EPA to ban race cars?
by Kruse
17 minutes 27 seconds ago
Kluber Isoflex LDS18 Special A
by Phishin
23 minutes 48 seconds ago
Taurus question
by Lubener
Today at 04:36 AM
Lucas Extreme Duty CLP?
by Ws6
Today at 04:19 AM
Pennzoil Ultra 5w20 / 7500mi / '08 Ford Fusion 3.0
by sdude2k2000
Today at 12:59 AM
Hairline Cracks in Radiator
by Merkava_4
Today at 12:05 AM
Super Tech Syn 5/30
by RevRider
Yesterday at 11:31 PM
Installing a dish washer.
by ram_man
Yesterday at 10:37 PM
Strangest Three Wheel Car Ever
by Fsharp
Yesterday at 09:57 PM
Remove Gasoilne and other Blowby Gasses
by landtoy80
Yesterday at 09:48 PM
Trans Am said goodbye to his battery today.
by ls1mike
Yesterday at 09:39 PM
Lil Big Rig - I want one
by montero1
Yesterday at 09:01 PM
robco, TrogDorInjection, wytenow, maxud, OrchardAuto
56875 Registered Users
72 registered (aircooled, B767capt, Al, Atesz792, beanoil, 04SE, 6 invisible), 799 Guests and 206 Spiders online.
56875 Members
66 Forums
244482 Topics
#1624901 - 10/08/09 04:15 PM What is the difference between Mercon V and MV??
SCORPION6 Offline
Loc: Panamā (Central America)
Is really conduse. I thought that was the same but apparently are differents. A call the Mazda dealer (I am from Central America) al I asked for the ATF for Mazda 6. They Told me that they use the MERCON V, not the MV. They told me that are the same but I read that are differents.
Impossible to get the MV here. I had to bought the Mercon V, but by mistake I replace some months ago for a normal ATF, because in the Manual are a Mazda 6 2wd and 4wd, I use the one that use the 4WD and the normal that you can get here everywhere. Bean the problem with tha transmission, shift.
This appear in a Service Boletin from Mazda:
Subject:
CORRECT APPLICATIONS FOR ATF M-V (TYPE M5) AND MERCONŽV AUTOMATIC
TRANSMISSION FLUIDS
Bulletin No: 05-005/08
Last Issued: 4/11/2008
Service Bulletin Mazda North American Operations
Irvine, CA 92618-2922
MULTI MODEL - CORRECT APPLICATIONS FOR ATF M-V (TYP
DESCRIPTION
Always be sure to use the correct automatic transmission fluid when replacing ATF. Using the wrong ATF may
cause shift quality complaints or may even damage the transmission.
NOTE:
• ATF M-V (TYPE M5) IS NOT THE SAME FLUID AS MERCONŽV ATF.
• ATF M-V (TYPE M5) HAS A GREATER VISCOSITY THAN MERCONŽV ATF IN LOW TEMPERATURES.
• ATF M-V (TYPE M5) HAS A GREATER ANTI-JUDDER SPECIFICATION THAN MERCONŽV ATF.
CAUTION:
• USING ATF OTHER THAN ATF M-V (TYPE M5) IN AUTOMATIC TRANSMISSIONS
DESIGNED TO USE ATF M-V (TYPE M5) MAY CAUSE SHIFT QUALITY COMPLAINTS.
• USING ATF OTHER THAN MERCONŽV IN AUTOMATIC TRANSMISSIONS DESIGNED TO
USE MERCONŽV MAY CAUSE TRANSMISSION DAMAGE.
#1624917 - 10/08/09 04:33 PM Re: What is the difference between Mercon V and MV?? [Re: SCORPION6]
bdcardinal Offline
Loc: Santa Barbara, CA
Mercon V is Mercon V. in Mazda speak, MV is the equivalant of FNR5 fluid, they are not compatible, and we have seen complete trans failures due to the use of Mercon V in a MV application.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Patron Member
#1624935 - 10/08/09 04:45 PM Re: What is the difference between Mercon V and MV?? [Re: bdcardinal]
Colt45ws Offline
Loc: Central Washington
That seems like a mistake on their part to name it M-V. When you mark it as such it makes people that are knowledgeable enough to be dangerous, ASSuME Mercon V is the same stuff.
-Colton
2002 Ford Crown Vic PI, 174k "Highwayman" (Ex-Kootenai County, ID Unit #42)
#1625024 - 10/08/09 06:07 PM Re: What is the difference between Mercon V and MV?? [Re: SCORPION6]
ludey Offline
Loc: California, USA
Wow! Excuse my ignorance but with all the acronyms used in this forum. I thought this was about the difference between Multi-Vehicle=MV ATF which, usually is Mercon V. I did not even know there was a classification of ATF called M-V. I understand why there would be confusion between the M-V classification and Mercon V fluid.
#1625236 - 10/08/09 09:34 PM Re: What is the difference between Mercon V and MV?? [Re: ludey]
Colt45ws Offline
You will find a lot of acronyms when you get into any technical field. Computers are really overrun with them too.
-Colton
#1625547 - 10/09/09 07:27 AM Re: What is the difference between Mercon V and MV [Re: SCORPION6]
bearda Offline
Loc: Germantown, MD
There are a couple of multi-vehicle fluids that pass M-V specs. I've used both Mobile1 Synthetic ATF and Amsoil ATF in my Mazda3's trans. Both of them list M-V on the bottle.
2006 Mazda3 2.3L, PU 5W-20
1995 Mazda Miata, M1 0W-40
2007 Toyota Yaris, PU 5W-30
#1626087 - 10/09/09 04:59 PM Re: What is the difference between Mercon V and MV [Re: bearda]
maximus Offline
Loc: TX
Yes, the M-V is a dealer item. I just bought 5 quarts from my local dealer. The price went from $15 to $10/quart after I grumbled. There's no recommended service interval for the transmission in the manual, but the pan has a drain plug. I plan on doing a drain and fill with this expensive "Mazda M-V" stuff. I don't want to take a chance using a non spec product. I don't care for that universal, "one for all" stuff either. After hours of reading, I've concluded it's good practice to change ATF about every 30,000 miles. I'm at 39,000 on the FF.
Edited by maximus (10/09/09 05:00 PM)
2011 Sonata GLS.
#1628444 - 10/11/09 11:25 PM MAZDAs [Re: maximus]
maximus Offline
Loc: TX
Ok, I did a simple drain and fill today. I drained the pan and re-filled with 3 quarts of this Mazda M5 stuff. Upon completion, I took a test drive. The transmission seems to shift smoother and a bit more responsively. It definitely felt good to pour that OEM fluid into the transmission. I will do another drain and fill next oil change and report back.
Edited by maximus (10/11/09 11:25 PM)
2011 Sonata GLS.
