Form-A-Funnel
OMG!!! ANOTHER GULF OIL RIG EXPLOSION!!!
by addyguy
09/02/10 11:06 AM
Used passenger van/work van good buys?
by M1Accord
09/02/10 11:03 AM
How long you been on the road (legally)?
by addyguy
09/02/10 11:03 AM
Motorcyclists: Watch out for left hand turners.
by mrsilv04
09/02/10 10:51 AM
Pennzoil YB $1.79/Quart after MIR (Limit 5)
by akk944
09/02/10 10:30 AM
Oil recommendations please.
by matt_in_tulsa
09/02/10 09:50 AM
Multiple quotes
by ChiTDI
09/02/10 09:30 AM
What's the preferred flavor of weed-trimmer??
by deeter16317
09/02/10 09:16 AM
ladder13, jimo, porvdub, OADGTi, vicious_fishes
32958 Registered Users
112 registered (addyguy, beast3300, akk944, 87sammy, ARH_0700, 9 invisible), 471 Guests and 55 Spiders online.
32958 Members
60 Forums
136844 Topics
Max Online: 941 @ 06/02/10 01:33 PM
#1655192 - 11/02/09 09:03 AM Dropping the pan and filter
den Offline
Loc: texas
99Silverado half ton 46,000 94 Suburban 95,000 it has been changed at dealer but last time i dont think they touched it? Silverado has never been changed,easy driving on both what should i do???
#1655253 - 11/02/09 10:20 AM Re: Dropping the pan and filter [Re: den]
ryan2022 Offline
Loc: Peterborough
I would change them both, just due to age.
Plus the newer fluids are quite good, and if you can do it yourself, the cost isn't that bad at all.
1997 Honda Civic EX Castrol GTX 10w30 Mobil Multi Vehicle
2006 Mazda 3 2.3 Castrol Syntec 5w20, Mobil Multi Vehicle.
#1655288 - 11/02/09 10:49 AM Re: Dropping the pan and filter [Re: den]
AzFireGuy79 Offline
Loc: Arizona
I would do a pan and filter sevice on both. After I would perfrom a cooler line fluid exchange with some Supertech Dex VI. I have had very good results with the older 4L60E/65 transmissions when going from DexIII to the new Dexron VI. You will need about 14-16 quarts to get most of the old fluid out.
2006 Toyota Tacoma TRD 4.0: Redline 5w-30,Redline D6 ATF,Redline 75w-90
2006 Toyota Camry SE 3.3: Redline 5w-30,Redline D4 ,ATF Bypass, Eclipse NAV
#1656358 - 11/03/09 06:59 AM Re: Dropping the pan and filter [Re: AzFireGuy79]
Jim Allen Offline
Loc: NW Ohio
I agree with the Arizona guy. Drop the pan and change the filter. Especially on the Silverado that has never been changed. Some 75 percent of the contaminants/wear debris in the life of an automatic (per Eleftherakis & Khalil) are either present at birth (manufacturing debris) or come from break in, so the first change is the vital one. This should happen by 5K miles. Also, install a cooler line filter, such as a Magnefine, installing it on the return line back into the trans.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#1665862 - 11/10/09 01:47 PM Re: Dropping the pan and filter [Re: Jim Allen]
SargeBB Offline
Loc: Texas
Agree with both AZ guy & Jim. I'd add one thing. If you follow Jim's good advice...this applies ONLY to a new vehicle...you would want to install the Magnefine on the line going from the A/T to the oil cooler(s). If the in-line filter is first installed AFTER about 5,000 miles, you'd do as Jim states and install it on the return line.
#1665993 - 11/10/09 03:36 PM Re: Dropping the pan and filter [Re: SargeBB]
benjamming Offline
Loc: northern Alabama
Sarge,
You know that you will have to explain yourself as to why you recommend installing a filter in a cooler supply line when new & cooler return line after ~ 5k miles. This makes absolutely no sense to me.
'02 Accord V6
'94 Grand Am 3.1L
