Does air go stale?
by mjoekingz28
02/12/16 04:13 PM
RAILROAD GUYS: What is this sound and one other Q
by SumpChump
02/12/16 03:59 PM
Got a free 5gal bucket of Mobil SHC 627
by MinamiKotaro
02/12/16 02:59 PM
Hard starting LCT snow engine..
by JTK
02/12/16 02:34 PM
low-temperature oil gelling reversible?
by DrRoughneck
02/12/16 12:51 PM
I HAD to do it!
by Kuato
02/12/16 12:24 PM
Why Erin Esurance vanished from TV
by Benzadmiral
02/12/16 11:39 AM
Engine Light Advice
by coopns
02/12/16 11:14 AM
Caution UOA - PP 10W30 6881m on 2001 Jeep 4.0
by Donald
02/12/16 11:09 AM
What happened to the thin oil movement?
by camrydriver111
02/12/16 10:57 AM
Mastercraft Strategy tires (I'm cheap)
by Bgallagher
02/12/16 10:41 AM
Mobil Delvac ATF in a regular car transmission
by SuperValue
02/12/16 10:35 AM
RTS, jhmed80, engus, Rob_Pol, Nick24w
56901 Registered Users
105 registered (97K15004WD, 2010Civic, 901Memphis, akela, 19kj57, AEHaas, 12 invisible), 1708 Guests and 192 Spiders online.
56901 Members
66 Forums
244606 Topics
#1639578 - 10/20/09 10:55 PM Grease gun injector needle for sealed balljoints.
wirelessF Offline
Loc: Oahu, Hawaii
Is it possible to use a grease gun needle to pierce the rubber seal to grease ball joints? It does not have fittings as it's a 2wd truck.
My lower ball joints on my truck is leaking grease and I'm worried that it might fail. I might change the ball joints w/ grease fittings as a preventative maintainance, but with the lack of funds, I was thinking of greasing them to get more life out of them.
#1639591 - 10/20/09 11:03 PM Re: Grease gun injector needle for sealed balljoints. [Re: wirelessF]
ewetho Offline
Loc: Kankakee, IL
You are just causing a problem by doing it that way but since you have a failing issue already as a temp fix to get you through till replacement go ahead.
2004 Neon SE 2.0L Current Fill
Motorcraft 5W-30, Motorcraft FL-300
#1639613 - 10/20/09 11:18 PM Re: Grease gun injector needle for sealed balljoints. [Re: ewetho]
onion Offline
Loc: kansastan
In my experience, aftermarket suspension parts don't last nearly as long at OEM parts. So as long as your ball joints aren't loose, I wouldn't recommend replacement. Replacing them before they fail would likely be doing your vehicle a disservice.
The invisible and the imaginary look exactly the same.
#1639672 - 10/21/09 12:31 AM Re: Grease gun injector needle for sealed balljoints. [Re: onion]
Stanley Rockafeller Offline
Loc: Van, B.C.
don't bother with the needle greasing. I did that and it didn't really help anything, as the grease needs to be in the "ball and cup" area to be useful. Since your only greasing around the shaft, your not really doing anything but wasting your time.
Just wait till they fail then get some greasable ones.
-88 BMW 325ism-the Model 3
#1639812 - 10/21/09 07:34 AM Re: Grease gun injector needle for sealed balljoints. [Re: Stanley Rockafeller]
demarpaint Offline
Loc: NY
As others mentioned forget using the needle to grease them, it won't work well. If you do it you popped a hole in the boot which will eventually open up more allowing dirt etc in and ruin the joint faster. If/when the joint fails replace it with a quality part that has a zerk fitting.
God Bless Our Troops
#1640116 - 10/21/09 12:51 PM Re: Grease gun injector needle for sealed balljoints. [Re: demarpaint]
mechtech2 Offline
Loc: Chicago Area
I have drilled and tapped the BOTTOM of the fitting for a grease fitting, but I don't consider that a good idea, in general.
Sealed joints seem to work fine if they are not torn or leaking.
#1640615 - 10/21/09 08:43 PM Re: Grease gun injector needle for sealed balljoin [Re: mechtech2]
onion Offline
Loc: kansastan
Yes, I've done that a couple of times, too- in situations where the boot was torn but I didn't want to replace the part. Kindof a pain, and you have to take precautions to minimize any metal debris getting into the ball joint- but it worked well enough.
Also, for what it's worth, the boots on my '94 Corsica's ball joints have been torn for the last 9 years (about 90k at the time). I grease them maybe twice a year, and at 175,000 miles, there's still no visible play in them. So I don't think that a torn boot is necessarily a big deal.
#1640745 - 10/21/09 10:11 PM Re: Grease gun injector needle for sealed balljoin [Re: onion]
Michael_P Offline
Loc: Ohio
I have greased sealed balljoints with a needle but not by peircing. Take the extra step and pop the balljoint off and insert the needle between the shaft and boot. I stopped the squeaking on my 1997 F150. The balljoints & tie rods were tight, just squeakig. That was around 120,000 miles. The Truck now has 200,000 miles. Keep in mind you have to work the grease in. Had there been any amount of play or loose feel, I would have replace them in a heartbeat. The Ford 1/2 tons were known to have squeaky balljoints as they must have gone skimpy on the grease.
