Survey
Who has cheapest ATF+4 by the gallon?
by rastoma
11/20/09 08:13 PM
OEM Motorcraft plugs at 85K miles (with pics)
by 01rangerxl
11/20/09 08:11 PM
Mobil 1 or Motorcraft Blend?
by 825ltrgt
11/20/09 07:59 PM
Where to Set Your Jackstands if Pinch Welds Only
by 1993_VG30E_GXE
11/20/09 07:51 PM
2008 Corvette
by ant
11/20/09 07:48 PM
New Amsoil store here
by Chris142
11/20/09 07:32 PM
Weird Ford Focus 2007 Air Filter
by AlanCanada
11/20/09 07:27 PM
Quaker State Synth 5w-20, 01 Saturn SL2,7500 miles
by ToyotaNSaturn
11/20/09 07:12 PM
Ryder276, MGGTL, itbd_mr2, mrplavick, engrboy5
28833 Registered Users
115 registered (01rangerxl, 825ltrgt, -SyN-, -Clayton-, 6 invisible), 402 Guests and 13 Spiders online.
28833 Members
60 Forums
118719 Topics
Max Online: 997 @ 11/10/09 08:47 PM
#1658638 - 11/04/09 09:17 PM 2 CJ4 results 4 08F350 Castrol15w40 & Amsoil 5w40
ABChop Offline
Loc: Alberta, Canada
Let me know what you think of the results below. I'm new to this stuff :)
I just bought this truck this summer. It had Castrol CJ4 15w40 in it when i bought it(or so they say).....so it's the oil sampled Oct 12 with 4331 km (2707 miles) on it. It had high Al and Na.
I then put in the new formula Amsoil 5w40 CJ4 oil in. It is the oil sampled Oct 22 with 5026 km (3141 miles) on it. They compared it to the old formula...hence the high boron and magnesium...as they cranked it up in the new formula.
The truck only has 45000 km (28125 miles) on it.
[img:center][/img]
[img:center][/img]
#1658647 - 11/04/09 09:23 PM Re: 2 CJ4 results 4 08F350 Castrol15w40 & Amsoil 5w40 [Re: ABChop]
ABChop Offline
As for the 92.3 VISC40 on the first change this is what they said.
Use of incorrect viscosity grade, contamination with different grade of oil or fuel,
incorrect label information provided
#1658655 - 11/04/09 09:28 PM Re: 2 CJ4 results 4 08F350 Castrol15w40 & Amsoil 5w40 [Re: ABChop]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Can you please type that in? I can barely read it.
See PABLO at oilslubesfilters.com
#1658662 - 11/04/09 09:33 PM Re: 2 CJ4 results 4 08F350 Castrol15w40 & Amsoil 5w40 [Re: ABChop]
ABChop Offline
Incase you can't read it.
1st change had Al 14, Na 28, 40C Visc 92.3
Comments from them.
Na - Sodium Sodium is commonly ingressed as road/sea salt. In engines, Sodium in conjunction
with high potassium and/or boron indicates coolant and/or coolant additive presence.
Other sources may include detergent additive (limited use), grease additive.
VISC40 - VISC40 Use of incorrect viscosity grade, contamination with different grade of oil or fuel,
incorrect label information provided.
#1658667 - 11/04/09 09:37 PM Re: 2 CJ4 results 4 08F350 Castrol15w40 & Amsoil 5w40 [Re: ABChop]
ABChop Offline
2nd change
Had 54 hrs on it...5000km (3125 miles).
Boron 38
Magnesium 663
#1659365 - 11/05/09 01:00 PM Re: 2 CJ4 results 4 08F350 Castrol15w40 & Amsoil 5w40 [Re: ABChop]
jmac Offline
Loc: N. Texas
Both of those show they can go longer, the 40Visc reading looks like it is on the second oil, so being a 5w-40 looks perfectly reasonable to me, plus the 100C visc. readings are on the mark.
Amsoil has incredible Oxidation readings even for so low miles.
Nothing sticks out as bad at this time, Na may be from an additive in Amsoil, not so familiar with that oil.
Boron is also FM, EP add.
Magnesium is a detergent.
