Form-A-Funnel
Dexos? Mobil 1 is now in!
by Jehartley
09/10/10 06:47 PM
May have found something that actually works??
by Johnny248
09/10/10 06:39 PM
When should you STOP cleaning your engine, or ARX?
by HangerHarley
09/10/10 06:31 PM
Thinking of switching oil...
by wallyuwl
09/10/10 06:15 PM
Anyone used Wagner Thermoquiet brakes?
by Ursae_Majoris
09/10/10 05:40 PM
Is A3 the right spec for an old Euro?
by fdcg27
09/10/10 05:10 PM
rotella t6
by justinf89
09/10/10 05:10 PM
Please critique my Amsoil plan
by Frbl
09/10/10 04:49 PM
Rix, WhiplashWilly, welder, FishMan, faranks
33022 Registered Users
116 registered (94 saturn sl1 2000 saturn sc2, 97f150, 94MaxGXE, 4ever4d, 77GrandPrix, 7 invisible), 463 Guests and 41 Spiders online.
33022 Members
60 Forums
137289 Topics
Max Online: 941 @ 06/02/10 01:33 PM
#1678747 - 11/20/09 02:03 PM Engine oil temperature sensor
RocketUSA Offline
Loc: OR
Hi guys,
Forgive me in advance. I've tried using the search function to look for this information and I just can't come up with it, so I'm going to ask straight out.
I'd like to install an engine oil temperature gauge, and I want to know what the users here suggest for installing the sending unit. The local parts store suggested I tee off of the oil pressure sending unit. I suppose it's possible the engine already has a fitting (or better yet a sensor) but my vehicle doesn't have any sort of printed manual I can buy. I've got a 2008 Toyota Sienna with the 2GR-FE 3.5L.
#1678756 - 11/20/09 02:17 PM Re: Engine oil temperature sensor [Re: RocketUSA]
aquariuscsm Offline
Loc: South Texas,USA
My Z31 300ZX turbo had an OEM oil temp guage. I wish all cars came with these.
1996 Nissan 300ZX 5-speed(#175 of 300)
Royal Purple 20W50
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Redline Water Wetter
#1678834 - 11/20/09 03:29 PM Re: Engine oil temperature sensor [Re: aquariuscsm]
flanso Offline
Loc: Tampa, Florida
VDO makes an oil temp sender that replaces the standard oil pan drain plug. I have never used one so I can't attest to the unit's quality.
#1678844 - 11/20/09 03:41 PM Re: Engine oil temperature sensor [Re: flanso]
Gary Allan Offline
Loc: Pottstown, PA
The pressure sender/sensor location isn't really appropriate for oil temp readings. You'll be reading whatever heat migrates to the sender.
The pan plug is the right spot for the sensible use. Some Fast and Furious types on (I think) Mazda's (or whatever) seem to insist on some location that reads the cam supply, but that's just a matter of indexing. That is, there will be a corresponding sump temp that results in any localized temp in most usage most of the time.
http://lube-direct.com/gallan/
#1678937 - 11/20/09 04:51 PM Re: Engine oil temperature sensor [Re: Gary Allan]
brandini Offline
Loc: Richmond, VA
Sandwich plate adapter... so you can measure at the filter.
04 Mazdaspeed MX5 - ZoomZoom
#1678940 - 11/20/09 04:53 PM Re: Engine oil temperature sensor [Re: brandini]
RocketUSA Offline
Loc: OR
I've got one of those cartridge type filters with a permanent housing. Would that work?
#1678950 - 11/20/09 05:06 PM Re: Engine oil temperature sensor [Re: flanso]
Bob Woods Online   content
Loc: North of Dallas Texas
Back in my VW days I used VDO engine oil temp senders, the sump plug and the oil dip stick kind both worked great.
2002 GMC 5.3 extended cab
1997 Taurus
#1683205 - 11/24/09 01:38 PM Re: Engine oil temperature sensor [Re: RocketUSA]
brandini Offline
Loc: Richmond, VA
Nope, you're screwed... buy a new drain pan plug and drill and tap a temp sensor into that.
