Purolator PureONE PL14610 - 6k Miles
by ThirdeYe
07/23/16 07:47 AM
'06 Kia Sportage weird issue
by CincyDavid
07/23/16 07:33 AM
Dented Again
by AirgunSavant
07/23/16 06:42 AM
Does EGR blocking increase diesel consumption?
by berniedd
07/23/16 06:20 AM
Has BP left the gas retailing market?
by Vern_in_IL
07/23/16 05:45 AM
Commentary on Gate's Commentary on Electricity.
by Shannow
07/23/16 05:14 AM
techron article
by Joe1
07/23/16 05:08 AM
Lighter or heavier o-20 oils
by shDK
07/23/16 04:53 AM
Nice Gun Store Find
by bobbob
07/23/16 01:57 AM
Gun Prices
by bobbob
07/23/16 01:55 AM
Nissan Maxima pre-cats common problem
by Rohan
07/23/16 12:43 AM
License Plate Lights Quit
by Nick1994
07/23/16 12:39 AM
Omaid, Bwayne, krellmk, Annette, bimmergeek
58567 Registered Users
67 registered (Alex D, 4WD, 41 Plymouth, b1amgm47, Axe Man, acbent, 6 invisible), 1471 Guests and 8 Spiders online.
58567 Members
66 Forums
252136 Topics
#1644260 - 10/24/09 03:37 PM TCW3 & DI Engines
Eddie Offline
Loc: Florida, Cape Coral
I had a thought concerning the use of TCW3 in my Mazda DI engine. All the fuel does not get burned when in high power use (A/F ratio of ~ 10:1). The addition of TCW3 (1/500 ratio)probably does not all get burned. This may exacerbate the problem of intake valves getting carboned up via the PCV system. Possibly the addition of TCW3 is not a good idea.I would like to hear opinions from those with some background in DI engines and intake valve issues.
CX5 Touring 2.5L :-)
#1644297 - 10/24/09 04:23 PM Re: TCW3 & DI Engines [Re: Eddie]
Nederlander75 Offline
Loc: Pardon?
Id think so, yes. I personally like the RLI Bio plus bc of the upper cylinder lube in an ester form that will clean if it gets into the intake. Redline would be a good idea as well.
#1644409 - 10/24/09 06:09 PM Re: TCW3 & DI Engines [Re: Nederlander75]
Steve S Offline
Loc: East of IGO
The thing to really consider is ,,, Does a top end oil really do any good?
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1644411 - 10/24/09 06:10 PM Re: TCW3 & DI Engines [Re: Steve S]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
It will work the same but you will want to use less in your ratio.
I would say about 1/3 less TCW3 to fuel.
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1645529 - 10/25/09 05:24 PM Re: TCW3 & DI Engines [Re: StevieC]
ekpolk Offline
The Regenerator
Loc: Pensacola FL
The Pennzoil Synthetic TC-W3 is an ester-based oil.
I dunno about that. In the non-DI engines, you get the benefit of the fuel, and whatever you've added to it (for better or worse) washing over the intake valves as it transits into the combustion chamber. In the DI engines, this potentially critical phase in mixture movement is missing, as the fuel enters the CC directly. I'm presently theorizing that some of the horribly messed up DI engine intake valves are becoming victims of getting nothing but smutty PCV vapors in the intake air stream, which then create an awful carbon build up on those valves.
09 Camry Hybrid, Black (M1 5w-20, std flavor).
07 Avalon XLS, Cassis Pearl (GC 0w-30).
04 Prius, Black (GC -- 0w-30).
#1645582 - 10/25/09 06:01 PM Re: TCW3 & DI Engines [Re: ekpolk]
Eddie Offline
I've been running a 1/500 mix of TCW3 and am starting to think it was a bad but, recommended idea. ekpolk explained what I tried to state in my opening question. I think I will reduce the mix to 1/750 until the last TCW3 is gone and that will be the end of it, unless I hear a convincing evidence to continue with the mix. Ed
