's A3/B3, A3/B4, A3/B3/B4 for example) for some time (Porsche since around 1975). It is perhaps a bit of a carry over and most PCMOs today would almost fly through CF compliance. typically it was S?/CD - we have moved on! It also saves on inventory and reduces the risk of "errors" at car dealerships!
2 - Very few SM lubricants have a CJ-4 rating. The formulating and testing for CJ-4 compliance (a "Commercial" lubricant) is costly and typically is not needed as they (SM) are consumer and not Commercial lubricants
Edited by Doug Hillary (11/21/09 12:15 AM) Edit Reason: Accuracy - spelling
Regards Doug
#1679483 - 11/21/09 12:18 AM
[Re: Doug Hillary]
Loc: ohio, usa
OK I guess that answers my question. The diesel rating an SM oil that's used in a spark engine has or doesn't have is irrelevent. Like you said, in the past I noticed all oils seemed to have a dual rating on the container, but now not so much.
