Survey
Who has cheapest ATF+4 by the gallon?
by rastoma
19 minutes 44 seconds ago
OEM Motorcraft plugs at 85K miles (with pics)
by 01rangerxl
21 minutes 59 seconds ago
Mobil 1 or Motorcraft Blend?
by 825ltrgt
33 minutes 31 seconds ago
Where to Set Your Jackstands if Pinch Welds Only
by 1993_VG30E_GXE
41 minutes 12 seconds ago
2008 Corvette
by ant
44 minutes 42 seconds ago
New Amsoil store here
by Chris142
Today at 07:32 PM
Weird Ford Focus 2007 Air Filter
by AlanCanada
Today at 07:27 PM
Quaker State Synth 5w-20, 01 Saturn SL2,7500 miles
by ToyotaNSaturn
Today at 07:12 PM
Ryder276, MGGTL, itbd_mr2, mrplavick, engrboy5
28833 Registered Users
115 registered (01rangerxl, 825ltrgt, -SyN-, -Clayton-, 6 invisible), 402 Guests and 13 Spiders online.
28833 Members
60 Forums
118719 Topics
Max Online: 997 @ 11/10/09 08:47 PM
#1656797 - 11/03/09 02:07 PM Oil filter relief bypass range?
Soobs Offline
Loc: Colorado, USA
So in comparing a lot of aftermarket oil filters to OEM oil filters for my Subaru and Ford I got to wondering (again) about the relief valve opening pressure. Do OEM filters have a range like aftermarket filters? Or, do aftermarket filters have a range of PSI because they aren't built for just one specific car?
For instance, for my Ford F150 the applicable PureOne (PL24651) has a relief valve PSI of 8-16 PSI. Does that mean that the valve starts opening at 8 PSI and is fully opened at 16 PSI?
#1656802 - 11/03/09 02:10 PM Re: Oil filter relief bypass range? [Re: Soobs]
Pete C. Offline
Loc: 2900 NW Blvd, Gastonia, NC
Yep.
... ahhhh, it's great to be old!
#1656805 - 11/03/09 02:11 PM Re: Oil filter relief bypass range? [Re: Pete C.]
Soobs Offline
Loc: Colorado, USA
i so smarts duh
#1656844 - 11/03/09 02:42 PM Re: Oil filter relief bypass range? [Re: Soobs]
bepperb Offline
Loc: Milwaukee, WI
Keep in mind that is the pressure differential across the filter element (into the filter vs out of the filter) and you're unlikely to hit even the lower number under any normal operating conditions.
2004 Highlander 2.4l 2AZFE
2006 Accord 2.4l K24A8
1993 Kawi EX 500
#1657049 - 11/03/09 06:08 PM Re: Oil filter relief bypass range? [Re: bepperb]
Gary Allan Online   happy
Loc: Pottstown, PA
yep
http://lube-direct.com/gallan/
#1657263 - 11/03/09 09:04 PM Re: Oil filter relief bypass range? [Re: Gary Allan]
SHAMUS Online   content
Loc: Puget Sound, WA
So, assuming that the oil is at op temp, and the filter is relatively new, it won't go into bypass even at WOT?
A HIGHLY TRAINED, PROFESSIONAL IDIOT
#1657882 - 11/04/09 12:24 PM Re: Oil filter relief bypass range? [Re: SHAMUS]
bepperb Offline
Loc: Milwaukee, WI
It wouldn't matter if the oil was one degree above the pour point. The largest restriction against the flow of the oil is the passages in the engine. By comparison, the filter is much easier to get through. If the oil going into the filter is an amazingly high 100psi, it just has to leave the filter at at least 92psi to stay out of bypass.
The bypass is a hail mary effort to protect against the possibility of clogged elements, not for easier flow at startup.
1993 Kawi EX 500
#1658076 - 11/04/09 02:48 PM Re: Oil filter relief bypass range? [Re: bepperb]
Loc: Pottstown, PA
People have a hard time seeing the direct kinetic relationship that oil has on either side of the media. The stuff plays bumper cars throughout the entire engine. If it can't fit through the engine, it's going to back up (in pressure) to the pump. When the pump breaches the relief setting ......THAT'S when that 1:1 kinetic relationship is severed and stuff doesn't HAVE to go down the pipeline.
The filter is nothing to flow in itself. For all the pressure you apply to the upside of it, the back side has just as much (near enough) pressure to "shore it up". Back pressure. It's only in relief (or when the gallery is empty) that you can alter this extremely close in:out pressure relationship.
Naturally ..this is outside of "unicorns".
