GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
1 piece lug nut recommendations?
by dlundblad
05/05/16 09:07 PM
1996 Chrysler Coolant
by outoforder
05/05/16 09:02 PM
Hat Tip to RMEuropean
by sleddriver
05/05/16 08:54 PM
Toro OHV considered flat tappet type...
by Duffyjr
05/05/16 08:48 PM
Tire Rack now carries the Falken Azenis RT615k
by slacktide_bitog
05/05/16 07:30 PM
Walmart now carries Nokian tires
by slacktide_bitog
05/05/16 07:16 PM
Heater Core Leak?
by bprat318
05/05/16 06:54 PM
R2C air filters
by Srt20
05/05/16 05:55 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
21 registered (alcyon, Ducked, Doug Hillary, carlprop, 3 invisible), 0 Guests and 0 Spiders online.
57814 Members
66 Forums
248535 Topics
#1655696 - 11/02/09 04:08 PM Any API-SG compatible oils?
Antigen Offline
Loc: Asia, California
Hi Guys. I have been trying to look for this topic but I couldn't seem to find it. I'm sorry if this is/was a redundant topic. Anyhow, I have a scooter. It's a Kymco Super 8. Which means the transmission is separate. It has a CVT.
The manual says to use API:SG which as far as I can tell is already obsolete.
Just acquired this about a month ago, And I am still trying to break it in using MOTOMAN'S break-in method. I am currently using API-SM MOBIL SUPER XHP 15W-40 mineral oil. But I've been reading and it a lot of sites said that API:SM is not good for air-cooled engines.
I guess the question is what I can I substitute for an API:SG? Or should I just continue using API:SM oils?
My oil change is due this week.
I am so tempted to use our Valvoline All Fleet Premium Heavyu Duty Diesel Engine Oil 15W-40 API" CI-4/SL. I've read guys using Delo.
I would use motorcycle oils, But in our area, the only motorcycle oils available are 20w50, and good brands are hard to come about. Automotive oil has absolutely no availability problems.
#1655750 - 11/02/09 04:52 PM Re: Any API-SG compatible oils? [Re: Antigen]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Use a motorbike oil not a pass car oil. They are usually sj - close enough AFA additisation goes.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#5 31478mi-PEAK 0W20+Subaru Filter
#1656139 - 11/02/09 10:28 PM Re: Any API-SG compatible oils? [Re: ARCOgraphite]
CSM746 Offline
Loc: Michigan
Using your HDEO 15W40 will work out fine. The diesel oils have add packs that include what we want in motorcycles and are known to be robust in the various mainstream brands as well as the boutique oils. And the oils are less money that the MC oils which is marketing at it's best. I run Mobil Delvac 15W40 in two R1200 BMWs and it is just right, especially this time of year up north. Just follow the recommended change intervals and all will be good.
#1656257 - 11/03/09 01:33 AM Re: Any API-SG compatible oils? [Re: CSM746]
chevrofreak Offline
Loc: Billings, MT
With CVT you aren't going to run into a lot of the problems that motorcycles have. Less shearing, no worry about clutch slippage from the oil being energy conserving. You could run just about any oil in that thing and it would do fine.
I <3 Red Line oil
#1656670 - 11/03/09 12:08 PM Re: Any API-SG compatible oils? [Re: chevrofreak]
Antigen Offline
So, I guess the valvoline all fleet heavy duty diesel engine oil would do? It says on the back that it's also for gasoline engines.
It's API:C4-4/SL
#1656720 - 11/03/09 12:56 PM Re: Any API-SG compatible oils? [Re: Antigen]
RWEST Offline
Loc: Somerset County, PA
Yeah, that thing's from Korea or someplace where they run 'em on reconstituted sewage or something. It'll love you for the Valvoline!! thumbsup
"even if you're paranoid, they can still be following you" hide
"live so the preacher doesn't have to lie at your funeral" wink
#1657156 - 11/03/09 07:52 PM Re: Any API-SG compatible oils? [Re: Antigen]
CSM746 Offline
Loc: Michigan
yes, that will work fine...I use Delvac as stated but your Valvoline has the following add pack:
ZDDP 1270 ppm
Calcium 3964 ppm
Magnesium 14 ppm
Boron 148 ppm
Moly 112 ppm
You can find pour point, flash point, etc. on their site, but this is a robust oil
Edited by CSM746 (11/03/09 07:56 PM)
#1661746 - 11/07/09 01:05 AM Re: Any API-SG compatible oils? [Re: CSM746]
Antigen Offline
Thanks for the input guys. =) I already put the valvoline in. Works like a charm. I'm just using this to break the scooter in.
I will later on switch on Royal Purple XPR or MaxCycle, Which ever is available after the break-in. Like what I said, Good stuff is hard to come about in the area where I am currently residing.
Everything is Castrol, And I hate Castrol. Just had bad experiences with is. There are other inferior brands like top1, Zic, Whiz and the likes. You know what I'm talking about. =)
#1661754 - 11/07/09 01:34 AM Re: Any API-SG compatible oils? [Re: Antigen]
chevrofreak Offline
Loc: Billings, MT
That Valvoline is probably a darned good oil. It's the older CI-4/SL spec, so it should protect very well. There isn't much reason to spend the money to buy the bike specific oils.
I <3 Red Line oil
