Honda GX35 question
by dirtydannyd
07/25/16 02:08 AM
Need advices for oil filter inspection
by ST2008
07/25/16 01:45 AM
Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
07/25/16 01:06 AM
Clean battery with garden hose?
by SavagePatch
07/24/16 11:55 PM
Toyota 5w20 blend?
by researcher
07/24/16 11:36 PM
Smoked some baby backs today
by BeerCan
07/24/16 10:28 PM
Ford FWD axle replacement
by 2009Edge
07/24/16 10:27 PM
Saturn ac compressor
by spasm3
07/24/16 10:20 PM
looking for spray guns - analysis paralysis
by tomcat27
07/24/16 10:18 PM
WIX 51372 ADBV Failure
by WellOiled
07/24/16 10:11 PM
moly + engine coatings
by benjy
07/24/16 09:57 PM
Worth the upgrade?
by daves87rs
07/24/16 09:47 PM
NJ1911, SneakyTacos, DaveD, 8o8is, Texasdude74
58584 Registered Users
25 registered (EchoTech1945, dmack2, AnthemBassMan, car51, Char Baby, austinlunsford, 2 invisible), 794 Guests and 12 Spiders online.
58584 Members
66 Forums
252221 Topics
Page 1 of 4 1 2 3 4 >
#1667509 - 11/11/09 06:48 PM 2007 Ford Fusion Transmission
millerbl00 Offline
Loc: Louisiana
I just bought a 2007 Ford Fusion with 40k miles on it. Looks like the transmission fluid has never been changed. It is no longer red in color at all. I know it is the 5 speed and takes FNR5 fluid. I and going to change it this weekend.
My question is does anyone think any long term damage has been done at this point? It looks really dirty for 40k miles. It does shift good. I felt since the rest of the car was perfect that I would be good on the transmission.
#1667521 - 11/11/09 07:01 PM Re: 2007 Ford Fusion Transmission [Re: millerbl00]
Spartuss Offline
Loc: Baltimore, Maryland
Color is not always an indication of fluid condition. Go ahead and change your fluid via a couple drain and refills with a nice drive in between.
Was once a BITOG addict!
#1667529 - 11/11/09 07:10 PM Re: 2007 Ford Fusion Transmission [Re: Spartuss]
bepperb Offline
Loc: Milwaukee, WI
No, I doubt any damage has been done, but I would probably do a drain/fill or two.
In my Highlander, the only automatic car I've ever owned, I did the first drain/fill at 40,000 miles and it also looked black, not red and dirty. That worried me to the point where I did another at 60,000, and the fluid I drained looked clear and red, and basically makes me think that there was a significant amount of breakin friction surface material in the initial fluid, it wasn't that the fluid was "worn out" or overheated. This doesn't directly apply to you, but hopefully eases your mind a bit.
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
#1667551 - 11/11/09 07:28 PM Re: 2007 Ford Fusion Transmission [Re: bepperb]
millerbl00 Offline
Loc: Louisiana
Thanks. All good advice. Yes it helps! A couple of changes and I think I will be good.
#1667567 - 11/11/09 07:42 PM Re: 2007 Ford Fusion Transmission [Re: bepperb]
LC Offline
Loc: Wisconsin
I have a 2006 Milan with 93,000 miles, same trans and engine as your Fusion. The owner’s manual says to change at 150,000 miles; yes that is what it says.
I went 90,000 on my transmission fluid with out any problems.
It never looked red even when new, kind of a brownish red.
I just used my siphon pump and sucked out 3 quarts and replaced that with the newest Mobil 1 syn ATF it Meets the requirements of the Mazda FNR5 transmission.
I did siphon again and replaced 3 quarts at 93,000 miles.
I would not worry about having 40,000 mile on original fluid.
Edited by LC (11/11/09 07:45 PM)
09 CVO SE Road Glide
04 Super Glide Sport
00 TW 200
12 Jeep Wrangler Unlimited
14 Mazda 6 iTouring
QSU/PP/PU oil
#1667572 - 11/11/09 07:44 PM Re: 2007 Ford Fusion Transmission [Re: LC]
panthermike Offline
Loc: Phoenix, AZ
Sorry to de-rail but, LC which siphon did you use? I want to put syn ATF in my Ranger without dropping the pan, this sounds like a good solution.
Thanks.
'16 Ram Sport 1500;PP 5w20 2K
'15 Lincoln MKC; MC 5w30 24K
'77 F250 "Ol Yeller"; Kendall/Mos2
'98 ES300; ML/Biotech 206K
#1667592 - 11/11/09 07:53 PM Re: 2007 Ford Fusion Transmission [Re: panthermike]
LC Offline
Loc: Wisconsin
http://www.kk.org/cooltools/archives/001299.php
Works great,I used it on my 2000 ranger.
00 TW 200
14 Mazda 6 iTouring
QSU/PP/PU oil
#1667599 - 11/11/09 07:55 PM Re: 2007 Ford Fusion Transmission [Re: LC]
millerbl00 Offline
Loc: Louisiana
Thanks everyone. I feel much better now hearing real world examples!
#1667607 - 11/11/09 08:03 PM Re: 2007 Ford Fusion Transmission [Re: LC]
panthermike Offline
Loc: Phoenix, AZ
Sounds cool, the amazon link says it's unavailable frown
#1667611 - 11/11/09 08:07 PM Re: 2007 Ford Fusion Transmission [Re: millerbl00]
tig1 Offline
Loc: Illinois
My 07 Fusion has 42,000 miles and I changed my fluid recently. Actually the FNR5 fluid from MC has a different colar than most ATF fluids. It's almost a Orange colar rather than the traditonal colar. I just pulled the drain plug and got 3.5 qts. out but the old fluid looked fine. Unless your tranny has been subjected to very harsh conditions you should be fine.
2007 Ford Fusion 184,000 miles
M1 0-20 AFE
2007 Ford Focus 156,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#1667618 - 11/11/09 08:11 PM Re: 2007 Ford Fusion Transmission [Re: tig1]
millerbl00 Offline
Loc: Louisiana
This is great! Everyone here has great info and a big help. So the trans pan has a drain plug?
#1667619 - 11/11/09 08:12 PM Re: 2007 Ford Fusion Transmission [Re: LC]
tig1 Offline
Loc: Illinois
As I already stated my 07 Fusion has a drain plug. Check and see if your 06 does. Also I e-mailed Mobiltech about using M1 ATF in my Fusion with the FNR-5 fluid and I was told it isn't compatable. Either the guy gave me bad info or you got the wrong scoop. Where is that info found on the M1? Would like to know.
M1 0-20 AFE
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#1667629 - 11/11/09 08:17 PM Re: 2007 Ford Fusion Transmission [Re: tig1]
millerbl00 Offline
Loc: Louisiana
Thanks everyone!
#1667630 - 11/11/09 08:17 PM Re: 2007 Ford Fusion Transmission [Re: millerbl00]
tig1 Offline
Loc: Illinois
Yes it does. Drop the large shield under the engine compartment and you will see it. By the way I just left mine off. Don't see a reason for it so I'm leaving it off. The Fusion is a great car. Love the ride and handling and MPG.
M1 0-20 AFE
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#1667648 - 11/11/09 08:28 PM Re: 2007 Ford Fusion Transmission [Re: tig1]
LC Offline
Loc: Wisconsin
say it right here: https://www.mobiloil.com/USA-English/MotorOil/Other_Products/Mobil_1_Synthetic_ATF.aspx
Mazda ATF-III, ATF-MV
ATF-MV is what my manual says to use and its is on the dipstick also. If your interested in Redline products I contacted them and they said "Thank you for contacting Red Line Oil, in your FNR5 automatic transmission I would recommend the D4ATF, would satisfy the fluid requirements.
Regards, Dave
Red Line Oil"
And My 06 does not have a drain plug.
00 TW 200
14 Mazda 6 iTouring
QSU/PP/PU oil
