Form-A-Funnel
Pennzoil YB $1.79/Quart after MIR (Limit 5)
by akk944
09/02/10 10:30 AM
Oil recommendations please.
by matt_in_tulsa
09/02/10 09:50 AM
Multiple quotes
by ChiTDI
09/02/10 09:30 AM
What's the preferred flavor of weed-trimmer??
by deeter16317
09/02/10 09:16 AM
September Advance Auto Ad
by tenderloin
09/02/10 08:34 AM
Brake system bleed now fluid is really dirty
by plrprecision
09/02/10 07:55 AM
which equation does widman calculator use?
by lipadj46
09/02/10 07:55 AM
Redline MT-85.
by simple_gifts
09/02/10 06:10 AM
jimo, porvdub, OADGTi, vicious_fishes, MASSMINI
32957 Registered Users
99 registered (addyguy, asamek, akk944, bdcardinal, AWDfreak, 10 invisible), 506 Guests and 42 Spiders online.
32957 Members
60 Forums
136840 Topics
Max Online: 941 @ 06/02/10 01:33 PM
#1661950 - 11/07/09 09:03 AM Drying Carpet
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Had a guy with a super machine hit the bottom floor. Excellent job.
Carpets are a still bit damp overnight (but much drier) - any drying methods or just heat and air flow?
#1661952 - 11/07/09 09:06 AM Re: Drying Carpet [Re: Pablo]
Bill in Utah Offline
Loc: UT
Put a fan on it and let air flow work its wonder.
But I live in the desert so everything drys quickly.
Bill
2004 GMC K1500 4x4 4.3l V6 5sp 122k+
2005 Toyota Corolla 1.8l I4 5sp 180k+
2007 Subaru Outback 2.5l H4 4sp Auto 48k+
1998 Ford Contour SE 2.5l V6 Auto 103k+
#1661970 - 11/07/09 09:24 AM Re: Drying Carpet [Re: Bill in Utah]
Drew99GT Offline
Loc: Colorado Springs
How's the humidity today Pablo? That's a big factor. If you can live with it for a bit, crank the furnace up to like 75 maybe? That should really take out the humidity. That's what we've done after getting carpets steam cleaned when it's a bit cool out.
#1661984 - 11/07/09 09:51 AM Re: Drying Carpet [Re: Drew99GT]
JTK Offline
Loc: Buffalo, NY
Lots of air flow, the dryer the better. That's what I hate about wall-wall carpet. What's beneath the carpet into the padding stays wet a looooong time and basically relies on the subflooring to soak it up.
Joel
2008 Hunday Santa Fe GLS AWD, 2008 Honda Odyssey LX (Babe magnet II)
#1661986 - 11/07/09 09:53 AM Re: Drying Carpet [Re: Drew99GT]
Warstud Offline
Loc: MIchigan
Heat from the furnace will create more humidity as the water dries but you need a air conditioner or dehumidifier to get rid of the humidity.
#1662001 - 11/07/09 10:05 AM Re: Drying Carpet [Re: Warstud]
Drew99GT Offline
The heat from the furnace will reduce the humidity IMO. Some of it will end up going out the roof vent. There's no way running your furnace can increase humidity. In technical terms, if the amount of water vapor did stay the same but the ambient temp rose from the furnace, the relative humidity drops. But I'd think running the furnace would carry out some moisture.
Running A/C would be best of course.
#1662096 - 11/07/09 12:06 PM Re: Drying Carpet [Re: Drew99GT]
Warstud Offline
Loc: MIchigan
Your missing the point..we all know that heat evaporates water.. turns liquid water to a gas vapour(humidity etc.) So as you decrease the liquid you have increased the gas but now you have to get rid of the gas. It's not the furnace that increases the humidity it's the drying effect of the heat from the furnace creating humidity through evaporation. So in the end the furnace will decrease humidity once it escapes the home.
#1662133 - 11/07/09 01:15 PM Re: Drying Carpet [Re: Warstud]
Pesca Online   embarrased
Loc: Montreal, Quebec in Canada
If you have a fire place, make a nice fire.
That is one the best way to try a place.
And like others said, create a good air flow in your home to move the humidity away.
2008 Nissan Rogue SL-FWD - Valvoline Synpower 5w30
2008 Honda Odyssey LX - Who cares? (not the dealer, anyway), it is a lease
#1662178 - 11/07/09 02:14 PM Re: Drying Carpet [Re: Pesca]
Pablo Offline
Thanks guys. Seems like less the 24 hours after the cleaning, the carpet is now feeling quite dry. I'll keep the heat up and air moving today, tomorrow it should dry enough to drag furniture around and in.
