Hi Everyone. Great Website on Oils and Fluids!
I have a question. I have a 2005 Nissan titan, 60K miles. I was at a GM dealership getting tires done on my truck (friends of mine) and I decided to change the transfer case fluid.
I have changed it before with Synthetic Mobil 1 ATF, but the GM dealership didn't have Mobil 1. They said Dexron VI is the synthetic replacement for Dexron III.
(Nissan calls for D Matic ATF or Dexron III).
So I said ok, this would be fine.
When I got home that night, I had driven 67 miles with the Dexron VI in my transfer case. I was curious and did some research on Dexron VI and then found that GM has a bulletin out stating NEVER to use Dexron VI in manual transmissions or transfer cases as it will cause a failure!!!
I nearly had heart failure!! So I immediately went to the store and got Mobil 1 Synthetic ATF and drained my transfer case and refilled. I didn't see any noticeable metal or anything, and the fluid was clean/red. It did smell bad though, like used gear oil.
My question is, why would Dexron VI cause your transfer case to fail, when it is suppose to be better then dexron III?
And the bigger question is, do you think I did any damage to my transfer case?
What damage would the Dexron VI cause?
Thanks a lot!
Thanks a lot!
