My extended drain OCI did not go as intended...
by firemachine69
07/01/16 11:10 AM
Honesty
by stockrex
07/01/16 11:04 AM
Valvoline's New "Cobalt" Grease availability
by EdandSherry
07/01/16 10:47 AM
Mobil Delvac 1 5w40: where to buy?
by car51
07/01/16 10:38 AM
Honda EM7000is stored too long with fuel
by henni
07/01/16 10:04 AM
1967 Ford F250- cooling system flush w/ Cascade??
by ryanschillinger
07/01/16 10:02 AM
Oil for FTO MIVEC used on track
by Spetz
07/01/16 09:13 AM
[Cut Open] Motorcraft FL500S - 5316mi
by DuckRyder
07/01/16 09:04 AM
Oil life monitors
by doublebase
07/01/16 09:02 AM
DENSO IKH20TT quality question
by inquirer
07/01/16 08:53 AM
OTC additives and products - what do we know?
by Kwuality
07/01/16 08:37 AM
Highway conditions in the Midwest
by grampi
07/01/16 08:22 AM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
74 registered (87sammy, 1JZ_E46, 13Tacoma, 09_GXP, 901Memphis, 7 invisible), 1914 Guests and 11 Spiders online.
58332 Members
66 Forums
251095 Topics
Page 1 of 2 1 2 >
#167719 - 12/19/05 07:45 PM Valvoline Maxlife
vwalburn Offline
Loc: Wichita, Kansas
I would like to get opinions on Valvoline Maxlife 5W-30 and the use of Purolator Pureone oil filters. I'm using these on both a 1996 Dodge Ram 1500 and a 1996 Toyota Corolla. Any thoughts on the use of other HM oils? Both cars have over 100,000 miles.
#167720 - 12/20/05 08:05 AM Re: Valvoline Maxlife
GROUCHO MARX Offline
Loc: The Sandhills of NewYorkistan
I'd say you've made a good choice. I like A-Rx in lieu of HM oils, but that's just me.
#167721 - 12/19/05 09:27 PM Re: Valvoline Maxlife
55Test Offline
Loc: New Brunswick
I've got a 92 Honda Accord with 210000 miles on it. I bought it the lask week of September. I changed the oil and used Quaker State winter blend 5w30. I don't know what was wrong, but I bet I was going through 1 quart of oil a week! The car was seemingly leaking and burning oil. I ran that oil for approx. 6500 kilometers. I changed it out and poured in Maxlife 5w30 SM rated, and installed a Carquest premium filter. In the 700+ miles since I changed to the Maxlife, the car has not used any oil! On my previous OCI with the QS winter blend, I bet I would have gone through 2 quarts by now. I don't know what I did, did the oil really fix things up that fast? Regardless, Maxlife is my new favorite oil.
#167722 - 12/20/05 12:02 AM Re: Valvoline Maxlife
Islandvic Offline
Loc: South Texas
Very excellent oil/filter combo in my opinion. Val maxlife conventional is 12-18% PAO Syn, though not marketed as a synblend. It was one of the first on the block in the high milage scene.
5k mile OCI should be no problem with that combo in both vehicles.
I started using it back in '01 in a '96 4.6 Crown Vic with good results. The Vic would consume more oil when I would use WM Super Tech and MoCraft instead of the Maxlife actually.
I then switched to MaxLife Synthetic, and consumption went down further. I use it it in my '95 K1500 350TBI with 168k miles.
Switching to the MaxLife Syn version in both of the mentioned vehicles at well over 100k miles did not produce any leaks, and actually reduced consumption.
Change your PCV valve in both vehicles.
#167723 - 12/20/05 12:03 AM Re: Valvoline Maxlife
Mr Magoo Offline
Loc: SC
55,
Where was your oil leak ? [I dont know]
Doesn't the SL GF3 Maxlife have a better add pack (more Cal, Phos, Zinc) than the SM GF4 Maxlife ?
#167724 - 12/20/05 12:09 AM Re: Valvoline Maxlife
bluerider Offline
Loc: TN
Hey guys, i haven't seen any info yet on ATV oil recommendations. I have new Polaris 400 and 700 and would like to know of a couple brand choices of oil and filters that will allow me to only change oil/filter once a year or about 1500 miles if possible. What do you recommend?
Thanks
#167725 - 12/20/05 04:21 AM Re: Valvoline Maxlife
Tones Offline
Loc: Houston, TX
bluerider:
Have you tried the motorcycle forum?
#167726 - 12/20/05 08:11 AM Re: Valvoline Maxlife
55Test Offline
Loc: New Brunswick
Well, I think I have a leaky front crank seal. It looked pretty wet last time I was down there. I've probably got leaky cam seals and coutershaft seals, but I can't be certain.
#167727 - 12/20/05 05:11 PM Re: Valvoline Maxlife
TallPaul Offline
Loc: By Detroit
The SM Maxlife has the lower zddp levels, but also has about 300 ppm moly that was not indicated in the SL formulation. So on balance, the SM probably is as good as the SL. Either way, you can pump it up with a zddp adder, maybe VSOT.
#167728 - 12/20/05 05:15 PM Re: Valvoline Maxlife
dave1251 Offline
Loc: Maricopa, AZ
I would not worry about its add pack. It should be up to par for any reasonable driving situlation.
#167729 - 12/20/05 06:33 PM Re: Valvoline Maxlife
JohnnyO Offline
Loc: Pittsburgh, PA
I'm going to try Max Life in my mother's car shortly to see if the oil consumption goes down. Caddy Northstar, which are known for burning oil. Been using M1 the last few years. Mom's car has slightly under 50k so it's not high miles, but I'm going to give Max Life a shot.
#167730 - 12/21/05 08:42 AM Re: Valvoline Maxlife
55Test Offline
Loc: New Brunswick
Would a half bottle of CD2 street legal oil boost be any good for boosting the ZDDP in SM rated Maxlife?
#167731 - 12/20/05 09:33 PM Re: Valvoline Maxlife
TallPaul Offline
Loc: By Detroit
I have 6 bottles of the CD2 Oil Boost and plan on using half a bottle at a time like that. Hope you got yours at Big Lots where it is going for $1.99 a bottle. ZDDP is about 4500 ppm. Should not thicken the oil. Should make the SM at least an SL additivewise.
#167732 - 12/20/05 10:05 PM Re: Valvoline Maxlife
kozman01 Offline
Loc: Columbus, OH
55
On your Accord. Look at the bottom of where your distributor connects to the valve cover. I found fresh oil leaking there. The dist. on Accords suck so just put a new one on. Also, check the oil pressure switch (a few inches above the oil filter) they leak alot on Accords and also check that "flange" thing that the oil filter is attached to. These things leak all the time and mine just was. Just some hints from a fellow 92 Accord owner. If you need a tip on a new distributor, let me know. Autozone and them sells them for around 275. You can get one for around 120.00.
#167733 - 12/20/05 11:33 PM Re: Valvoline Maxlife
Mr Magoo Offline
Loc: SC
"ZDDP is about 4500 ppm"
Isn't that much ZDDP bad for the catalytic converters ? [I dont know] [I dont know]
Page 1 of 2 1 2 >
