Industrial hand cleaners?
by KenO
07/26/16 11:58 PM
Shell Rotella T6 in a Altima 2.5
by Grambo
07/26/16 11:24 PM
"Creaking" Conti DWS's?
by Lolvoguy
07/26/16 10:52 PM
Check your car after it's been worked on
by Nick1994
07/26/16 10:15 PM
How are lg android devices now days?
by ram_man
07/26/16 09:42 PM
Dexos 5w30 with highest 100c Viscosity
by CapitalTruck
07/26/16 09:32 PM
How do you avoid being perceived as a rookie when
by motor_oil_madman
07/26/16 09:27 PM
Oil opinions after dumping FF
by JoelB
07/26/16 09:27 PM
Bulk loading a grease gun?
by buck91
07/26/16 08:59 PM
Sears Battery Pricing
by PeterGreen
07/26/16 08:29 PM
My 12am emergency strut spring repair on a Civic
by Colt45ws
07/26/16 08:19 PM
My upper sidewall pinehole leak fix
by Pokermatters
07/26/16 07:52 PM
snydercn, surfbum, Tmemz4, woollum86, Phil108
58612 Registered Users
37 registered (artificialist, 01CAMRY, 97prizm, 3800Series, 69GTX, abycat, 3 invisible), 1064 Guests and 12 Spiders online.
58612 Members
66 Forums
252296 Topics
#1655345 - 11/02/09 11:37 AM mixing brands of brake fluid?
ryland Offline
Loc: Portland, OR
I need to change my front brakes and when I'm done I'm going to bleed all four brakes to make sure there is no air in the system. Last year I had a tire shop do a brake fluid flush because I have an 05 honda element and the brake fluid was getting pretty dark and my manual said to flush the system every 3 years. I know they used dot3 but I dont know what brand. I have two bottles of honda brake fluid. Is it ok to just bleed a little out then fill it up or is mixing brands bad and should I bleed the whole system?? Also if I should bleed the whole system how much brake fluid does that take?
#1655347 - 11/02/09 11:38 AM Re: mixing brands of brake fluid? [Re: ryland]
nfs480 Offline
Loc: Minnesota
You should be ok so long as you're using the same type, in this case DOT 3.
1989 Honda Accord SE-i 238,000 miles Amsoil ASL 5W-30.
2011 Honda Fit Sport 14,000 miles Amsoil XL 0W-20
#1655350 - 11/02/09 11:39 AM Re: mixing brands of brake fluid? [Re: ryland]
defektes Offline
Loc: Hesperia, CA, USA
mixing 2 different dot3 is fine.
2002 GMC Sierra 5sp. 4.3L 145K ST3980 E-Core
Chevron Supreme 5w-30, Amsoil Synchromesh In Tranny
Valvoline SynPower 75w-90 Gear Oil In Rear
#1655369 - 11/02/09 11:54 AM Re: mixing brands of brake fluid? [Re: defektes]
Familyguy Offline
Loc: Virginia
Yep, that should be just fine.
2013 Kia Sorento EX
3.5L AWD
#1655375 - 11/02/09 11:56 AM Re: mixing brands of brake fluid? [Re: Familyguy]
Oldwolf Offline
Loc: Cary, NC
I concur.
2005 Prius: Mobil 1 Blend (50%)0W20+(50%)0W40
2012 Prius C: Toyota 0W20
#1655384 - 11/02/09 12:01 PM Re: mixing brands of brake fluid? [Re: Oldwolf]
ryland Offline
Loc: Portland, OR
Ok great! Thanks guys! Also I dont have a micrometer to check the thickness of my rotors. I have 70k miles on my element. Should the rotors last another set of pads? The pads arent all the way down to metal yet. The rotors are rusty on the parts where the brake pad dosent touch but I'm going to clean them up tonight when I do the pads. I got the duralast gold cmax pads and the guy at the store said that the rotors ushualy last two sets of pads. What do you think?
#1655389 - 11/02/09 12:03 PM Re: mixing brands of brake fluid? [Re: ryland]
Spartuss Offline
Loc: Baltimore, Maryland
Flushing the system out gets all new fluid out. Bleeding the system gets some of the fluid out and the air out of the system.
I'd flush the system or bleed it until you've used up the whole bottle to get the most concentration of new fluid in there.
Was once a BITOG addict!
#1655549 - 11/02/09 02:32 PM Re: mixing brands of brake fluid? [Re: Spartuss]
bigmike Offline
Loc: Florida
I agree. I would flush the system until I saw clear fluid coming out of each bleeder. I did this on my truck a few weeks ago and it took 2 quarts of DOT 3. I made 2 passes per bleeder, starting with the farthest from the master cylinder, working to the closest.
Take care,
-Mike
2006 Chevy Silverado LT 4.8 - QS 5w30, Napa Gold
2009 Honda Accord LX-P 2.4 - QS UD 0w20, P1 14610
#1655709 - 11/02/09 04:19 PM Re: mixing brands of brake fluid? [Re: bigmike]
mechtech2 Offline
Loc: Chicago Area
You won't see a difference between a 'flush' an a 'bleed'.
One could be better than the other.
BTW, you can fush an old brake system all day and then take the calipers and wheel cylinder off and look inside. You'll see lots of stuff hanging in the corners.
Mix away! Just don't use the odd ball silicone based fluid!
#1655840 - 11/02/09 06:01 PM Re: mixing brands of brake fluid? [Re: mechtech2]
eljefino Offline
Loc: ME
You should be okay on the rotors. Can you get a spec? Might be able to use an open end wrench as a pass/fail if it's an even number. (Scrape off the rust rings for a good read.
Remember service replacement is thicker than "discard".
I've never had a rotor wear out as long as I paid attention and didn't have a sticky caliper etc. They warped and got annoying first. Sounds like you got a quality honda pair; would not replace without without definitely condemning as the parts store ones are usually worse.
#1656496 - 11/03/09 09:26 AM Re: mixing brands of brake fluid? [Re: eljefino]
artificialist Online   content
Loc: Florida
I have done fine with 2 fluids mixed. In many cases I would run out of Pennzoil DOT4 and have to add Valvoline DOT4.
Nothing bad happened.
2010 Lancer Ralliart Sportback
