Form-A-Funnel
Pennzoil YB $1.79/Quart after MIR (Limit 5)
by akk944
09/02/10 10:30 AM
Oil recommendations please.
by matt_in_tulsa
09/02/10 09:50 AM
Multiple quotes
by ChiTDI
09/02/10 09:30 AM
What's the preferred flavor of weed-trimmer??
by deeter16317
09/02/10 09:16 AM
September Advance Auto Ad
by tenderloin
09/02/10 08:34 AM
Brake system bleed now fluid is really dirty
by plrprecision
09/02/10 07:55 AM
which equation does widman calculator use?
by lipadj46
09/02/10 07:55 AM
Redline MT-85.
by simple_gifts
09/02/10 06:10 AM
jimo, porvdub, OADGTi, vicious_fishes, MASSMINI
32957 Registered Users
99 registered (addyguy, asamek, akk944, bdcardinal, AWDfreak, 10 invisible), 506 Guests and 42 Spiders online.
32957 Members
60 Forums
136840 Topics
Max Online: 941 @ 06/02/10 01:33 PM
#1661780 - 11/07/09 02:36 AM Stay with my oil or change?
eblade Offline
Loc: Socal
So I have a 1993 Honda Civic DX that been on Valvoline Maxlife 5w30 in the winter and 10w30 for the summer. I Seafoam the engine every 3 oil changes and been using the Prue one filters with an oci of about 6k+. The car just went over 222,xxx miles and the engine has some issues. PVC, spark plugs, air filter, cap & rotor and IVAC have been recently replaced or cleaned. I get around 28-31mpg most of the miles are city driving. The engine idles rough during the daytime, however, it is fine at night. I have no idea why that is but I have a theory it might be electrical issue with the idle control. Around 3k+ rpms I hear a ticking/tapping coming from the engine. I already tried a valve lash adjustment. At this point I think it is a rod bearing or main bearing on its way out. Maybe thicker oil will help? Should I try AutoRX product?
Edited by eblade (11/07/09 02:40 AM)
#1661797 - 11/07/09 04:58 AM Re: Stay with my oil or change? [Re: eblade]
Eddie Offline
Loc: Florida, Cape Coral
You may condider staying with the 10w30 all year in your local or even to to 10w40/ Auto RX is not a bad idea.
#1661799 - 11/07/09 05:03 AM Re: Stay with my oil or change? [Re: eblade]
cornfused Offline
Loc: Indiana
Possibly a lifter sticking?
Another candidate for Marvel's mystery oil, I would try that first and see if it helps.
2003 Taurus "Babied" M1 0w20/Motorcraft
1995.5 Tacoma "Not Babied" VML 10w30/Pureone
1987 Mustang "Definately not Babied" Mobil 1 15w50/Motorcraft
#1661838 - 11/07/09 07:07 AM Re: Stay with my oil or change? [Re: cornfused]
NHHEMI Online   content
Loc: NH
Yeah I was thinking along the same lines. Before you( OP )get too ahead of yourself try something in the crankcase to see if you have a sticking valve, lifter, or possibly rings. Actually, as you already use it, Seafoam works great to free sticking engine parts. MMO works well too but in my experience the Seafoam does it faster.
Seafoam
MMO
AutoRx
Any of the above is worth a try.
Royal Purple User Since 1990 thumbsup
2008 Dodge Ram 5.7L HEMI
#1661850 - 11/07/09 07:21 AM Re: Stay with my oil or change? [Re: NHHEMI]
duaneb9729 Offline
Loc: minneapolis mn
to narrow down where the engine, have a friend raise the rpm to 3000, then using a long screw driver or solid object, put it against the valve cover and then the oil pan.
if you hear the noise better in the oil pan start shopping for a new car.
as far as the idle goes, have you cleaned the maf? heck does it have a maf?
#1661853 - 11/07/09 07:23 AM Re: Stay with my oil or change? [Re: duaneb9729]
duaneb9729 Offline
Loc: minneapolis mn
#1661871 - 11/07/09 07:56 AM Re: Stay with my oil or change? [Re: duaneb9729]
hate2work Offline
Loc: Western Washington
It idles rough during the day, but runs fine at night? If that's true, changing your oil isn't going to help.
Have you tried turning on your lights during the day? Any other daytime/nightime variables that you know of?
Good luck :)
#1664091 - 11/09/09 01:56 AM Re: Stay with my oil or change? [Re: cornfused]
eblade Offline
Loc: Socal
I'll probably put Valvoline 5w30 HM synthetic blend and seafoam cleaning after Thanksgiving. It seems the ticking might not be engine related. I found a post on yahoo answers about that the noise I describe could be the CV joints going bad. This is a good possibility since my CV boot joints are ripped and dire need of replacement.
#1664309 - 11/09/09 08:58 AM Re: Stay with my oil or change? [Re: eblade]
CErnst Offline
Loc: Kansas City, MO
oh yeah, torn boots mean the joints will die relatively soon. go buy yourself new shafts or have a shop do it. that needs to get replaced.
Mine: '98 Ford Ranger SuperCab 4x4 3.0L
Hers: '07 Mitsubishi Outlander LS AWD
#1664342 - 11/09/09 09:44 AM Re: Stay with my oil or change? [Re: CErnst]
mechtech2 Offline
Loc: Chicago Area
You have to be moving to hear the C/V joints.
A standard quick test for them is to make tight turns at slow speeds in both directions and listen for clicking/ popping.
If one is ripped, count on it being gone. 2 weeks is about all they last, after they have a torn boot.
#1664364 - 11/09/09 10:06 AM Re: Stay with my oil or change? [Re: mechtech2]
eblade Offline
Loc: Socal
I just realized I missed a very important detail in my op. The ticking only happens during a load/torque on the car. With that said, I don't have money to buy the axles so I guess I'll have to put that off after Thanksgiving as well.
#1664383 - 11/09/09 10:27 AM Re: Stay with my oil or change? [Re: eblade]
CErnst Offline
eblade, something you might consider if money is tight, go find a junkyard and grab those shafts. I know it is a bit of a gamble, but I've done it once before years ago.
#1664394 - 11/09/09 10:39 AM Re: Stay with my oil or change? [Re: mechtech2]
JohnBrowning Offline
Loc: USA
I would try Auto-Rx based on milage alone even if you had no issues. I would pull the bottom end and stick new bearing in it.ure it would be proper to measure everthing and resize the large end of the rods but that all takes time. You can stuff new bearing in rather quickly and replace all the timing front and rear main seals at the same time, If you where really ambitious you could install new rigns at the same time and see if you can make it 500,000.
