08 caravan / oil seeping from spark plug
by Mark72
02/12/16 11:25 PM
Holley Accelerator pump probem
by nwjones18
02/12/16 10:56 PM
Sealant for threaded air hose fittings.
by BigD1
02/12/16 10:37 PM
on line data search programs - which is best?
by bmwjohn
02/12/16 10:11 PM
What size air compressor is needed
by ram_man
02/12/16 09:45 PM
DHS wants to force car owners to use OEM parts
by faltic
02/12/16 08:54 PM
Castrol Edge 5w30 no longer A5/B5
by slacktide_bitog
02/12/16 08:20 PM
Best Oil Analysis?
by countryboy9799
02/12/16 07:28 PM
Left my lights on and battery died.
by joegreen
02/12/16 07:25 PM
Honda CRX '91 transmission fluid
by jhmed80
02/12/16 07:18 PM
It's winter, let's take out the... Motorcycle???
by OVERKILL
02/12/16 06:54 PM
Home Testing for Gas in Oil?
by landtoy80
02/12/16 06:54 PM
wdleighton1, RTS, jhmed80, engus, Rob_Pol
56902 Registered Users
26 registered (deoxy4, BlueKelah, AEHaas, DaveBinVa, 1345, 3 invisible), 515 Guests and 94 Spiders online.
56902 Members
66 Forums
244626 Topics
#1641822 - 10/22/09 07:09 PM Changing valve stem seals on Camry...
daves66nova Offline
Loc: los angeles
Is it possible to change out the valve stem seals on a 95 Camry 4 cyl. without taking the head off?
THIS SPACE FOR RENT, PLEASE PM ME.
#1641833 - 10/22/09 07:15 PM Re: Changing valve stem seals on Camry... [Re: daves66nova]
bepperb Offline
Loc: Milwaukee, WI
With the rope trick, or a good air supply into the spark plug hole. Yes.
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
#1641842 - 10/22/09 07:24 PM Re: Changing valve stem seals on Camry... [Re: bepperb]
daves66nova Offline
Loc: los angeles
Cool,thanks
#1641883 - 10/22/09 08:15 PM Re: Changing valve stem seals on Camry... [Re: bepperb]
Familyguy Offline
Loc: Virginia
+1
I rigged a "valve popper" from a hose from a compression tester (the gauge had broken) and stuck a NPT air chuck on the other end with a hose clamp.
2013 Kia Sorento EX
3.5L AWD
#1641996 - 10/22/09 09:50 PM Re: Changing valve stem seals on Camry... [Re: Familyguy]
JohnBrowning Offline
Loc: USA
They make a device that hooks to your air compressor and has the right threads for the model that will hold the valve in place while you work. Are you sure it needs new seals? That is a lot of work to get to them if you do not need them. I have found that normaly the valve stem seals on Toyota's tend to last as long as the guides unless the engine was dirty for a long time as sludge and carbon desposits will kill seals faster then you can blink! maybe it would be worth a try if you ahve not done so to try Auto-Rx first. It can not hurt the worst thing would be you still needed to change them.
Sometimes they come unseated and simply pressing them back into place is all that is needed.
I have had great luck with TRW made seals and gaskets. Their was a time when the TRW kits where so cheap that I would order a complete rebuild kit then chuck the pistons and cam for ones of my choice in place of buying things seperately. So if you are not going to use OEM TRW and Knoch both used to make nice seals for most of Toyota's applications!
#1642005 - 10/22/09 09:56 PM Re: Changing valve stem seals on Camry... [Re: JohnBrowning]
paulo57509 Offline
Loc: Tracy, CA
I need to do this on my '87 Camry (3S-FE).
My question is how do you compress the valve spring on a OHC head? Will one of these type of compressors work?
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200354077_200354077
1987 Chevrolet Camaro IROC-Z 5.0L
1987 Acura Legend L Coupe 2.7L (5-Speed)
1992 Lumina Euro Coupe 3.1L
1998 Lexus LS400
2003 GMC Safari
#1642014 - 10/22/09 10:04 PM Re: Changing valve stem seals on Camry... [Re: JohnBrowning]
daves66nova Offline
Loc: los angeles
Originally Posted By: JohnBrowning
Are you sure it needs new seals? maybe it would be worth a try if you ahve not done so to try Auto-Rx first.
It emits a puff of white smoke everytime i turn it on when the engine's cold
#1642564 - 10/23/09 10:12 AM Re: Changing valve stem seals on Camry... [Re: daves66nova]
bepperb Offline
Loc: Milwaukee, WI
Paulo, I don't think you'll need anything like that. How about something like this (this isn't the only manufacturer of this magnetic tool). I think you're overestimating how firm the spring will be.
http://www.youtube.com/watch?v=ZFTaeu4GIPo
Edited by bepperb (10/23/09 10:13 AM)
2004 Highlander 2.4
Recently Gone:
1993 Kawi EX 500
#1642835 - 10/23/09 01:17 PM Re: Changing valve stem seals on Camry... [Re: bepperb]
mechtech2 Offline
Loc: Chicago Area
You can probably depress the valves springs by hand, with no tool.
But a tool is nice!
As mentioned, a piece of nylon rope jammed into the cylinder will work well. Put the engine 90 deg BTDC first. Then turn the engine so the piston jams the rope tight against the valves.
When you don't have a compressor and adapters, this is a great alternative.
#1643248 - 10/23/09 06:15 PM Re: Changing valve stem seals on Camry... [Re: mechtech2]
babyjay8495 Offline
Loc: cincy
I think stuffing rope in the cylinder was the best method, turned out i ran out of time and couldn't get back to it until next weekend, happy i didn't use the air hose that time. Pushing the springs down by hand would be pretty [censored] hard, but make sure you have someone there with a magnet to catch the keepers, those things can fly off and good luck finding them. I tried the average spring compressor, but found out they were too big and wouldn't let me compress them. What i did was take a cheap pair of harbor freight long needle nose pliers and welded them so the tips would lay on outside of the top washer and pushed down. Have fun!
07 civic
03 silverado
94 tercel
