32957 Members
60 Forums
136840 Topics
Max Online: 941 @ 06/02/10 01:33 PM
#1661956 - 11/07/09 09:11 AM
Re: BEST oil for Cummins Dogde 5.9L......????
[Re: bullwinkle]
Loc: AZ
The common rail is extremely easy on oil as long as no aftermarket tuning is used. Agood filter such a t stratapore or a venturi filter will allow you to easily run 10K OCI with Delvac 1
03 Ford F250 7.3 (Lots of Mods). Redline & baldwin 7039 07 Ford F150 fill. Penz Ultra 5-20 & Bosch 3410 99 ford F150 4.6 fill. Redline 5-30 & P1
#1662128 - 11/07/09 01:07 PM
[Re: bullwinkle]
Loc: san diego, ca
PBX is NOT Group IV-it's a hydrocracked Group III. Unless you have cash to burn for $150 oil changes, or a bypass system to REALLY extend OCIs on a CR Cummins-why not pick up some Mobil Delvac 1300 dino-it's a WHOLE LOT cheaper than Delvac 1, costs about 1/3 as much-your soot is going to build up quickly enough that you'll be wanting to change it after 7500 or so anyway (& don't forget that annoying Dodge/Chrysler/Cerberus/Fiat/??? engine warranty issue!!!)! Thanks for the info! I just found out that AA equipment sells John Deer Plus-50 15w-40 CI-4 oil.... so maybe I go with JD... It is 11 bucks per gal... And good stuff to put into the Cummins, right? Change JD every 5000?
#1662194 - 11/07/09 02:39 PM
[Re: banana]
Loc: oh
i would think the jd plus 50 could easily go 10k in a dodge, i use it in my 07 powerstroke & always had stellar uao's
'07 f350 6.0
#1662347 - 11/07/09 05:03 PM
[Re: roadrunner1]
Loc: san diego, ca
I must admit that this whole oil thing and CJ vs. CI is not easy to understand... but I think I am getting a little bit closer...
So right now I think JD plus is my new path... or the regular Premium Blue CJ oil + some ZDDP additive...
#1664118 - 11/09/09 04:19 AM
[Re: banana]
Loc: Indianapolis, IN
Ok - for about the one zillionth time, there is no "BEST" oil for all applications for all people. You have to analyze your operational patterns, your maintenance plans, and choose accordingly. Then, if you want confirmation that you've made a good choice, successive UOAs.
The loss of ZDDP and other items when moving to CJ-4 fluids is a reality, but it's the mis-interpretation of that reality that sends most folks scurrying. Just because some characteristics (ZDDP, etc) were reduced with CJ-4, why do most people automatically suspect an inferior product? Do you not think that other characteristics (other additives and base stocks) were manipulated to compensate for the changes? For one thing, the CJ-4 fluids were designed with a great many detergents and anti-agglomerates to help with the ever-increasing use of EGR. That part of the CJ-4 add package far surpasses the older versions; yet people only focus of the loss of zinc, and forget to credit CJ-4 fluids with their strengths.
Overall, the major manufacturers (Shell, Mobil, Valvoline, Castrol) have a collective total of millions of miles of testing and real-world-use data to show that, when using ULSD as a fuel, the new CJ-4 fluids outperform their predecessors. It's NOT a conspiracy; it's facts, data, and engineering.
Outputs (UOA results) speak volumes more than inputs (VOAs and PDFs). Let's step away from the oil topic, and look at the input/output factor from a different perspective. Consider a football game. Knowing the starting line-ups for each team is a good thing, and you might be able to predict who is going to win. But if you could jump ahead into the future to make a bet, would you rather know the roster, or the end score? Would you rather know the inputs, or the results? Most people can see, from this perspective, that outputs are more inportant than inputs. Getting back to oil; a UOA is much more telling than a VOA.
With that in mind, look at many of the recent UOAs for the new CJ-4 dino HDEO fluids. The performance is outstanding. Whatever it is that people think is detrimental from the move to CJ-4 is NOT manifesting itself in the real world. The new CJ-4 fluids are turning in stellar UOAs. On top of that, with the recent (ongoing) bargins in Rotella and Delvac, the dino HDEO costs are excellent. I personally recently ran Rotella 10w-30 dino in heavy use for 6k miles, and the UOA was outstanding. Many Delvac 1300 UOAs have shown super results. All in CJ-4.
Banana, you've got a 2007, right? You have DPF? Your truck's stock? You need to run a CJ-4 fluid, for the health of the exhaust system and to control soot.
All that being said, certainly anyone should use what they deem most appropriate; that's common sense. But being in SoCal, it's not like extreme temps are an issue for the OP. So only the OCI duration should play into this decision. Can he/she handle really long OCIs? If so, go with synthetics and bypass; that is their forte'. But if you can't keep your hands off the wrenches, then find a quality dino HDEO and use it for 7.5k miles (perhaps more, UOA dependent).
There is no best oil for everything. There are "better" selections for given operating and maintenance plans. You must choose accordingly, after you define your scenario.
Edited by dnewton3 (11/09/09 04:44 AM)
Doing 7.5k miles on dino WSS-M2C930-A in the 2.5L Fusion. To boldly go where no man has gone before ...
I used to run dino oil, because I didn't know what I didn't know. Then, I used "synthetics", because I thought I knew better. Now, I use dino's, because I know the truth.
#1664133 - 11/09/09 05:13 AM
[Re: dnewton3]
Loc: cincinnati
Not sure if a 5.9 ever had the DPF-I think that's a 6.7-only thing-with the now universal use of ULSD, CJ-4 seems to be doing almost as well as CI-4+. I don't know about anybody else, but my '06 5.9 turns the oil black INSTANTLY from soot, I don't run enough miles to use UOAs, I only run around 5K a year on that truck.
93 GMC C3500 6.2 diesel 4L80E 06 Ram 3500 SRW Cummins 48RE 4X4 04 Ford E-350 6.0 PSD 82 Mercedes 300DT 89 F-450 7.3 IDI 5 speed, 3.73s & Traclock
#1664380 - 11/09/09 10:25 AM
[Re: D-Roc]
" ... I only run around 5K a year on that truck."
I'm right there with you. I only ran 6k miles last year on my Dmax.
All the more reason to choose a quality dino oil, a decent filter, and OCI once a year. Zero sense in spending more for PAOs and high-end filtration if that's all you're going to do. You won't see any appreciable gain in wear reduction, and therefore your ROI is terrible by using top end products for short OCIs.
In your area, any of the 15w-40 quality brand name dino's would do. I'd choose the one that happens to be on sale when you walk in. You won't be doing UOAs; there's no need for consistency of readings to mandate a single brand/grade.
Your Cummins will run fine, and your wallet will thank you.
IMO, that is the "best oil" plan for you.
#1665333 - 11/10/09 01:47 AM
[Re: dnewton3]
Loc: san diego, ca
all right! Thanks for all the replies! And after reading a lot about the topic, and the posts above, I made up my mind...:
I'll probably just stay w/ my VPB 10w-40 and change it after 5-6k...like I did the whole time. And I am using a LF16035 oil filter...
And she has no DPF...
I will start montioring it by doing UOA's... I will change the oil tomorrow.
thx for all the help again!
Edited by banana (11/10/09 01:54 AM)
#1674770 - 11/17/09 10:34 AM
[Re: banana]
Loc: san diego, ca
...the UOA after 5k at 40k: Link
#1676334 - 11/18/09 01:36 PM
[Re: bullwinkle]
Loc: Long Beach, CA
Not sure if a 5.9 ever had the DPF-I think that's a 6.7-only thing-with the now universal use of ULSD, CJ-4 seems to be doing almost as well as CI-4+. I don't know about anybody else, but my '06 5.9 turns the oil black INSTANTLY from soot, I don't run enough miles to use UOAs, I only run around 5K a year on that truck. Yup, no DPF on the 5.9...which is why I chose the 5.9 on my 2007 even though the 2007.5 models with the 6.7 were on the dealer's lot. My truck also turns the oil black instantly. From what I read on the Cummins forums, that's typical.
2007 Dodge Ram CTD / Carli Suspension
