This oil was run from 6/20/09 until 11/11/09. It was 10W-30 PP with a Napa Gold oil filter. My last UOA looked good enough that I decided to run the oil longer this time. I went about 200 miles past the point where my dummy light for my OLM went off. It does not show a % for my car.
I drive pretty gentle most of the time.
Wix air filter. Air filter changed at 110k miles on the odo and again at this oil change. I'm changing it every 10k now.
Blackstone Coments:
You took the oil change interval up another notch and wear reads similarly to where it has in recent trends. Copper and lead bumped up a little, but neither reads excessively. In fact, when you look at unit/location averages, the wear profile in this sample matches up with them very closely, which suggests normal wear for this engine over the course of this most current oil change interval. The 3.4 TBN means that plenty of oil additive was still active as of the sample date. The low viscosity is a non-issue and no coolant was noted. Try ~9,400 miles next oil run.
Comments welcome. I've got PP 5W/30 in it now with a Wix oil filter and plan to run it until spring. I think going 10k is pretty safe. My goal is to just change the oil every 6 months which could be up to 11k miles per OCI. Copper is up some but lower than last time on a per mile basis. Lead is higher than last time too but not higher than the Universal Average. Still no sign of a return of the intake gasket coolant leak that was repaired in the spring of '08. Hopefully it is gone for good.
Code:
OIL PP10W30 PP10W30 PYB10W30 PP5W30 M110W30 M110W30
MILES IN USE 7.4k 5.0k 3.4k 5.1k 5.7k 4.9k Uni Avg
MILES 117.5k 110k 87.1k 80.5k 70.4k 64.8k
SAMPLE TAKEN 11/11/09 6/20/09 6/10/08 2/28/08 9/2/07 7/3/06
ALUMINUM 3 2 2 3 3 2 3
CHROMIUM 1 1 1 1 1 1 1
IRON 9 8 9 24 14 8 13
COPPER 25 19 21 28 39 30 17
LEAD 8 5 9 4 21 19 8
TIN 0 0 2 1 0 0 1
MOLYBDENUM 49 48 3 52 98 83 65
NICKEL 0 0 0 1 0 0 0
MANGANESE 0 0 0 0 0 0 0
SILVER 0 0 0 0 0 0 0
TITANIUM 0 0 0 0 0 0 0
POTASSIUM 0 2 7 11 1 3 7
BORON 29 36 114 34 47 52 45
SILICON 15 11 29 13 12 12 11
SODIUM 2 2 8 10 5 4 24
CALCIUM 2809 2944 2018 2919 2184 2354 2078
MAGNESIUM 10 10 7 12 11 13 90
PHOSPHORUS 649 639 646 656 538 589 691
ZINC 728 832 784 819 675 745 848
BARIUM 0 0 0 0 0 0 0
INSOLUBLES 0.3 0.3 0.2 0.3 0.3 0.3
WATER 0 0 0 0 0 0
FLASHPOINT ºF 390 410 400 400 410 420
SUS VIS 210ºF 58.2 59.2 56.6 57.9 58.6 60.8
cSt @ 100ºC 9.70 9.99 9.24 9.63 9.83 10.44
TBN 3.4 n/a n/a 3.9 3.7 n/a
Blackstone Coments:
Code:
TIN 0 0 2 1 0 0 1
WATER 0 0 0 0 0 0
