Form-A-Funnel
Pennzoil YB $1.79/Quart after MIR (Limit 5)
by akk944
20 minutes 45 seconds ago
Oil recommendations please.
by matt_in_tulsa
Today at 09:50 AM
Multiple quotes
by ChiTDI
Today at 09:30 AM
What's the preferred flavor of weed-trimmer??
by deeter16317
Today at 09:16 AM
September Advance Auto Ad
by tenderloin
Today at 08:34 AM
Brake system bleed now fluid is really dirty
by plrprecision
Today at 07:55 AM
which equation does widman calculator use?
by lipadj46
Today at 07:55 AM
Redline MT-85.
by simple_gifts
Today at 06:10 AM
jimo, porvdub, OADGTi, vicious_fishes, MASSMINI
32957 Registered Users
105 registered (87sammy, ARH_0700, addyguy, asamek, akk944, 9 invisible), 495 Guests and 46 Spiders online.
32957 Members
60 Forums
136840 Topics
Max Online: 941 @ 06/02/10 01:33 PM
#1658798 - 11/04/09 11:41 PM civic shaking upon start up?
kenwin30 Offline
Loc: louisiana
hey guys, 98 civic with 213k, got the plugs and wires changed at 170k, when i start the car,(esp when the motor is cold) the motor vibrates for about 10-15 seconds, then it quits and everything is fine, kinda like the motor is coughing i would say, could this be the plugs so soon??
#1658802 - 11/04/09 11:45 PM Re: civic shaking upon start up? [Re: kenwin30]
Gary Allan Offline
Loc: Pottstown, PA
Get some injector cleaner with PEA in it ..(drum roll with a ta-da) like Amsoil PI.
What type of driving does this car see?
http://lube-direct.com/gallan/
#1658804 - 11/04/09 11:47 PM Re: civic shaking upon start up? [Re: Gary Allan]
kenwin30 Offline
Loc: louisiana
mostly highway miles...been running techron through it every 4 months or so !
#1658807 - 11/04/09 11:51 PM Re: civic shaking upon start up? [Re: Gary Allan]
FusilliJerry82 Offline
Loc: Richboro, PA
Not that I know specifically where it is on a Civic but this is indicative of a plugged Idle Air Control Valve. A common problem in 90s Hondas. Another common, easily fixed cause is air in the cooling system. Try purging it.
2000 Mazda Protege LX - 164k - Advance Auto 10w-30/Valucraft filter
96 Ford Explorer XLT - 183k - Out of Commission
#1658808 - 11/04/09 11:53 PM Re: civic shaking upon start up? [Re: kenwin30]
Gary Allan Offline
Loc: Pottstown, PA
Well, that should have taken care of any deposits and your highway driving should make them take a long time to form.
I forgot to ask, did this happen before you changed the plugs and wires? Is that why you did it?
Assuming the answer is YES ...
Here's a test for you to perform. BEFORE you turn the key on (repeat BEFORE) place your foot to the floor and crank it for a few seconds. Stop cranking ..let your foot off ..and then start normally. It should not start when floored.
See if that reduces the misfire time to smooth.
#1658814 - 11/05/09 12:03 AM Re: civic shaking upon start up? [Re: Gary Allan]
kenwin30 Offline
Loc: louisiana
no this was not happening before i got the plugs, just started about 2 weeks ago, usually happens in the morning,
#1658822 - 11/05/09 12:14 AM Re: civic shaking upon start up? [Re: kenwin30]
Gary Allan Offline
Loc: Pottstown, PA
Hmmm (sticking out lower lip and posing as a dumb version of "The Thinker)
Let us assume that one or more of the plugs is defective or gapped improperly.
#1658854 - 11/05/09 01:26 AM Re: civic shaking upon start up? [Re: kenwin30]
Vizzy Offline
Loc: Canada
Vibrates.then you say it seems like it is coughing? I'm confused. So how is the idle and when you step on the gas in neutral is the motor stumbling ??
Need more specifics and detail to help you. My first thought was a bad motor or tranny mount.
#1658972 - 11/05/09 07:52 AM Re: civic shaking upon start up? [Re: Vizzy]
MONKEYMAN Offline
Loc: St. Louis
Originally Posted By: Vizzy
[quote=kenwin30] My first thought was a bad motor or tranny mount.
Mine too.
#1658987 - 11/05/09 08:15 AM Re: civic shaking upon start up? [Re: MONKEYMAN]
kenwin30 Offline
Loc: louisiana
the motor seems well when i step on the gas, no hesitation at all..i just let the car idle for about 30 seconds and then its fine...
#1659224 - 11/05/09 11:08 AM Re: civic shaking upon start up? [Re: kenwin30]
mechtech2 Offline
Loc: Chicago Area
This seems fuel related. The spark plugs are not fixing themselves.
But on a cold start, your enrichment for the fuel may be faulty. Bad temp sensor, fuel injector[s], MAF sensor, vacuum leaks, etc..
Start with vacuum leaks. Every line and it's connection must be perfect [esp the PCV system]. No manifold leaks, either.
#1659767 - 11/05/09 06:57 PM Re: civic shaking upon start up? [Re: kenwin30]
Vizzy Offline
Loc: Canada
Sounds like the engine is fine to me.
I definitely think a motor or engine mount.
I know on my parents 94 Accord( 4 cyl, automatic) that when the car is cold at idle is makes the steering wheel vibrate more than it should, I know that on the web it has mentioned some kind of dampener (isolation mount) for the transmission is probably worn out...when the car warms up a bit heat reaches the mount area from the engine and exhaust manifold, and the vibration goes away.
#1661783 - 11/07/09 02:42 AM Re: civic shaking upon start up? [Re: Vizzy]
joel95ex Offline
Loc: texas
the FIT valve and IAC valves on the hondas are known to "loosen" up and can be fixed . there is a very detailed sticky on superhonda about this...remove it and screw the plunger back in.....
here is the link w/pics and instructions:
http://www.superhonda.com/forum/f55/troubleshooting-idle-problems-259965/
IAC cleaning link:
http://www.superhonda.com/forum/f94/diy-cleaning-your-iacv-144463/
95 Accord 4cyl Vtec. 364K miles
Supertech 10w-30, PYB 10w-30, M1 EP 10w-30
2005 Durango 4.7 143K miles
PP 5w-30 now M1 EP
#1663344 - 11/08/09 02:38 PM Re: civic shaking upon start up? [Re: kenwin30]
Tosh Offline
Loc: Silicon Valley
Did it get extra cold 2 weeks ago? Sounds like a typical IACV getting gummed up...
Edited by Tosh (11/08/09 02:40 PM)
