OK, before I lube it ...
by BrocLuno
4 minutes 46 seconds ago
Toyota Japan Fluid SDS
by SXE10
Yesterday at 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
Yesterday at 11:25 PM
Considering a differential swap
by buck91
Yesterday at 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
Yesterday at 09:51 PM
Car Acronyms
by Marco620
Yesterday at 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
Yesterday at 09:41 PM
Carpet cleaning methods.
by Run
Yesterday at 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
Emtrac Plus Battery
by Tapan
Yesterday at 09:25 PM
Did you know of Mr. Urban?
by CourierDriver
Yesterday at 09:19 PM
Ever Been a Successful Front Suspension Rebuild ?
by CrackyWainwright
Yesterday at 09:06 PM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
33 registered (CR94, bdcardinal, anonobomber, bvance554, BrocLuno, ag_ghost, 4 invisible), 977 Guests and 9 Spiders online.
58295 Members
66 Forums
250914 Topics
Page 1 of 2 1 2 >
#1566279 - 08/14/09 07:13 PM Parts Plus oil filter
Tortured_Soul Offline
Loc: St. Louis Park, MN
Are they any good? Who are they made by? I think I read somewhere that they are made by Wix. Thanks in advance!
2006 KIA Spectra5
Mobil Special 5W-30
NAPA Silver filter
#1566284 - 08/14/09 07:15 PM Re: Parts Plus oil filter [Re: Tortured_Soul]
ThirdeYe Offline
Loc: Walker, MI
The one I have is made in China. Not sure what actual company makes it. It looks well built, although I haven't cut it open. The bottom is sealed in plastic. Also on the box it says "Meets or exceeds OEM specifications. Manufactured by an TS 16949 Certified Company"
99 Pontiac Firebird - 93k - Havoline 10W-30/Purolator PureOne PL10111
08 Scion tC - 119k - RP 0W-20/Purolator Classic L14477
#1566285 - 08/14/09 07:15 PM Re: Parts Plus oil filter [Re: Tortured_Soul]
gonzo Offline
Loc: millington tn.
Is it blue?I have one on my work truck.Can't get look at it to see who I think it'd made by.
#1566288 - 08/14/09 07:17 PM Re: Parts Plus oil filter [Re: gonzo]
Yes, it is blue... I just hope it's > Fram.
2006 KIA Spectra5
Mobil Special 5W-30
NAPA Silver filter
#1566297 - 08/14/09 07:22 PM Re: Parts Plus oil filter [Re: Tortured_Soul]
gonzo Offline
Loc: millington tn.
I know Parts+ sells the Wix brand in oil,air,fuel and also transmission filters.I just recently found out they had their own brand of filters.
#1566767 - 08/15/09 05:52 AM Re: Parts Plus oil filter [Re: gonzo]
caravanmike Offline
Loc: ohio
blue parts plus seems to be identical to the napa pro-select which is made by wix.
Oils I use: Any 5w-30,5w-20 conventional
#1566800 - 08/15/09 07:05 AM Re: Parts Plus oil filter [Re: caravanmike]
mrsilv04 Offline
Loc: Illinois
Someone needs to cut one open.....
Whatever you do... do NOT speed through the town of Gauley Bridge, WV.
#1567061 - 08/15/09 12:00 PM Re: Parts Plus oil filter [Re: mrsilv04]
gonzo Offline
Loc: millington tn.
I'd use it in a heartbeat.
#1568487 - 08/16/09 08:28 PM Re: Parts Plus oil filter [Re: gonzo]
ThirdeYe Offline
Loc: Walker, MI
That's odd, the one I have doesn't look like it's made by Wix and has a plastic seal on the bottom. The "Made in China" on the box makes me wonder... Once my camera is done charging, I'll take some pics of it. I don't know how old it is though, it was given to me by someone who scrapped their car and they no longer needed it.
#1569107 - 08/17/09 10:01 AM Re: Parts Plus oil filter [Re: ThirdeYe]
ThirdeYe Offline
Loc: Walker, MI
I asked the person that gave it to me and he thinks he got it in 2006. I don't think it's a Wix, because of the "Made in China" on the box, the seal on the bottom, and the fact that the Wix for this application has 6 larger holes in the baseplate, not 8 like this one. I don't understand their numbering system, but it cross-references to the AC Delco PF52/Fram 3980/Wix 1036
#1569165 - 08/17/09 10:35 AM Re: Parts Plus oil filter [Re: ThirdeYe]
labman Offline
Loc: Nothern USA
Look inside. If it has a circle of small holes in the far end, likely it is made by Fram with a clicker bypass in the dome end. Champ was using those for a while before going to Ecores and blue buttons on the small ones. WIX or Clarcor's should have a solid steel end cap.
With it being free and a lack of evidence Frams are as bad as they are cracked up to be, I would run it and then cut it open.
Edited by labman (08/17/09 10:37 AM)
#1569174 - 08/17/09 10:40 AM Re: Parts Plus oil filter [Re: labman]
ThirdeYe Offline
Loc: Walker, MI
There's no circle of small holes in the far end. I don't think it's a Fram, either.
#1569495 - 08/17/09 02:47 PM Re: Parts Plus oil filter [Re: ThirdeYe]
I hope it's not a Fram! I could take it off and put on the Purolator I have... I had to go to Goodyear to get my oil changed, because I recently moved. Otherwise I would have done it myself. At least they use Kendall syn blend. I just had to crawl under the car and see what brand of filter they used.
2006 KIA Spectra5
Mobil Special 5W-30
NAPA Silver filter
#1570110 - 08/18/09 12:05 AM Re: Parts Plus oil filter [Re: Tortured_Soul]
nthach Offline
Loc: California
Looks like a Pentius...
#1629664 - 10/13/09 03:05 AM Re: Parts Plus oil filter [Re: nthach]
Augustus Offline
Loc: Arizona, USA
I found a Parts Plus oil filter at a local Warehouse distributor which also sells retail. After a search online for a WIX distributor...and they mentioned their line of Parts Plus products.
PH2835 fits my 05 4Runner. Made in China on the box. The $2.02 price scared me. The clerk gave me a Parts Plus catalog. The inside back cover shows an exploded diagram of their oil filters.
I have a pic, but thought better of posting it due to copyright issues -?
Metal endcaps, coil spring, nitrile anti-drain valve, spiral wound center tube, 0.5mm steel sheet can. Doesn't sound like a FRAM to me!
In a limited comparison, was told a WIX uses a leaf spring vs a coil. Is that true?
The same location: cabin filter $5.29, air filter $10.22.
vs. $20.99 and $18.+ at the Dealer & WallyWorld, respectively.
I couldn't pass that up! Definitely my new air filter supplier.
Page 1 of 2 1 2 >
