Old wall furnace
by Jarlaxle
08/26/16 02:55 PM
automatic side folding mirror squeak
by Grambo
08/26/16 02:11 PM
Anybody own a new Mazda 6?
by AirgunSavant
08/26/16 01:58 PM
Do Employees Of Car Companies Get New Cars Cheap ?
by crazyoildude
08/26/16 01:54 PM
Amsoil SVG 75W90, 50K, 04 Duramax 196K
by dhellman12
08/26/16 01:53 PM
When an orifice is needed & when it is not (long)
by ryaneirich
08/26/16 01:38 PM
UT-Austin Response to CC
by sleddriver
08/26/16 01:36 PM
Grease darkening quickly on bicycle bearings
by Wheel
08/26/16 12:54 PM
Just replaced valve cover gasket
by JeepWJ19
08/26/16 11:48 AM
You Got A Merv People!
by AirgunSavant
08/26/16 11:17 AM
Total Quartz 9000 Energy 0W30 - Synthetic or not?
by Seweryn
08/26/16 10:32 AM
Options for Cadillac DTS with the Northstar Leak
by Ddub
08/26/16 10:21 AM
rgmbedzi3, wildkid2008, dccode, dromonk, sledhead1
58930 Registered Users
98 registered (1JZ_E46, adamrc, Al, AirgunSavant, AlaskaMike, 2015_PSD, 9 invisible), 1783 Guests and 33 Spiders online.
58930 Members
66 Forums
253587 Topics
#1642013 - 10/22/09 10:03 PM Does Low Noack Volatility Numbers = Low Burning
JSRT4 Offline
Loc: ONTARIO,CANADA
Just curious about the value of having low volatility numbers on an oil. Does an oil with low volatility numbers mean that it might burn less than an oil with higher volatility numbers when used in the same engine. I've been looking for an oil with low numbers, but just curious if this is a worthwhile feature of an oil. My thinking is that low volatility might mean lower chance of oil rings being stuck over time. Not sure if this is correct or not though. any info appreciated, thanks.
2002 Honda S2000 2.0L
2015 Jeep Cherokee 2.4L
#1642037 - 10/22/09 10:21 PM Re: Does Low Noack Volatility Numbers = Low Burning [Re: JSRT4]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
It just means less evaporative loss while putting up with the stresses your engine puts on it.
For an engine that is burning oil the best thing you can do is do a good engine cleaning using some MMO in the oil preferable along with a high mileage oil, for a few runs.
This will clean the rings and any buildup and help to revitalize hardened seals.
Then switch to a thicker grade High mileage oil or thicker non high mileage oil depending on how much consumption is going on.
Another advantage of oils with better NOACK is PCV's that stay clean and oily vapour that doesn't endup inside your intake/plenum etc. in excessive quantities.
What kind of engine, mileage, and consumption are we talking about?
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1642066 - 10/22/09 10:38 PM Re: Does Low Noack Volatility Numbers = Low Burning [Re: StevieC]
JSRT4 Offline
Loc: ONTARIO,CANADA
thanks for the quick reply steviec, your information on recent posts have been very helpful. My car doesn't really have consumption problems right now, but this engine is known to consume some oil due to the harsh combustion environment at higher rpms - 2L Honda S2000 2002 model year. I was just thinking that a low volatility oil might help keep the rings working as best as possible and avoid consumption issues in the future. thanks for your insight.
#1642084 - 10/22/09 10:49 PM Re: Does Low Noack Volatility Numbers = Low Burning [Re: JSRT4]
StevieC Offline
It's a happy balance between a quality fluid with a good base stock, additive package and NOACK rating.
You can spend countless hours driving yourself crazy looking at numbers until you can't see straight.
Use a fluid that seems to be well rounded and leave it at that.
I think I recommended Amsoil SSO for your engine right? It has a very good NOACK and will serve you well.
Glad I could help. thumbsup
cheers
Steve
#1642095 - 10/22/09 10:55 PM Re: Does Low Noack Volatility Numbers = Low Burning [Re: StevieC]
JSRT4 Offline
Loc: ONTARIO,CANADA
Yup it's definitely something that has been driving me crazy, looking at too many numbers and advertisement info. , time to take the plunge and dive into an interval with a good oil. I will definitely be running the amsoil fluid, just finishing a short run with a high mileage oil to clean things out from previous owners and it should be ready for a good synthetic like amsoil. thanks again
cheers
Steve
#1642099 - 10/22/09 10:59 PM Re: Does Low Noack Volatility Numbers = Low Burning [Re: JSRT4]
StevieC Offline
Do the SSO... You won't be sorry. thumbsup
I will let you know how my Red Line run turns out... Maybe that will be a choice for you too.
If you really want good No Ack check into the Fluid Terry Dyson likes Renewable Lubricants. They have some insane performance made from vegetable bases and unmatched by Amsoil/Red Line in some areas like NoAck.
I have used it and see amazing results. I've got more lined up to use once my Red Line testing is over.
#1642106 - 10/22/09 11:02 PM Re: Does Low Noack Volatility Numbers = Low Burning [Re: JSRT4]
JohnBrowning Offline
Loc: USA
Not always but it is usually a safe bet. It depends on how your engine is losing the oil. DO you understand the temperature that the NOAK test is done at? No car is going to have sump temps that high and the ring area's could exceed that.....So their is more to it then just NOAK. I have ran some oils that later on I found out had dreadful NOAK yet I had no observable consumption on the other hand I have ran some with great NOAK yet lost 1/4 of a quart in a few thousand miles!
So in theory a lower NOAK should produce lower consumption.More important and more over looked is that an oil with a lower NOAK should produce less deposits from light hydrocarbons cooking off!
